Window regulator help
Discussion in 'Other Toyota Vehicles' started by Tyotor, Jan 27, 2023.
  1. Jan 27, 2023 at 5:40 PM
    Tyotor
    Tyotor [OP] New Member
    Don
    2016 SR5 Premium
    Maybe some of you smart folks can help me here. I also own a Toyota Highlander. Sometimes the 10mm bolt comes loose or falls off the bottom of the regulator. (Should put loc-tite on it and be done with it). Tonight, when I was fixing it, I noticed that the window regulator track moves side to side if you grab the top of the window and shift it left to right. Shouldn’t that stay stationary? The window won’t stay in the rubber channel as a result.
  2. Jan 27, 2023 at 6:20 PM
    wdsteven
    wdsteven New Member
    When you say side to side you mean towards the inside then outward? either way there are 6 of the 10MM bolts that hold the regulator in against the inside door and then there are two 10mm bolts that hold the glass to the regulator if they are all in place and tight it is possible that the center Pivot is worn out on the Regulator and what a PITA it is to get big hands in there if you drop anything down inside!
    If it Moves front to back then again the Center Pivot could be worn out and or the plastic rollers worn or even missing one, As for Loctite I would not use it on the Glass retainers.
  3. Jan 27, 2023 at 6:46 PM
    Tyotor
    Don
    2016 SR5 Premium
    Thanks for the quick reply. The bottom track that the two 10mm bolts attach to moves left to right (not front to back).
  4. Jan 27, 2023 at 6:51 PM
    wdsteven
    wdsteven New Member
    Then make sure the other 4 bolts (also 10mm) that hold the regulator assembly are tight if they are possible worn regulator unit.
  5. Jan 27, 2023 at 7:46 PM
    Tyotor
    Don
    2016 SR5 Premium
    Are those the 10mm heads affixed to the door metal?
  6. Jan 28, 2023 at 4:20 AM
    wdsteven
    wdsteven New Member
    Yes
  7. Jan 28, 2023 at 2:05 PM
    RunningBear
    RunningBear New Member
    2023 TRD ORP, Lunar Rock, KDSS
    The problem is there are no 10mm sockets or wrenches left in the world, they have all disappeared.
  8. Jan 28, 2023 at 4:33 PM
    Tyotor
    Don
    2016 SR5 Premium
    We finally figured out the problem! The glass had slipped out of the track on one side. Once I loosened the two 10mm nuts and raised the glass, we were able to slip it down both tracks.
    Thanks for all the help!
    wdsteven likes this.
