“Limp Mode” help
Discussion in '5th Gen 4Runners (2010-2024)' started by sherwood4runner, Apr 13, 2023.
  1. Apr 13, 2023 at 8:41 AM
    sherwood4runner
    sherwood4runner [OP] New Member
    2018 4Runner OFP
    Icon Stage 2 w/ SPC UCA, Spidertrax wheel spacer, Magnaflo exhaust, K&N CAI, Xenon Depot Full LED upgrade, Pedal Commander, Ridge Grappler 285x70x17, SCS Ray 10 Matte Gunmetal 17x8.5 w/-10mm offset, Full tint, Husky Liner floor and cargo mat, Morimoto XB headlights, Depo taillights, Diode Dynamic SS3 SAE Fog Lights
    Was driving 2018 4Runner ORP down the freeway and check engine light, multi terrain error and a few others came on and lost power. Couldn’t go over 25 MPH. Towed to dealership and this is what they said needs to be done. I have/had a pedal commander and removed it when this happened. Any experience with this????
  2. Apr 13, 2023 at 8:58 AM
    Do you have any input into what the dealer says happened to the air injection control pump (water intrusion)?
  3. Apr 13, 2023 at 9:04 AM
    sherwood4runner
    2018 4Runner OFP
    They said water got in a caused corrosion. The advisor wasn’t sure how it got in. I’m not very educated in these things.
  4. Apr 13, 2023 at 9:27 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    So you may actually have an air injection issue.
    But, when I installed Pedal Commander, by the book, it tripped my ecu. I was told this will happen twice, then never again, turned out to be true. Did a hard reset disconnecting the battery and all that. Then, as predicted by members here from experience, it happened again month or two later while driving and the dash lit up like that and went into limp mode. I did the same ecu reset, reinstalled PC by the book, smooth sailing ever since. Good luck
    glwood54 and 08TXRunner like this.
  5. Apr 13, 2023 at 2:59 PM
    You're braver than I. I would have boxed up the PC and sent it back after the first issue. Luckily, I never had this happen with the Sprint Booster I had.
    djwantke[QUOTED] and 08TXRunner like this.
  6. Apr 13, 2023 at 7:09 PM
    Hahah and dude, even braver than you think, it was my wife driving at the time while I was at work! But my Runner is paid off and don't give a shit bout warrantees so there's that
  7. Apr 13, 2023 at 8:22 PM
    4oreigner
    4oreigner New Member
    2019 4Runner Limited
    Did you remove the PC before or after the diagnosis?
    Did you tell the dealer it was installed?
    Where is your 4R currently?
    What weather conditions have you been driving in lately that may have led to that diagnosis?
    After removing the PC did you consider disconnecting the battery to reset the system?
  8. Apr 14, 2023 at 9:43 AM
    ecoterragaia
    ecoterragaia New Member
    Central Virginia
    2021 SR5 4WD
    This was a common problem with the V8 Tundras, but haven't heard of it being an issue for the 4Runners or Tacomas.
  9. Apr 14, 2023 at 10:50 AM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    This happens to the 2012 tacomas. secondary air pump failure can cause limp mode. Toyota will only pay for it if its a 2012 tacoma!!!
  10. Apr 14, 2023 at 5:03 PM
    714sp4rky
    714sp4rky New Member
    Chris
    ‘20 4Runner SR5
    I had this happen about 2 months ago and I do have a pedal commander on my runner. Took it to the dealer they said a valve was busted and that the air pump was out also. That the air pump caused the valve to stop working. They replaced everything free of charge and didn’t say anything about pedal commander.
  11. Apr 16, 2023 at 2:56 PM
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    Water in the secondary air pump used to be a issue but not since Toyota changed the software on all equipped models. The secondary air pump is supposed to run momentarily after you shut the engine off specifically to clear any water in it. You should easily be able to hear it I can. Can you or did you hear it run after shutoff? My take is I can't really see a pedal commander causing this. Maybe you need a software update for the PCM. Don't know exactly when Toyota made the software change but I would definitely inquire before I shelled that kind of bucks for a pump with the dealer telling you it's your fault/problem.
