LFD Cross Bars and Awning Mounting
Discussion in '5th Gen 4Runners (2010-2024)' started by 1SilverRunner, Apr 30, 2024.
  1. Apr 30, 2024 at 11:32 AM
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar *coming soon Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets Suspension: Dobinsons IMS long travel kit (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken AT4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. MinWin End Caps Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered, coming soon Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Performance: Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Garmin Dash Cam Mini II with Dongar power solution Ram ball mount for Garmin In-Touch Mini II Scosche phone mount Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised 27W Ditch Lights OVS Nomadic Awning 6.5' AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    TLDR: Anyone have LFD cross bars that they've mounted an awning to?
    I'm planning to mount an OVS 6.5' straight pull awning to these cross bars. Trying to keep this setup as low profile as possible.
    I will likely fabricate some brackets since LFD's awning mounts are $75 after shipping.
    [​IMG][​IMG]
    https://lfdoffroad.com/products/universal-awning-mount
    The awning was pretty inexpensive at $180 at caliraised:
    https://caliraisedled.com/products/...hhVAZJDIrAK3QoYEPabecewwrIgp37rBoCW7gQAvD_BwE
    The goal is to mount the awning as low as possible while still allowing the doors to open of course. About 4" lower than this setup would be ideal:
    377553d1614187376-lfd-off-road-thread-ir_a28164d28169f20dff1e583340d2799a20688c98.jpg
    Fortuner likes this.
  2. Apr 30, 2024 at 12:17 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    '24 ORP
    I don't have any notes on installing to LFD crossbars as I went "up and out" on a set on Inno crossbars; but I don't think I'd want to go any lower on the roof - otherwise you wouldn't be able to stand under the awning up close to the truck, unless you are super short.
  3. Apr 30, 2024 at 12:27 PM
    1SilverRunner
    Tejas
    Yes I believe this why most mounts locate the awning higher. In my case however It can be low profile. After a 3.5" lift and 34's my truck is much taller than I am at 6'1"
    The awning mount being just above the doors would work well for me. Can't seem to find any simple solutions apart from the LFD mounts. They are not a terrible deal but I haven't found any published data from OVS on their awning's mount dimensions. So buying brackets just to end up having to modify or fabricate my own seems like a waste of time and money.
    Figured I'd reach out and see if anyone has found a low profile mount that works with the LFD crossbars and OVS awning.
    MeefZah[QUOTED] likes this.
  4. Apr 30, 2024 at 12:33 PM
    1SilverRunner
    Tejas
    This would be about the height I'm looking for.
    Image pulled from RCI's website. It's their low profile awning mounts for a prinsu rack
  5. Apr 30, 2024 at 4:59 PM
    MeefZah
    Lexington, Ohio
    '24 ORP
    If you end up building your own probably install a gusset like my ARB ones pictured below. It appears from your image in post 1 that the LFD ones are ungusseted...? I am no engineer but I think there's a weird amount of stress placed on those mounts since the awning is held away from them and tends to flop around a lot offroad (not the aluminum spine of the awning as that's solid to the mounts, but the fabric of the awning and the internal poles and such heave up and down and probably stress the bracket) .
    I don't know if the ARB ones would work for you but they are a pretty good deal at $15 each; damn well made for that price.
    https://www.northridge4x4.com/part/...QlEAsFy61fM63OxFb6W6RZ5P8S8enLVBoCQJkQAvD_BwE
    1SilverRunner[OP] likes this.
  6. Apr 30, 2024 at 8:28 PM
    1SilverRunner
    Tejas
    Nice product link those might work just fine. Good price too.
    Once I get the awning in I’ll take some measurements and decide which of these will work best.
    Thanks
  7. May 17, 2024 at 5:23 PM
    1SilverRunner
    Tejas
    Ended up buying some mounts.
    LFD mounts worked to locate the awning exactly where I wanted it. Unfortunately as you @MeefZah warned they do sag just a bit… I may weld in some angle iron and some small gussets.
    I’ll update this thread if I get around to that
    MeefZah likes this.
  8. May 17, 2024 at 6:08 PM
    MeefZah
    Lexington, Ohio
    '24 ORP
    Man that is right at the top of your door!
