Wire path for roof rack lights
Discussion in '5th Gen 4Runners (2010-2024)' started by wafersmith, Dec 16, 2023.
  1. Dec 16, 2023 at 2:03 PM
    wafersmith
    wafersmith [OP] New Member
    2018 TRD off-road
    I was curious to see how others ran the wires from their roof rack lights into the cab or engine compartment. I want to put some lights on my roof rack but want to be careful about my wire runs as I don’t want any leaks. Thanks!
    djwantke likes this.
  2. Dec 16, 2023 at 7:47 PM
    qcTRDct
    qcTRDct New Member
    2022 ORP KDSS
    On my FJ I was able to go from the engine compartment up between the fender and the cowl, then used double stick tape and wire loom to run straight up along the edge of the windshield. Looked very clean, no penetrations. I bet it would be easier on the 4runner.Screenshot_20231216-224348~2.png
    wafersmith[OP] likes this.
  3. Dec 16, 2023 at 10:30 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Wire hider from the roof, down the windshield into the engine compartment. Easy to cut the plastic shroud into the engine compartment below the glass. When installed you can't even really see it.
    KC has their brand, as I'm sure some universal/generic on sold on Amazon.
    Been running the KC version for a few years, works great. Actually forgot it was there until this thread.
    Disregard the blue tape, just had my windshield replaced due to a big ass rock.
    djwantke, steelevo, Thacrow and 2 others like this.
  4. Mar 19, 2024 at 2:00 PM
    scottiezilla
    scottiezilla New Member
    Bringing up the most recent n relevant thread I could find…
    so I am currently routing my wiring for everything n one area, the roof front, light bar n pod on both sides of lightbar
    questions:
    I have to replace windshield…if I run the wiring down or under the windshield channel, or even the Kc wire hider, does this wiring have to be removed for the windshield to be replaced?
    does anyone have experience removing the windshield channel trim?
    wondering if it’s the kinda thing where it’d be better to wait till the windshield is replaced or even WHILE it’s being replaced to sneak wires under n up
  5. Mar 19, 2024 at 3:11 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    I had my windshield replaced while I had the KC wire hider. The windshield shop pulled the wires out of the wire hider, peeled the wire hider off, replaced the windshield, reattached the wire hider with new double sided tape that I provided and put the wires back in the wire hider. Easy day.
  6. Mar 19, 2024 at 4:48 PM
    scottiezilla
    Dang @PVT Pablo
    If it all could be that simple haha
    thanks though bud, least I know it’s not a deal breaker to have it there, just a lil temporary move
  7. Mar 19, 2024 at 6:42 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey @wafersmith
    Good question
    100%, @PVT Pablo is a smart man. Invest in KC Wire Hiders. I recently installed dual sides of the windshield and back to my 3/4 rack. Took four 3' length hiders to keep wires protected the entire distance. Paid shipping from US :notsure: had to be done
    Also bought a similar product, with a rounded top, off Amazon. Haven't used it tho
