Do I need different upper control arms?
Discussion in '5th Gen 4Runners (2010-2024)' started by Fpesc, Apr 25, 2024.
  1. Apr 25, 2024 at 2:12 AM
    Fpesc
    Fpesc [OP] New Member
    Frank
    2021 Off Road Premium
    I have a 2021 4Runner ORP. I am going to put on 285/70/17s with the Billstien 6112 Strut & Spring Assembled + Rear B8 5100 Shocks Set. Do I need to buy different upper control arms or will there be enough space for the OEM ones. I intend to lift the front 2.5in.
  2. Apr 25, 2024 at 3:16 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    I'm running basically the same set up. I'm about 2" (clips 6 and 4) on my 6112's. I went with Old Man Emu UCA's. Greaseable and quiet. Very happy with them. Post up pics when you're done.
  3. Apr 25, 2024 at 4:24 AM
    TrailSpecial22 New Member
    PA
    my OEM UCAs were fine, but each may vary
  4. Apr 25, 2024 at 6:28 AM
  5. Apr 25, 2024 at 6:31 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    You probably don't NEED them but you'll benefit from having them.
    TRDSD and 1SilverRunner like this.
  6. Apr 25, 2024 at 6:52 AM
    HuskyMike
    HuskyMike New Member
    I have basically the same setup (2" up front) with OEM UCAs. No issues, although I have yet to get it aligned since I installed them.
    What are you referring to when you say "enough space"?
  7. Apr 25, 2024 at 8:54 AM
    Fpesc
    Frank
    When is say enough space, I mean to function properly and not hit the tire. I painted the OEM rims black (did it myself and came out great!), so I will be using that rim with the original offset.
  8. Apr 25, 2024 at 10:44 AM
    Acesandeights
    Acesandeights Newbie - always learning
    So Oregon
    1938 4Runner
    I don't think most of that is true.
  9. Apr 25, 2024 at 12:46 PM
    Acesandeights
    So Oregon
    1938 4Runner
    Changes in caster can cause the wheel to lose clearance as it moves it closer to the front or tear of the fender.
    Factory upper control arms are not the limiting factor for front end articulation.
  10. Apr 25, 2024 at 1:10 PM
    TRDSD
    TRDSD New Member
    2019 TRD Off Road Premium
    So the ability to move/adjust the wheel a bit more fore or aft isn't helpful if you're rubbing/clearing bigger tires? :confused:
    So potentially limiting a shock's down travel doesn't help with / isn't a function of articulation? :confused:
  11. Apr 25, 2024 at 1:25 PM
    Acesandeights
    So Oregon
    1938 4Runner
    If the factory control arms aren't the limiting factor, then no.
    I bet you have a guitar amp that goes to 11.
  12. Apr 25, 2024 at 1:42 PM
    TRDSD
    TRDSD New Member
    I’d normally say welcome to a new member, but I usually save that for people with an IQ > 75. Enjoy your time here.
  13. Apr 25, 2024 at 2:36 PM
    Acesandeights
    So Oregon
    1938 4Runner
    I don't know what that means. Hope that helps indeed.
  14. Apr 25, 2024 at 2:41 PM
    nova
    nova New Member
    mike
    Soon Arizona
    slightly modified LE
  15. Apr 25, 2024 at 2:47 PM
    Acesandeights
    So Oregon
    1938 4Runner
  16. Apr 25, 2024 at 3:45 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    You may not know until it is all installed. Will ultimately determine if you have rubbing or alignment issues afterwards.
  17. Apr 25, 2024 at 4:01 PM
    Vito Corleone
    Vito Corleone New Member
    Georgia
    2022 4Runner ORP
    Current Mods: 3/2 Lift Kit w/Billstein 5100’s SPC Front Upper Control Arms 285/70/17 Michelin Defender LTX TRD Pro Wheels TRD Pro Grill 20% Tint on Windows & Sunroof Pedal Commander Cold Air Kit LED Front Turn Signals Brite-Box Anytime Foglight Kit “Tail as Turn” Rear Turn Signal Kit LED Reverse Lights LED Tag Lights LED Puddle Light Pods Sequential Turn Signals N-Fab 3” Step Bars Future Mods: In-Car Camera System Rear Molle Panel Storage System Magnuson Supercharger (when available)
    I went with replacing the upper control arms. This eliminated any tire scrubbing and the need to chop the body mount. I went with 3” in the front and 2” in the rear with 285/70/17 on TRD Pro wheels. It sits perfectly level.
    Rott4r likes this.
  18. Apr 25, 2024 at 6:47 PM
    Rott4r
    Rott4r New Member
    23 MGM 4Runner TRD orp kdss
    If planning on changing them later down the road, might as well get uca and install everything at once, especially if you can find the uca you want on sale. I got uca for alignment purposes. I did notice my steering felt a little tighter after installing them, which is a plus for me
    Vito Corleone likes this.
  19. Apr 25, 2024 at 7:26 PM
    Rott4r
    Rott4r New Member
    Clean setup, it does sit nice and leveled is the 285s on at the time of this picture?
  20. Apr 25, 2024 at 10:13 PM
    telog
    telog New Member
    TL
    CO
    2020 TRD Pro army green
    I agree with Vito. I have a pro. Added eibach springs over fox shocks with 285s. trimmed fenders back and no body chop. I do a lot of off road and no tire rub. I took off the fox uca and put on dobinsons adjustable UCA’s and it a made a world of difference. Not sure what your use is, but the ease of adjustment makes it easy.
  21. Apr 26, 2024 at 7:54 AM
    HazOpRed
    HazOpRed 22' TRDOR
    Short answer is no, just keep your $$$
    Acesandeights likes this.
  22. Apr 26, 2024 at 9:15 PM
    Vito Corleone
    Georgia
    2022 4Runner ORP
    Yes, this picture is with the 285s.
  23. Apr 27, 2024 at 10:52 AM
    Stock UCAs won’t limit articulation as long as the shocks installed are not long travel.
    However, if you use huge tophat spacers to lift the front (instead of a shock/coil lift), you may possibly reach the angle limit of the stock UCA. Which is very bad. That’s the big reason top-hat spacers aren’t recommended if you off-road.
    But any aftermarket coil/shock lift with standard range travel will have no problem with the stock UCAs, The shock is always what’s in charge of limiting down travel.
    While a lot of people get aftermarket UCAs to allow for additional caster angle, it can be the cause of rubbing at the body mount (where there wouldn’t have been any with stock UCAs). That’s because to get that additional caster, aftermarket UCAs move the top of the tire backwards, closer to the body mount).
    So if you can live with lower caster angles, stock UCAs is probably the best bet in terms of durability, quietness, and being maintenance free.
    nova and Acesandeights like this.
