Wiring Question with Regard to Trailer Hitch Plug
Discussion in '5th Gen 4Runners (2010-2024)' started by Cowboy59, Mar 13, 2021.
  1. Mar 13, 2021 at 6:41 PM
    Cowboy59
    Cowboy59 [OP] Enjoy the Adventure
    N. Florida
    I have added a Rigd tire carrier to my 4R. I had to move the license plate and add led lights for the plate. I have run the black and read wires neatly trough wire loom and mounted along the hitch, up underneath the bumper and spare tire, where I can tap the two leads into the wire loom for the 4 prong hitch plug.
    Getting the plug apart does not appear simple, but I can push back the factory look and tap into the lines. I know the green and yellow lines are for the blinkers, or at least they should be.
    Can someone tell me which color wire is the ground and which is the power? I the factory plug is completely sealed, so I cannot tell which wires are connected to the first two plug pins (ground and power).
    Any help would be greatly appreciated.
  2. Mar 13, 2021 at 7:06 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Edit: delete - not relevant.
  3. Mar 13, 2021 at 7:18 PM
    Does this help you?
    Toy4X4 likes this.
  4. Mar 13, 2021 at 11:15 PM
    Agent_Outside
    Built 2011 T4R Limited
    The trailer plug harness it just a short little section that plugs in, you can remove it and tap in where you need to. The 7 pin plug is labeled for what wire does what, a simple test light will confirm it’s doing what you want it to do. I used the reverse light circuit to add a reverse light in my bumper and I used the tail light circuit to power the license plate light.
    opentang and DrewMan like this.
  5. Mar 14, 2021 at 7:38 PM
    Cowboy59
    N. Florida
    Thank you for that info. I found the same info in tech doc, so your post allowed me to confirm the info. Just what I needed.
    DrewMan and SlvrSlug[QUOTED] like this.
  6. Mar 15, 2021 at 8:01 AM
    Todi
    Todi New Member
    Maryland
    2018 4Runner TRD Off-road
    M.O.R.E. aluminum skid set; Artec aluminum gas tank skid and LCA skids; C4Fab rear diff skid; HeftyFab Banshee front bumper; RezFab flat sliders; SSO rack; 285/70-17 E Falken AT3W; Ironman 4x4 Foam Cell Pro Stage 3
  7. Mar 15, 2021 at 8:11 AM
    Cowboy59
    N. Florida
    Thanks for that suggestion, but I need the plugs for connecting my trailers. I found the answer I needed.
