Oil Change - How to avoid a mess when dropping the oil filter???
Discussion in '5th Gen 4Runners (2010-2024)' started by GrimJeeper91, Apr 24, 2024.
  1. Apr 24, 2024 at 7:01 AM
    GrimJeeper91
    GrimJeeper91 [OP] New Member
    Terry
    2024 TRD Off-Road
    Yokohama AT's, Bilstein 5100's, Talon's Garage full skids.
    After doing two oil changes now I'm a little annoyed at the oil filter situation. The first time I only let the oil filter drain a couple minutes before I pulled the housing. Big mistake, oil came gushing out and made a big mess when I removed the housing. At the time I though no biggie, I just need to let it drain longer.
    The second time I let it drain for at least 15 minutes . When I got back under there it was only dripping once about every15 seconds so I thought I was good. Wrong!!! I still had a gusher when I dropped the filter housing. How long do you need to let the SOB drain to avoid a mess???
    The first change was with a cold engine, the second hot. Neither really seemed to facilitate draining the filter housing.
    Also, what's the point of the little formed sheet metal clip that slips on to the side of the housing? It's barely hangs on there and I don't really see what function it would provide.
    On a positive note, my first oil change since installing the ValvoMax drain plug. That thing is the bomb! Going on the rest of the fleet at the next oil change!
  2. Apr 24, 2024 at 7:06 AM
    jdm-v35
    jdm-v35 New Member
    CO
    2018 4runner TRDORP
    Magnuson Supercharger etc.
    Did you remove the oil cap to allow it to breathe and let the oil drain better? I use the little oil filter drain adapter thing and it has never been an issue for me. I usually remove oil cap, drain oil pan for 15-20 min or so, put bolt back in, then drain oil filter for 5 min and remove filter. it's not completely dry or empty, but its not full of oil.
    Bagman and TrailSpecial22 like this.
  3. Apr 24, 2024 at 7:07 AM
    3JOH22A Toyota Gigolo
    I just pull the front skid and don't bother draining the filter bowl. You can try a flexible funnel like this https://www.amazon.com/OIL-UDDER-Magnetic-Flexible-Diameter/dp/B08LGRP33M Grip the filter bowl with the funnel when loosening the last couple of threads.
  4. Apr 24, 2024 at 7:07 AM
    Are you using the little drain fitting to drain the housing?
    And, even if you do use that, there always seems to be some oil left in the housing. I just keep the drain pan underneath and keep the housing level as I remove it, so I can dump it into the drain pan.
  5. Apr 24, 2024 at 7:11 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Elka 2.5, SPC UCA, durobumps, RCI full skids, RSG sliders, 10 lb Powertank, Maxtrax, Hi lift jack, Westscott Designs modular roof rack and ladder, ARB rear diff breather relocate, ECGS bushing upgrade
    Bagman and catbrown357 like this.
  6. Apr 24, 2024 at 7:22 AM
    Motivx drain. Get the cap tool too.
    catbrown357 likes this.
  7. Apr 24, 2024 at 7:28 AM
    Roadkill
    Roadkill New Member
    I haven't changed my oil yet. I've only had it a week but I have two other Toyotas. For my Tundra I take that little plastic part they give you to drain the housing and I put in a wine bottle and push it up in there to drain the oil. Then I dump it in my oil catch. I've never made a mess
    Bagman likes this.
  8. Apr 24, 2024 at 7:39 AM
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    My responses to the first six responses above:
    I didn't remove the filler cap up front. However, after the engine oil has drained fully the crankcase is obviously vented. Removing the filler cap can't hurt so I'll add that to the mix next time.
    I had pulled the front skid since I was swapping it out anyways so thankfully I had more room to work. My aftermarket skid has a door to access the filter, however, based on my first two experiences I'll probably just drop it anyways to help minimize the mess. Might need to try that funnel.
    Yes, I'm threading in the little plastic drain fitting into the bottom of the filter housing.
    I'm not sure how the Motivx drain tool is any better than the plastic one that comes with every replacement filter other than keeping the hands cleaner. I don't see how it would be more effective at draining the housing.
    I do have the Motivx cap tool, it's very nice!
    I guess messy oil changes must be a Toyota thing.
    Rocko9999 likes this.
  9. Apr 24, 2024 at 7:45 AM
    Agent_Outside
    Built 2011 T4R Limited
    Loosen the filter housing first, just a tiny bit, make it move so you can unscrew it by hand later. Then drain the housing. After a minute or so of the filter housing draining, and while it's still draining, loosen the filter housing by hand past the sealing o-ring. That lets housing breath and completely drain the rest with no mess.
    auspilot, SkereD 53, icestud and 2 others like this.
  10. Apr 24, 2024 at 8:25 AM
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    I'll give it a try! Thx...
  11. Apr 24, 2024 at 8:58 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Problem is draining the housing from the bottom-impossible to not get oil on your arm.
  12. Apr 24, 2024 at 8:59 AM
    Lou
    Lou New Member
    2021 TRD Off Road Premium
    This has been my experience too.
    jdm-v35[QUOTED] likes this.
  13. Apr 24, 2024 at 9:08 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    '24 ORP
    Don't use the filter drain. IMO it's garbage. The whole thing is a garbage design but the drain tricks you into thinking you've voided the filter and then suddenly there's oil draining into your armpit.
    Just take the filter cover off, leaving the drain plug in place. As you crack the filter cover and it starts loosening by hand, take a plastic grocery bag abd cover your hand and wrap the sides of it upwards over the filter cover, grab the filter cover by hand, and remove it through and then into the plastic bag. All the oil glops into the bag and you can retrieve the filter cover, old filter, and tube at your leisure and with rags ready to go.
  14. Apr 24, 2024 at 9:11 AM
    Rocko9999
    2011 Limited
    That's actually genius. Thank you.
    MeefZah[QUOTED] likes this.
  15. Apr 24, 2024 at 9:11 AM
    BiggestAUfan
    BiggestAUfan New Member
    2018 Super White TRD Off Road Premium XP
    Pending ;)
    I changed my Land Cruiser filter every 5k & oil every 10k.
    Can I change the filter only on my '18 4runner? (I've been using the dealership every 5k since I got it :( ).
    Thanks!
  16. Apr 24, 2024 at 9:14 AM
    Lou
    Lou New Member
    Or you can do all of that with less oil by draining the filter canister first.
  17. Apr 24, 2024 at 9:16 AM
    MeefZah
    Lexington, Ohio
    '24 ORP
    I've never found that to be the case, personally.
  18. Apr 24, 2024 at 9:17 AM
    jdm-v35
    jdm-v35 New Member
    CO
    2018 4runner TRDORP
    I have never heard of anyone doing that; seems a bit excessive. Most people that do that would change the oil every 5k and filter every 10k. I just do both every 10k or 1 year whichever comes first. I think 5k/6 month intervals is unnecessary and troublesome.
    2016SR5P likes this.
  19. Apr 24, 2024 at 9:29 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    That's kind of an ignorant thing to say. It is 100% better than that plastic bullshit thing that comes with the filter. It's aluminum and it threads into the base of the filter housing. Then, when that's set, another threaded piece screws into that and depresses the spring-loaded ball in the bottom of the filter housing (when you're ready). There's a length of flexible PVC tubing attached to the bottom of the tool that directs ALL of the oil into whatever container you use to catch the oil. No oil on the hands. Spend the money on this tool. It's worth every penny.
    Oil Filter Drain Tool Oil Filter Release Hose Tube Pipe Fit for Toyota, Lexus, Scion 2.0L - 5.7L Engines with Cartridge Style Oil Filter System
    Brand: POWERWORKS
    315 ratings
    Amazon'sChoiceOverall Pick
    200+ bought in past month
    $13.99$13.99
    One-Day
    Get a $100 Amazon Gift Card instantly upon approval for Prime Visa. No annual fee.
    Brand POWERWORKS
    Material Brass, Polyvinyl Chloride
    Item Package Quantity 1
    Head Style Fixed Square, Box End, Open End
    Finish Type Powder Coated
    About this item
    • PREMIUM QUALITY: This tool made of high quality heavy brass and include one 39 Inch PVC hose. Allows you to direct the oil into your oil disposal container, help you cut down on the mess even further. Fits Toyota Filter Housing Part# 15620-36020 & 15620-36010.
    • INSTRUCTIONS:you simply remove the drain plug of the oil filter housing and screw in the tool in the closed position, and then turn the wheel to the open the valve to let the oil drain out. When the oil finishes draining, turn the wheel again to close the valve, remove the tool, and then proceed to remove the oil filter housing as normal.
    • FEATURES ADN ADVANTAGES:changing the cartridge type Toyota oil filters is messy compared to their old spin on oil filters. After using this tool to empty the oil filter housing, the job of changing the oil filter cartridge is a lot neater .
    • FITS THE FOLLOWING VEHICLE MODELS: Fit for Toyota, Lexus, Scion 2.0L - 5.7L Engines with cartridge style oil filter system. If you are not sure whether the oil filterdrain tool will fit, please contact us before purchasing.
    • WHAT YOU'LL GET: 1x Engine Oil Drain Hose, Place order with 100% confidence, we provide 1 click refund for our valued customers in 3month. Please feel free to contact us if you have any questions and we are always stand by your side to issue your problems.
  20. Apr 24, 2024 at 9:29 AM
    Agent_Outside
    Speak for yourself
  21. Apr 24, 2024 at 9:36 AM
    Lou
    Lou New Member
    That's a little strong. For me, the plastic thing that comes with the filter makes more sense.
    1. I don't need a tube to redirect oil anywhere. I already have a drain pan under the filter canister.
    2. I don't need a tube that now has oil in it to drip somewhere else.
    3. The plastic thing is free.
    Spare Parts likes this.
  22. Apr 24, 2024 at 9:38 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    You do you man.
    Go Birds and Shark Bait like this.
  23. Apr 24, 2024 at 9:39 AM
    As others have chimed in, the cartridge filter arrangement doesn't lead to a mess for most people, but can be finnicky. The cartridge filter arrangement seemed like a good idea back in 2010. Toyota has since recanted and went back to steel canister filters with the 2022+ Tundra/Sequoia, 2024+ Tacoma, and soon the 2025+ 4Runner.
  24. Apr 24, 2024 at 9:42 AM
    java
    java fauxrunner
    2023 ORP ice cap
    Bypass oil filtration.
  25. Apr 24, 2024 at 9:50 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    It started with the 2nd Gen Tundra in 2007. I had one when they first came out and remember thinking how odd it was. What I like about it is there is no more cutting open traditional filters to inspect for metal or foreign objects in the filter. I still appreciate that to this day.
    I suppose after 18 years of changing oil on the Tundra and then the 4Runner, I've sort of perfected the no mess oil change. It does take some practice.
  26. Apr 24, 2024 at 9:52 AM
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    First off, best of luck dealing with your anger issues. Hopefully you can get the help you apparently need.
    Second, I acknowledged that it would keep your hands cleaner (or in my case, rubber glove on one hand). What I questioned was whether it was any more effective at removing the oil from the housing. I don't see why this would remove more oil than the "FREE" plastic fitting that comes with every replacement filter element.
  27. Apr 24, 2024 at 9:57 AM
    catbrown357
    Tempe
    2011 Limited 4WD
  28. Apr 24, 2024 at 10:29 AM
    joshdub
    joshdub New Member
    2020 TRD ORP
    I bet yall have to take a shower after you shit huh
  29. Apr 24, 2024 at 10:45 AM
    2020 4Runner
    2020 4Runner New Member
    Fl
    MotivX tools.
  30. Apr 24, 2024 at 10:51 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    Yep. It's so simple.
    2020 4Runner[QUOTED] likes this.
