2018 Toyota 4Runner 4WD LTD - clunking sound in 4WD with hard turns
Discussion in 'Suspension' started by Felski77, Apr 30, 2024.
  1. Apr 30, 2024 at 12:44 PM
    Felski77
    Felski77 [OP] New Member
    2018 Toyota 4Runner LTD
    My 2018 4runner LTD has around 43K miles and the front end clunks when making hard right turns in 4WD. Is this related to tie rods or CV? It also makes a soft squeak/wheeze sound when going over bumps slowly (like out of your driveway). Seems like a suspension problem but not sure what this vehicle has up front.
    Thanks in advance for your ideas!
  2. Apr 30, 2024 at 1:01 PM
    icebear Recovering Kia Owner
    When you say “in 4WD” are you in H4F or H4L at the time of clunking?
  3. Apr 30, 2024 at 1:10 PM
    Felski77
    Great question. H4F
  4. Apr 30, 2024 at 1:20 PM
    Crikeymike
    Crikeymike Exit Offroad, Dobinsons Specialist Vendor
    Jax Beach, FL
    2014 4Runner w/Dobinsons MRA Suspension, Shrockworks bumper/sliders
    And you can't get it to make the noise in 2WD?
    Loose sway bar links and loose alignment cams are normally the cause of a clunk in the front, but if those have never been messed with, those shouldn't be making any noise.
    If the suspension is not OE, then it's probably something to do with that
  5. Apr 30, 2024 at 1:44 PM
    Being a 5th gen Limited, it's permanently in 4WD, the only options are to lock the center and shift into low range.
    If it's turning related like it sounds, I'd check the CVs to start.
  6. May 1, 2024 at 8:13 AM
    Felski77
    @icebear that's what I was thinking. Thanks!
