Wiper arm tension?
Discussion in '5th Gen 4Runners (2010-2024)' started by 4runningMan, Apr 19, 2023.
  1. Apr 19, 2023 at 9:38 PM
    4runningMan
    4runningMan [OP] New Member
    New Mexico
    Weird problem here. I have smearing/haze on just the drivers side of the windshield when using my wipers. At first I thought… “bad wiper blade”. So I tried two other new sets of blades and have the same problem (OEM, Trico, Bosch).
    For good measure, I also polished out the glass with a glass polish to be sure it’s squeaky clean. The haze/fog is clearly not there where the passenger side wiper overlaps.
    So then I got to wondering… does anyone know if it’s possible to increase the downward pressure of the wiper arm? The only thing I could think of was to unhook one end of the tensioner spring, give it a 360° twist and hook it on again. But that seems… wrong.
    Can wiper arm pressure be adjusted another way?
  2. Apr 19, 2023 at 10:26 PM
    4oreigner
    4oreigner New Member
    2019 4Runner Limited
    Regardless of make/model/year of the vehicle with that symptom, and especially after your described troubleshooting, I'd change out the spring with a new one. If you have reason to believe the arm may be bent as well, even slightly bent, I'd replace that too.
    4runningMan[OP] likes this.
