WTF! Do I Have to Have the Engine Running to Listen to Audio!
Discussion in '5th Gen 4Runners (2010-2024)' started by RUNNER4DAN, Feb 23, 2024.
  1. Feb 23, 2024 at 1:25 PM
    RUNNER4DAN
    RUNNER4DAN [OP] Cleverly Disguised as a Responsible Adult
    Daniel
    Doesn't need any
    There has to be a trick to listen to the radio without the engine running. Please enlighten me. I've never had a "smart key" vehicle before.
  2. Feb 23, 2024 at 1:30 PM
    HuskyMike
    HuskyMike New Member
    Press the start button without your foot on the brake pedal. Once should switch to accessory mode, the next press will switch to ignition on mode. Both will allow the radio to work without the engine running.
  3. Feb 23, 2024 at 1:30 PM
    joshdub
    joshdub New Member
    2020 TRD ORP
    If you press the start button the vehicle will go into accessory mode. If you hold the brake pedal and press the start button the vehicle will start. It's really quite simple.
  4. Feb 23, 2024 at 1:31 PM
    steelevo
    Utah
    RUNNER4DAN[OP] and HuskyMike like this.
  5. Feb 23, 2024 at 1:34 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    I figured it would be simple but I couldn't find anything in the owners manual.
  6. Feb 23, 2024 at 1:46 PM
    Yeah man, RTFM. The answers to your questions can be found in the manual, or by performing a very quick Google search.
  7. Feb 23, 2024 at 1:55 PM
    HuskyMike
    Basically every answer can be found by a google search... why have forums, right?
  8. Feb 23, 2024 at 6:02 PM
    jmkulbeth
    jmkulbeth Have you tried turning it off and on again?
    Jeffrey (KE5HDB)
    Siloam Springs, AR
    2020 4Runner Offroad Premium, Nautical Blue
    Bone stock!
    To keep the radio on when you kill the engine, leave it in neutral when press the start/stop button. That'll also put it in accessory mode. You can then shift into park and the radio stays on. It'll stay on about 20 minutes before it shuts off.
  9. Feb 23, 2024 at 7:45 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I have to try this. I don't like the radio turning off just because I want the engine off. I think just about every vehicle out there shuts off accessory mode after about 20 minutes, which prevents unintended battery death, but sometimes it's inconvenient.
    Number16 likes this.
  10. Feb 23, 2024 at 7:55 PM
    Photon_Chaser 46612 and counting…
    Roger
    Sierra Nevada Mountains
    http://tinyurl.com/5th-Gen-Build-Page
    This makes me wonder if it’s not a timer feature but perhaps based off a monitored battery voltage?
    Might have to break out the ol voltmeter and do some testing…
  11. Feb 23, 2024 at 8:16 PM
    You're not wrong. But, whenever I Googled things about my Tacoma, it led me to Tacomaworld. So, I ended up on there, and then here when I switched back to a 4Runner. :D
  12. Feb 23, 2024 at 8:23 PM
    ladebakk
    ladebakk New Member
    Thats why we have forums.. Thanks man! Great simple tip. Never thought of that. I hate that it turns off bluetooth and resyncs/restarts everything when listening to podcasts or music.
  13. Feb 23, 2024 at 10:27 PM
    :puke:
  14. Feb 24, 2024 at 1:32 PM
    garoto
    garoto New Member
    If you want to leave accessory mode on while your wife picks up tomatoes from the grocery "real-quick", and you don't want to turn the car off and back on, put the car in neutral, then turn off the car, then put it back in park. The car will stay in accessory mode without having to cycle the car off and on.
    whippersnapper02 likes this.
  15. Feb 24, 2024 at 2:31 PM
    Number16
    Number16 New Member
    2021 4runner
    Thank you for this. I hated that every time I stopped but wanted to keep the screen on it would go away and I would have to start over again. Next time
    I am in my car I am going to give this a try.
