Lower control arm bolt adjustment for alignment - known for seizing up?
Discussion in '5th Gen 4Runners (2010-2024)' started by TimGinCentralNJ, May 8, 2024.
  1. May 8, 2024 at 9:03 AM
    TimGinCentralNJ
    TimGinCentralNJ [OP] New Member
    Tim
    '24 Limited in Classic Silver
    TRD Pro rims w/265/70-17 Toyo OC AT3s
    Hey Gang-
    Re: my 2024 Limited:
    I was just talking with one of the techs at my local 4wd shop (OK4WD in Stewartville, NJ) and asked him whether he felt the alignments on Toyotas from the factory were pretty decent--or whether I should plan on having them do an alignment when they mount-up my new Toyo OCs this weekend.
    He felt the factory alignment should be good enough...but did mention that he's seen a number of cases where the alignment bolts on the lower control arms of 5th gen 4runners corrode and seize up within the vehicle's first year. He suggested having the assembly taken apart and thoroughly lubed at some point to prevent this.
    Is this a thing?
    Thanks!
    TimG
  2. May 8, 2024 at 10:36 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    If you're in an area where the roads are salted, then yes. It is a thing. I believe you fit the description if you're in NJ.
  3. May 8, 2024 at 10:40 AM
    TimGinCentralNJ
    Tim
    Thanks CB. I'm wondering if my upcoming Fluid Film treatment (which I plan to do yearly) might be adequate...or whether the assembly really does need to be disassembled and greased up in order to prevent this.
    TimG
  4. May 8, 2024 at 10:43 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Factory alignments can be crap, my runner was ok, but our RAV4 destroyed its first set of tires because the alignment was out of wack.
    TimGinCentralNJ[OP] likes this.
  5. May 8, 2024 at 10:45 AM
    It needs to be disassembled and coated with anti-seize. The bolt siezes to the steel sleeve inside the bushing, the FF is not going to get in there.
  6. May 8, 2024 at 10:48 AM
    TimGinCentralNJ
    Tim
    Much appreciated, TR....
    TimG
  7. May 8, 2024 at 10:50 AM
    No problem! It just occurred to me, Wanderlost Overland did a good video about this exact topic.
  8. May 8, 2024 at 10:50 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    If it were me, I would lube the adjusters independent of the fluid film. I think you're wise to do and annual treatment. Don't forget to lube all of your driveline. I do mine on every oil change, and I don't even live in the salt. Just good practice.
  9. May 8, 2024 at 11:09 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Falken Wildpeak 265/70R/17 load E
    I suspect that's a lot more common if you skipped rust prevention. I hit the insides of the controal
    Is it possible to do so without disturbing the current alignment?
  10. May 8, 2024 at 11:12 AM
    I know you can mark them with a paint pen and crack them loose once in a while while maintaining alignment, but not sure if you can fully remove them without needing to realign.
  11. May 9, 2024 at 6:12 AM
    RUNNER4DAN
    RUNNER4DAN New Member
    Daniel
    Doesn't need any
    Most car manufacturers will do a free alignment within a certain milage.
  12. May 9, 2024 at 6:18 AM
    Spare Parts
    Southern Maine
    22 LR ORP
    Not my dealership, they were all about pointing out how bad my tires were, and were more than willing to charge me for an alignment, at 20k miles. I went elsewhere and paid for lifetime, and now try every oil change or so.
  13. May 9, 2024 at 6:50 AM
    RUNNER4DAN
    Daniel
    Doesn't need any
    Nobody is going to do a free alignment at 20,000 miles! Usually it is within the 1st 12,000 miles.
  14. May 9, 2024 at 8:55 AM
    Spare Parts
    Southern Maine
    22 LR ORP
    Well, they saw the car every 5k from the get go, at 20k it was very clear the tires needed to be replaced.
    the alignment was shit from the factory.
  15. May 9, 2024 at 3:28 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    And yet you never requested an alignment! And now you're pissing and moaning because when you did after 20,000 miles they wouldn't cover it! How many damn potholes and curves did you hit in 20,000 miles?
    Quit your belly aching!
  16. May 9, 2024 at 4:41 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    Dude, why you jumping in my shit? I just stated what happened in my situation.
  17. May 10, 2024 at 4:48 AM
    RUNNER4DAN
    Daniel
    Doesn't need any
    Jist pointing out some obvious facts.
  18. May 10, 2024 at 5:57 AM
    Spare Parts
    Southern Maine
    22 LR ORP
    Sorry, I forgot some folks can help it .
    good day sir
  19. May 13, 2024 at 2:14 PM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    My passenger lower front cam seized on mine
  20. May 13, 2024 at 4:18 PM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    Just to show you how fast corrosion starts in the alignment cam bolts up here in the rust belt, here's the worst one out of my 2021 when it was just 4 months old. All were pulled and coated liberally with Never Seize before re-installation and a fresh alignment.
  21. May 13, 2024 at 5:19 PM
    TimGinCentralNJ
    Tim
    Holy crap....just 4 months?! That's insane. I've never heard of any modern mass produced vehicle succumbing to corrosion that quickly. Seriously...what is it with these trucks and rust exactly? I would have thought the jillions of dollars Toyota spent replacing Tacoma frames due to significant rust issues several years ago might have them step up their manufacturing game and begin employing some of the anti corrosion technologies that have been developed over the last 20+ years.
    Thanks for the pic. I'm getting mine greased up at my 1K synthetic oil change in a couple of weeks.
    TimG
    Trail Runnah likes this.
  22. May 13, 2024 at 6:48 PM
    TrailSpecial22 New Member
    PA
    Agreed lube them up
  23. May 13, 2024 at 6:56 PM
    PA
    agreed
    take the time to notice how poorly tires are wearing before its to late. Ugh.
  24. May 13, 2024 at 7:00 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    That I did not do. But in all fairness, my factory tires have all worn like crap, I always figured it was just crap factory tires.
  25. May 13, 2024 at 7:11 PM
    PA
    Dudlops?
  26. May 14, 2024 at 6:44 AM
    Spare Parts
    Southern Maine
    22 LR ORP
    I don’t remember what ones were on the RAV4, but on the Taco that’s what’s was on it. At 30k, those were complete junk as well.
  27. May 14, 2024 at 9:00 AM
    totmacher
    totmacher New Member
    Daniel
    West TN
    2018 SR5 Nautical Blue
    done some stuff to it
    It's not as precise as people like to act. Do it one bolt at a time, put it back lined up to your marks, and it's good enough.
  28. May 14, 2024 at 10:34 AM
    Anyone know the torque value for these bolts off the top of your head? And, do they need to be torqued with the vehicle wheels/tires on the ground?
    djwantke likes this.
  29. May 14, 2024 at 11:29 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    100% my cam bolts are going to F me around when I have to cross this bridge.
    My cam bolts:
  30. May 14, 2024 at 3:10 PM
    PA
