Going to Test Drive - What to look for?
Discussion in '5th Gen 4Runners (2010-2024)' started by tacomaccountant, May 9, 2024.
  1. May 9, 2024 at 6:33 AM
    tacomaccountant
    tacomaccountant [OP] New Member
    Josh
    Florida
    Hey Everyone,
    This is my first post here. I was fairly active over on tacomaworld for a while when I had my 3rd gen Tacoma. I'll save the details for my post in new members but I wanted to go ahead and get this one going.
    I am going to test drive a 21 TRD Off Road premium tomorrow. It has a little over 40k miles. Is there anything specific (problems, features some have and some dont, etc) that you would recommend looking for or asking about?
    thanks
  2. May 9, 2024 at 6:38 AM
    Make sure you get at least 28 smiles per gallon while driving it. If you don't, then don't buy it. Other than that, because it's only got 40k on the clock, check for basic stuff. Make sure recent servicing was done. Check how long the tires have left. If you're in the rust belt area, check the frame.
    Jere39, BearBio and Schlappesepple like this.
  3. May 9, 2024 at 6:39 AM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Check the frame even if you're not in the rust belt, dealers move these things around. Aside from that, normal used car stuff.
    TimGinCentralNJ and BearBio like this.
  4. May 9, 2024 at 6:50 AM
    ColoradoTJ
    ColoradoTJ I drink...and I know things. Staff Member
    Chris
    With bigger purchases I usually elect to take the vehicle to a third party inspection center.
    I have seen motors that were shot under 20k miles. Definitely worth the 150-300.00. When I helped out a buddy for about 6 years in a diesel repair facility, a Dodge 5.9L Cummins came in with 10k on the odometer with a dead cylinder due to a failed injector. We pulled the motor and built him up a nice 500 HP street/tow rig for around 14k. Had he just went stock it would have been around 8400.00. A simple 3rd party inspection would have found this issue before purchase and he could have avoided this all together.
    I would also check on service records and see if they used Toyota Care. 10k oil changes are no bueno in my book.
  5. May 9, 2024 at 8:00 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Make sure the steering wheel shakes at 60???? haha!!! Good luck hope it works out for you!
    ColoradoTJ and Acesandeights like this.
  6. May 9, 2024 at 8:25 AM
    ColoradoTJ
    Chris
    :yes:
    I see what you did there.
  7. May 9, 2024 at 8:26 AM
    Lc200
    Lc200 Member
    Pre Facelift SR5P
    Take it on the highway and if it sways, vibrates or hums, you ve got yourself a keeper.
    java and Guppy1301 like this.
  8. May 9, 2024 at 11:42 AM
    scanny
    scanny New Member
    Ontario, Canada
    make sure 4x4 works, it has to be used every month for at least 10 miles to keep it lubricated. It might fail if previous owner never used it.
  9. May 9, 2024 at 2:27 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar *coming soon Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets Suspension: Dobinsons IMS long travel kit (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken AT4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. MinWin End Caps Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered, coming soon Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Performance: Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Garmin Dash Cam Mini II with Dongar power solution Ram ball mount for Garmin In-Touch Mini II Scosche phone mount Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised 27W Ditch Lights OVS Nomadic Awning 6.5' AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Normal used car stuff.
    -Maintenance records check out.
    -Look for excessive corrosion.
    -Check carfax for reported accidents.
    -Oil looks good on the dipstick. No metal shavings. No milkshake looking substance.
    -Check the 4x4 system (4Hi and 4Lo). Be mindful of turning very tightly on a paved surface whilst in 4WD. That should be avoided.
    It's a 4Runner. All that will likely be fine. They're not indestructible but they are definitely hard to kill.
    There are some mobile mechanics or third party services that can do an in depth inspection if that's worth it to you. They should:
    -Check fluids
    -Check the electrical system
    -Scan the car's computer for any fault codes
    -Check suspension bushings and wheel bearings
    -Evidence of prior unreported collisions/ accidents
    steelevo, scanny and RumHamRunner73 like this.
  10. May 10, 2024 at 9:12 AM
    tacomaccountant
    Josh
    Florida
    I bought it! I wound up test driving yesterday afternoon. It's been raining a ton so I haven't had a chance to take my own pictures yet. This is from the dealer site. 21 TRD Off Road Premium (Toyota Certified Pre Owned) with 44.9k miles on it. Really happy with it.
    Guppy1301, Jere39, garoto and 7 others like this.
  11. May 10, 2024 at 9:15 AM
    1SilverRunner
    Tejas
    Congrats! Love the color :cool:
  12. May 10, 2024 at 9:21 AM
    jwctaco
    jwctaco Retired
    S.W. Michigan
    23’ T4R
    Congratulations, enjoy
  13. May 10, 2024 at 9:29 AM
    HighSierraGuy
    HighSierraGuy New Member
    Congrats! Silver is the best
    Guppy1301 likes this.
  14. May 10, 2024 at 10:38 AM
    TimGinCentralNJ
    TimGinCentralNJ New Member
    Tim
    '24 Limited in Classic Silver
    TRD Pro rims w/265/70-17 Toyo OC AT3s
    Congrats on the new rig and welcome to the group :)
    TimG
  15. May 10, 2024 at 10:55 AM
    94hokie
    94hokie New Member
    23 TRD ORP Lunar Rock
    My '13 was Silver, that color easily hides dirt the best. Congrats.
    Stoney Ranger likes this.
  16. May 10, 2024 at 11:05 AM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Make sure you are not paying a cent over $30k, 2024s are going for $46k
  17. May 10, 2024 at 11:14 AM
    steelevo
    Utah
  18. May 10, 2024 at 11:55 AM
    Fortuner
    Fortuner New Member
    CA
    2021 4Runner TRD Off Road Premium w/KDSS
    Congrats!
    At that mileage, make sure the Front/Rear diff fluids were serviced. Also, get out there and enjoy the vehicle before the "mod-bug" bites. Haha.
