Help with tires and apologies ahead
Discussion in '5th Gen 4Runners (2010-2024)' started by HyperX, May 9, 2024.
  1. May 9, 2024 at 6:27 AM
    HyperX
    HyperX [OP] New Member
    Dan
    2024 4runner TRD off road premium
    none yet
    I have searched this forum and I am getting conflicting infos on certain brands, sizes and rubbing.
    I bought a brand new 2024 ORP 4Runner. I love cooper discoverer XLT tires as that is what I had on my 2019 Silverado HD (incredible in rain and snow). I want to run the same on the 4runner, but I noticed they only have the Discoverer LTs not the XLTs in the size I need.
    Hence this is the question. Can I run 275/17/70 Cooper Discoverer LTs tires on my stock 4runner without any lifts or trimming? Or should I stick to stock?
    Pic of 4runner :)
  2. May 9, 2024 at 6:33 AM
    You can go all the way up to 285's without rubbing or trimming. I swapped out my factory Dunlop's the DAY I bought my SloRunner with Falken Wildpeaks. I chose the exact same size, but they do rub when I reverse and turn the wheel all the way to the right. It only happens if I turn right. Never left, and never if I'm going forward to the right.
    Anywho.. Here are before/after pictures:
    glwood54 likes this.
  3. May 9, 2024 at 6:46 AM
    Same tires/size here, no rubbing at all. FYI, I only see the after pic.
    Edit: before pic now shows up...
  4. May 9, 2024 at 7:28 AM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    a few goodies
    @Borracho Loco: That is a very good looking truck! With the color and the 40th Anniversary accents - very nice! :hattip:
    Borracho Loco likes this.
  5. May 9, 2024 at 10:19 AM
    kmeeg LionRunner
    I ran BFG KO2 275/70R17 on stock suspension + stock TRD ORP wheels. But OP seems to have TRD Pro wheels, due to their offset I think 275/70R17 tires would rub.
    I switched 275/70R17 Load E to 285/70R17 Load C (with a lift and minor trimming) in a very short time as I found Load E tires are too firm for my & my family taste.
  6. May 9, 2024 at 12:35 PM
    HyperX
    Dan
    none yet
    This is what I am afraid of.. I do not want rubbing... I guess sticking to stock size is prob a safe bet.. especially since the 275s are like 1/2 inch bigger... I am just looking for that beefy tire so when I go to my farm I do not worry about getting stuck.. worried these street looking tires will get me in trouble especially in mud.
  7. May 9, 2024 at 12:40 PM
    java
    java fauxrunner
    2023 ORP ice cap
    255/80/17?
  8. May 9, 2024 at 12:43 PM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Elka 2.5, Apache Offroad UCA, durobumps, RCI full skids, RSG sliders, 10 lb Powertank, Maxtrax, Hi lift jack, Westscott Designs modular roof rack and ladder, ARB rear diff breather relocate, ECGS bushing upgrade, c4 low profile bumper, Baja designs S8 lightbar, warn evo winch, factor 55 ultrahook
    Get a good AT tire replacing the stock. You don't have to upsize to fix the street tire problem. Look at the Mickey Thompson Baja Boss. Lots of great reviews on that both on and off road.
    Keeping the weight down on the tire and getting a load rating that works for you is important.
    kmeeg and ThatOneGuy like this.
  9. May 9, 2024 at 1:59 PM
    HyperX
    Dan
    none yet
    OOh that was not even on my radar as an option.. will 255s fit without rubbing? they are 2 inches taller I see... but skinnier by half inch..
  10. May 9, 2024 at 2:14 PM
    2021venture
    Todd
    2021 Venture
  11. May 9, 2024 at 2:41 PM
    kmeeg LionRunner
    Don't forget the Load Rating. 255/80R17 only comes with Load E.
    Before I got 275/70R17 Load E I had 265/70R17 Load C. While I was driving off the tire shop with Load Es back of my head said "did I make a bad decision? The ride is rough even with stock soft suspension". Few days later I regret when my wife really dislike the ride.
    If you have a tire shop who can accept a return if you don't like the tires that would be great. ​
    Also maybe to think availability and no of options.
    For example if you search 255/80R17 in discount tire you have 16 tire options vs if you search 265/70R17 you have 163 tire options and also sub divide to 4 Load Ratings. Similar story for 285/70R17 -
    VS
    OR
  12. May 9, 2024 at 3:27 PM
    java
    java fauxrunner
    2023 ORP ice cap
    I am thinking of getting them after some threads suggested no rubbing, worth consideration. And Im liking the look.
  13. May 9, 2024 at 3:47 PM
    HyperX
    Dan
    none yet
    Thank you for the detailed post with pics. I definiately want the coopers discover AT3s. I ran coopers on all my trucks and SUVs and love them. Never thought about ride comfort with different loads. I assume my stock 2024 tires are load C then? What does the TRD Pro come with, also load C?
  14. May 9, 2024 at 3:53 PM
    kmeeg LionRunner
    No, TRD Pro come with Standard Load P265/70R17
  15. May 9, 2024 at 3:55 PM
    Noodles
    Noodles New Member
    Didn’t read OP’s post. Did he ask about optional sizes and if it’s going to rub? :D
  16. May 9, 2024 at 4:25 PM
    jeepster09
    jeepster09 New Member
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    Well I decided to go with Cooper STMAXX in 235/80R17 [9" x 31.8 vs 10.7 x 31.85] tires since I had same type and size on my Jeep Grand Cherokee and was very happy with them. Being narrower, but same height they look great, ride great and have improved gas mileage some. I have actually been averaging 21 mpg. Absolutely no rubbing.
  17. May 9, 2024 at 8:00 PM
    HazOpRed
    HazOpRed 22' TRDOR
    You will rub with 275/70r17 depending on your alignment. I run those in Falkens. If you push them all the way forward, you will need to trim a teeny bit of the bumper lip. A happy medium spot in the alignment might exist, but a dremel is faster
    Noodles likes this.
  18. May 10, 2024 at 3:29 AM
    Noodles
    Noodles New Member
    Why can’t you use the stock size? If it’s a new vehicle this problem doesn’t even exist yet. Maybe after 40-50k miles when you wear out these tires.
  19. May 10, 2024 at 5:20 AM
    Shanky
    Shanky New Member
    Im happy with the 275 /55 17’s Ko2s. A shade over 32” and no rub on OR wheels in any situation.
  20. May 10, 2024 at 6:55 AM
    HyperX
    Dan
    none yet
    I like the look of the beefy Coopers is why. It will match all my other trucks too. Plus I own a farm 390 miles from my home, the coopers have no drone on the highway and they look and act beefy. The farm is 200 acres and has a bunch of trails full of mud and such and I am worried the stock tires will get my 4runner stuck. Case in point, my buddy came to visit me in a brand new Range Rover that had street tires and he got stuck. I guess I could just get the original size and be done with it and not worried about rubbing, etc.
  21. May 10, 2024 at 7:35 AM
    Noodles
    Noodles New Member
    Makes perfect sense. Good quality tires can make you or break you on rough terrain. 200 acres sounds amazing.
  22. May 10, 2024 at 7:54 AM
    HyperX
    Dan
    none yet
  23. May 10, 2024 at 10:20 AM
    Manhattan
    Manhattan New Member
    I need to see these 235/80/17s. We need pics!
  24. May 10, 2024 at 12:26 PM
    jeepster09
    Twin Cities MN
    4Runner 2008 Sport
