Will these clear OK on a Limited.......
Discussion in '5th Gen 4Runners (2010-2024)' started by afret, Nov 13, 2021.
  1. Nov 13, 2021 at 10:24 AM
    afret
    afret [OP] 2022 ORP, KDSS, Toyo AT3
    North Idaho
  2. Nov 14, 2021 at 5:41 AM
    DIRTRCR13
    DIRTRCR13 New Member
    Jerm
    The 405
    '16 Sierra Romeo Cinco
    Rub where? Body, fender, UCA?
    I dont think 10mm is going to be much of a factor either way even with adding a full inch on wheel width ( assuming you are going from a stock wheel)
  3. Nov 14, 2021 at 7:23 AM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    Your looking to bring your wheels into your wheel well more? +10mm isn’t much and you just listed a stock tire so you should have no problem. Frankly I see a lot of people going with a negative offset to being the wheels out more. This will be interesting
  4. Nov 14, 2021 at 7:31 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Ya,, id think you'd want a negative offset,. but, do you. A stock size, well, should run like stock/oem
    Edit - (285/70/17's here, on a stock OR)
  5. Nov 14, 2021 at 7:37 AM
    Mtbpsych
    Mtbpsych New Member
  6. Nov 14, 2021 at 12:27 PM
    afret
    North Idaho
    The guy at Tire Rack told me a 17x7.5 with +24 offset will clear the suspension parts and should be no problem unless going over +30. Just wanted to confirm with someone who actually tried a +24/+25 offset wheel. Yeah, I'm from the old drag race school that likes tucking tires in the wheel wells and can't quite get the idea of pushing tires outboard though my thick skull.
    SunnyTRD likes this.
