X-REAS system replaced under warranty
Discussion in '5th Gen 4Runners (2010-2024)' started by R686Phill, Apr 1, 2019.
  1. Apr 1, 2019 at 4:23 PM
    R686Phill
    R686Phill [OP] New Member
    Ron
    2018 4Runner Limited
    Factory stock
    Dealer is replacing entire system under warranty. Purchased new Limited in Jan. 2018. Only 22,000 miles on my “paved road driven” daily commuter. This concerns me, as this system seems prone to failure.
  2. Apr 1, 2019 at 4:55 PM
    4X4Runner
    The left coast
    I think it’s a fluke, that system has been known to run well into 100k just fine.
    jgcaps likes this.
  3. Apr 1, 2019 at 5:31 PM
    R686Phill
    Ron
    Factory stock
    I hope we get there on the next one. I haven’t seen the total $ yet, but I’m sure it’s lots! I left it overnight, should be ready in the morning.
  4. Apr 1, 2019 at 6:25 PM
    R686Phill
    Ron
    Factory stock
    There was a clunking in the right front. Sounded like a worn shock mount. It sounded like it was clunking in the rear also. The dealership said the right front strut had a leak. They replaced it but said there was air in the system. Once air is introduced, there is no way to get it out. The only way is to replace the whole system.
  5. Apr 1, 2019 at 6:46 PM
    Agent_Outside
    Built 2011 T4R Limited
    The system does not have to be replaced all at once. The right front is linked to left rear, that setup would all need to be replaced together, the left front is linked to the right rear and totally separate.
    Backslider likes this.
  6. Apr 1, 2019 at 11:17 PM
    R686Phill
    Ron
    Factory stock
    I understand the system is cross linked. The service manager said they were going to replace all 4 struts, and accumulators. I am going to let them.
    WallyT4R and Backslider like this.
  7. Apr 2, 2019 at 4:05 AM
    doxidad
    doxidad New Member
    Tom
    NE Ohio
    2024 TRD ORP Ice Cap w/KDSS
    Just a data point - but I had close to 200K on my '04 sport before I popped a leak in my XREAS. Hopefully your replacement will last as long on longer.
    jester243, WallyT4R and Backslider like this.
  8. Apr 2, 2019 at 4:53 AM
    wmdtech
    wmdtech Send MOD Money!!
    Nate
    Mid TN
    18 TRD ORP
    Sucks that it "broke", but nice you're getting a complete replacement.
  9. Apr 2, 2019 at 5:34 AM
    R686Phill
    Ron
    Factory stock
    Wow, 200K sounds more like it. Still an expensive system if you have problems. Did you replace you XREAS system, or do a cheaper system?
  10. Apr 2, 2019 at 5:51 AM
    Agent_Outside
    I went with Kings to replace mine.
  11. Apr 2, 2019 at 6:05 AM
    R686Phill
    Ron
    Factory stock
    Does anyone replace with original equipment after 100k or 200k? Anyone think XREAS does anything better than a more traditional system?
    Is that when most find their 4R sitting a bit higher on a new wheel/ tire package as well?
  12. Apr 2, 2019 at 6:24 AM
    Agent_Outside
    I replaced mine around 90k miles. I kept the factory stuff until I killed it. Too much time on unpaved washboard rutted up “roads” at speed did it in. The suspension got hot, really hot, the dampeners faded bad, started dumping fluid, it was smoking and smelled awful. Extended travel custom valved Kings with JBA upper control arms still cost less than replacing with all new OEM XREAS stuff.
    jester243 and wmdtech like this.
  13. Apr 2, 2019 at 7:19 AM
    R686Phill
    Ron
    Factory stock
    Thanks, good info. That’s my assessment, a guy has a lot of options when faced with the cost of XREAS. Fortunately this ones on Toyota!
    jgcaps and wmdtech like this.
  14. Apr 2, 2019 at 11:05 AM
    R686Phill
    Ron
    Factory stock
    Ok, just picked it up. Drove nice and quiet, like it used to. I only see 2 new struts (RF & LR) and 1 new accumulator (driver side). Happy to have it fixed, but they said 4 new struts. I’m not complaining (maybe a little) but happy it’s working now.
    WallyT4R and wmdtech like this.
  15. Apr 2, 2019 at 8:42 PM
    Agent_Outside
    It didn’t sound right that they would do all 4. Warranty would not pay for them to do that.
  16. Apr 3, 2019 at 2:45 AM
    R686Phill
    Ron
    Factory stock
    Agree, it didn’t need to be done. Don’t know why they said they would replace all four.
  17. Apr 3, 2019 at 8:20 AM
    jester243
    Dan
    Spokane, WA
    what does the work order show being done?
  18. Apr 3, 2019 at 12:33 PM
    R686Phill
    Ron
    Factory stock
    Service manager tossed me the key, said he would mail it to me. Haven’t seen it at this point.
