Toytec Boss 2.0 Aluma Series Coilover Catastrophic Failure-Safety Warning!
Discussion in 'Suspension' started by Motohead, Aug 15, 2023.
  1. Aug 15, 2023 at 5:42 PM
    Motohead
    Motohead [OP] New Member
    Warning concerning Toytec Boss 2.0 Aluma Series Coilovers! These pictures are from my 2006 Tundra dbl cab. The coilovers are less than two years old and have never been abused. 97% pavement and about 3% gravel roads. Toytec would not open an investigation and didn't even want to see the broken parts. There should be a recall. I would remove them from my truck immediately if you have them! Broke while driving 20mph(thank god!) on the pavement.
    HuskyMike likes this.
  2. Aug 16, 2023 at 6:19 AM
    blksubykid
    blksubykid New Member
    sheesh. glad everyone is ok at least. I know the 2.5s are actually made by Elka for Toytec, so I would assume the same for the 2.0s but not 100% on that
    nimby likes this.
  3. Aug 16, 2023 at 6:24 AM
    Motohead
    Yes, very scary. We had just finished driving up the Million dollar highway when it broke in Silverton, Co. Brake caliper and driveshaft were destroyed.
  4. Aug 16, 2023 at 6:35 AM
    I would contact Elka to see what they say.
  5. Aug 16, 2023 at 2:26 PM
    Motohead
    I sent an email to Elka two days ago, no response yet. Thanks for the suggestion.
    nimby likes this.
  6. Aug 16, 2023 at 3:54 PM
    TrailSpecial22 New Member
    PA
    mother of god!! I smell a law suit.
  7. Aug 16, 2023 at 4:18 PM
    Are you sure you weren't trying to do this?
    Higgbra73, MeefZah and 2Toys like this.
  8. Aug 16, 2023 at 4:22 PM
    Motohead
    Ha, you would think so! Nope, we do hike a lot of 14nrs out here in Colorado so drive some 4x4 rds to trailheads but haven't had it airborne yet.
    nimby likes this.
  9. Sep 17, 2023 at 10:41 PM
    Any news from Elka? Also, I assume you meant axle shaft, not driveshaft...
  10. Sep 18, 2023 at 6:25 AM
    Motohead
    Elka has been silent. Yes, I meant the axle shaft.
  11. Sep 18, 2023 at 6:30 AM
    kmeeg LionRunner
    I wonder if you give a call to Hugo at R4T in Denver CO and see if he can give a friendly/free advice what to do in this situation? He would know how warranty works for Toytec products.
  12. Sep 18, 2023 at 6:43 AM
    Motohead
    Ive spoken directly with the manager at Toytec. They did comp a set of lessor Ulitma coilovers which i don't like performance wise. The real sad part is that they didn't want to open an investigation with Elka or even see the broken parts which I offered to drop off. They are claiming to have never heard of this before which is crazy.
  13. Sep 20, 2023 at 8:48 PM
    Larpy
    Larpy New Member
    I just had the same issue on my 18 4Runner! They were installed 45,000 miles ago and my driver side front coilover broke in the same exact spot. I was driving on a smooth dirt road when it broke. My truck has no trail hustory. When I removed both the passenger and driver sides the bushings in both were trashed. I was told that the life expectancy for these are only 4 years by Toytec! A horrible product!Resized_20230920_192508.jpgResized_20230920_184920.jpg Resized_20230920_184857.jpg Resized_20230920_184857.jpg Resized_20230920_184920.jpg Resized_20230920_192525.jpg Resized_20230920_192508.jpg
  14. Sep 20, 2023 at 9:54 PM
    4R777
    4R777 New Member
    Wow. Thanks for the heads up on ToyTec.
    I wonder if they're all bad, or maybe just a bad batch of raw materials from the supply side.
    Surprised they won't immediately look into this. Maybe they are too afraid of the results and hope to fix the problem quietly.
  15. Sep 21, 2023 at 4:17 AM
    PA
    i would never buy Toytec again if that happened to me. Yikes!
  16. Sep 21, 2023 at 6:58 AM
    4R777
    4R777 New Member
    Agree. Because of this thread, I've already counted them out for potential future upgrades to my upcoming 6th gen rig.
  17. Sep 21, 2023 at 7:52 AM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    I’ve already decided against them on this basis.
    Bilstein, OME, or Eibach have too much at stake to Mickey Mouse it like they are.
  18. Sep 21, 2023 at 11:03 AM
    Hyrule_trd
    Hyrule_trd New Member
    Eric
    MD
    2020 Tacoma
    Ironman Foam Cell Pro, MESO stuff, other things I can’t remember
    That’s pretty crazy. You can see that it had a crack or pitting going on for a while. You can see the 3 different parts of the failure, red where there was the initial crack or corrosion pit, can see that it is dirty. Then the next part in yellow, can’t remember the term and final the blue which is when the force was too much and the rest fractured.
    I’ll try and look up the names of it but you can see similar things when the NTSB investigates accidents.
  19. Sep 21, 2023 at 2:25 PM
    PA
    agreed, thst why I ran Bilstein on my 3, 4runners
    Higgbra73 and bassist[QUOTED] like this.
  20. Sep 21, 2023 at 2:42 PM
    3JOH22A Toyota Gigolo
    The destroyed bearing is a known issue with Elkas. Buddy in my off-road club had it happen to him, gouged the end fitting too. Had to have the shaft replaced because Elka changed the end fitting design (wonder why? :rolleyes: ), and the old shaft didn't fit the new end fitting. Now he replaces the bearings on his Elkas every second oil change as preventative maintenance.
  21. Sep 21, 2023 at 2:44 PM
    PA
    Too much work imo
  22. Sep 21, 2023 at 3:35 PM
    Larpy
    Larpy New Member
    They are a garbage product! I will never purchase Toytec again. A waste of money.
  23. Apr 30, 2024 at 7:58 AM
    Beowulf
    Beowulf New Member
    Sadly, this just happened to me on my GX460. Luckily, I was only going a few mph turning into a parking area and slowly limped to a parking spot. Looks like it destroyed my CV boot. Hopefully nothing else.
    It is trapped between the CV and the tie rod. I'm hoping that after work, I can just removed the tie rod, slide this out, and limp home (2miles) on the bump stop.
    I really hope since I only drove a few hundreds yards after it happened, that only the CV boot is damaged and not the whole assembly.
    I don't need anything fancy. Think I'll just use the OME basic lift. I'll need to add the top hat, but honestly, I fell this will ride better. Never liked the Toytec ride. Plus, it clanked all the time. Bushings suck.
    https://mudify.com/products/omegx-1022-2-ass
