2024 Limited - how to install OEM mud flaps
Discussion in 'New Member Introductions' started by sanjosekimchi, Mar 1, 2024.
  1. Mar 1, 2024 at 8:11 AM
    sanjosekimchi
    sanjosekimchi [OP] New Member
    Hello 4Runner community!
    We just purchased the 2024 limited. I'm trying to install the OEM mud flaps but the screw holes on the flaps don't seem to align with the holes in the wheel well. I've checked with the parts department via vin # and they've confirmed it's the correct part.
    Does anyone have any advice on this?
    Thank you
  2. Mar 1, 2024 at 11:08 AM
    DesertSurfer
    DesertSurfer New Member
    Welcome to the forum from San Diego!
  3. Mar 1, 2024 at 1:48 PM
    Georgetown, TX
    welcome
  4. Mar 1, 2024 at 3:10 PM
    steelevo
    Utah
    Welcome. They should fit, as long as they’re for a limited and not the other trims.
  5. Mar 2, 2024 at 9:11 AM
    Curlystooge
    Curlystooge Member
    2022 limited in magnetic grey
    Welcome. I am interested to know what your resolution was. I had ordered an OEM set from Amazon that would not fit. I sent them back and have not tried further.
  6. Mar 2, 2024 at 10:43 AM
    sanjosekimchi
    Hi Curly,
    I'm working on it today and will post pictures when I'm done. I double checked with the parts department at my local Toyota dealer and they confirmed the oem mud flaps require that I drill a few additional holes into the plastic fender. I have the printed instructions directly from Toyota which also state the same. Kind of silly given there are exiting holes not being utilized. Stay tuned.
    ThatOneGuy and Curlystooge like this.
  7. Mar 2, 2024 at 12:28 PM
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
    You'd think OEM mud flaps would be no-drill, since like you said, there is existing hardware than can be used. These are the ones I got off Amazon, no-drill, fit perfectly. My '23 Limited does not have running boards or fender flares, so this is the kit I used:
    Amazon.com: YHTAUTO Mud Flaps Splash Guards w/Hardware Kit Replacement for 2010-2023 Toyota 4Runner Without Running Board and Fender Flares| Not Fit Any Ground Effects : Automotive
  8. Mar 3, 2024 at 2:18 PM
    sanjosekimchi
    UPDATE: I was able to get the OEM mud flaps installed in about 45 mins (I worked slowly and deliberately).
    Part #: PT769-89110
    Instructions: 2012 - (attached file)
    Some helpful hints:
    1. Be very careful about positioning the spring clips that are screwed into. If you're off center even just a little bit, the screws will not catch or will go in at an angle which isn't good.
    2. Have the correct tools. You'll need an angle screw driver for the back wheels as you can't turn them like the front wheels (see picture).
    3. You'll end up removing and re-attaching a small, existing flap on top of the new mud flap (only on the front flaps. this is really silly, come on Toyota!). Honestly, this should just be one part. :(
    Overall, I'm happy with the mud flaps; however, in the future I'd go with a simpler after-market product which didn't require me to drill new holes into the plastic panel (as mentioned by Bronzestar).
    Bea60 and Fu3lC3ll like this.
  9. Mar 3, 2024 at 5:15 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Looks great! Glad you got it on
    Btw, Welcome
  10. Mar 4, 2024 at 2:54 AM
    Welcome from Wisconsin!
  11. Mar 4, 2024 at 5:46 AM
    Ironguy New Member
  12. Apr 30, 2024 at 12:33 PM
    roverguy
    roverguy New Member
  13. May 1, 2024 at 7:48 PM
    Bea60
    Bea60 New Member
    Bety
    2024 Toyota 4Runner
    None
    Hello,
    New to the site, sorta having issues figuring out how to ask someone a question. I see sanjosekimchi has the same mud flaps as I have. My question is the bottom screw. My truck looks like it has a rivet there. Does that get removed or is there hardware that screws to the center of it. The direction don’t mention anything about a rivet. It just stated to add a
    Screw in that area. So I am a little confused. The rear mud flaps were a breeze to install. Any info is appreciated. Thanks everyone.
  14. May 2, 2024 at 6:25 AM
    Ironguy New Member
    Welcome from Arizona.
    You might just need to punch a new hole. It's only rubberized plastic.
  15. May 4, 2024 at 8:20 AM
    Bea60
    Bea60 New Member
    Bety
    2024 Toyota 4Runner
    None
    Thank you,
    I will take another look. It’s going to have to wait now since I had shoulder surgery on Thursday. I was trying to get them installed before that….but the fronts were a little bit more tricky. I appreciate any info.
