Yakama Road Warrier Basket Removal
Discussion in '5th Gen 4Runners (2010-2024)' started by VentureTRD, Jun 30, 2021.
  1. Jun 30, 2021 at 12:43 PM
    VentureTRD
    VentureTRD [OP] New Member
    Blowing Rock, North Carolina
    I decided to remove the basket from my 2021 Venture, but 2 of the 4 clips look to have what looks like a lock over the twist off plastic nuts. It could be a slot screw driver, but it won't budge. Any ideas?
  2. Jun 30, 2021 at 12:44 PM
  3. Jun 30, 2021 at 1:04 PM
    TXKK626
    TXKK626 New Member
    Fort Wayne, IN
    2021 Venture Edition
    Mine came with locking covers to prevent theft in the mall parking lot. Keys were in the glovebox on delivery. If you don't have the keys, I'd check back with your dealer to start with, then maybe Yakima if the dealer is no help.
    MeefZah and Shallowminded like this.
  4. Jun 30, 2021 at 1:17 PM
    Shallowminded
    Shallowminded New Member
    2021 White Venture
    This.
  5. Jun 30, 2021 at 2:25 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX4(Runner)60
    In the short term, while figuring out the missing key situation, you can remove the cross rails and basket as one assembly by sliding the cross rails out of the side rails at the back.
    You will need to unclasp the plastic end caps on each end using a thin screwdriver and twisting the caps towards the outside of the truck.
  6. Jun 30, 2021 at 4:08 PM
    VentureTRD
    I should have read the paper manuals, instead of online. I found the keys in the booklet. Thanks for your help. Will be putting this for sale.
  7. Jun 30, 2021 at 4:53 PM
    MeefZah
    Lexington, Ohio
    2020 GX4(Runner)60
    When you sell it, it is actually a Yakima "Megawarrior" basket. You said "Road Warrior" (not a thing), probably meaning "Load Warrior" (a thing), but it's actually the next size up from the Loadwarrior so it's value is more...
  8. Jun 30, 2021 at 5:23 PM
    EglSctAndy
    EglSctAndy New Member
    Andrew
    2021 Nautical Blue Venture Edition
    Wescott Designs Lift, Toyo AT3 285/70/17
    Glad you found the key cuz I’m not sure how you would have gotten it off. I recently sold the same basket off of my venture $375. Used OfferUp for the first time and was pretty happy with how it all turned
  9. Jul 1, 2021 at 3:16 AM
    VentureTRD
    It was a Mega Warrior Basket. I called the dealership, they had no idea where the key would be, but I found it stuffed in the middle of the owner's manual. Good to know where they put these.
    I Sold the MegaWarrior Basket.
