Will these 2022 Ford Bronco rims fit my 4Runner?
Discussion in '5th Gen 4Runners (2010-2024)' started by teton, May 12, 2023.
  1. May 12, 2023 at 3:04 PM
    teton
    teton [OP] New Member
    2015 4Runner SR5
    Hey guys:
    sorry to come here with such an elementary question. I want to know if these wheels will fit my 2015 sr5. I suck at this stuff and figured this would be the place for help.
  2. May 12, 2023 at 3:13 PM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    Bolt pattern matches but you would have to know the hub bore size of the Bronco wheels to make sure they are the same or bigger than OEM.
  3. May 12, 2023 at 3:15 PM
    teton
    2015 4Runner SR5
    Thanks so much. Google says this
  4. May 12, 2023 at 4:11 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Arent the black diamond wheels just steelies?
    And no, center bore size and offset is wrong.
    Thatbassguy and Thacrow like this.
  5. May 12, 2023 at 5:44 PM
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    +55 would be very close to suspension if not touching it. Center bore on 4Runners is something like 106 as well
  6. May 12, 2023 at 5:48 PM
    teton
    2015 4Runner SR5
    Thanks so much!
  7. May 12, 2023 at 6:59 PM
    LetsTacoboutit
    LetsTacoboutit New Member
    Adobe
  8. May 13, 2023 at 6:22 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Are you looking for steel wheels?
  9. May 13, 2023 at 6:31 AM
    That offset is likely to be a problem.
    And, the center bore, as mentioned above.
    Maybe they would work with some spacers. :notsure:
  10. Jan 15, 2024 at 10:18 AM
    Phanleydam17
    Phanleydam17 New Member
    Paul
    19 Tacoma
    IMG_4685.jpg IMG_4687.jpg I put the bronco rims on my Tacoma. Had a pocket for the Tacoma hub machined on the 1.5” spacers and they fit great.IMG_4683.jpg
    luv4outdoors and java like this.
  11. Oct 31, 2024 at 10:08 PM
    luv4outdoors
    luv4outdoors New Member
    Thursday
    Hello Paul. What was the reason or requirement for the pocket mod? I think I answered my own question but will leave this here for confirmation.
  12. Nov 1, 2024 at 8:07 AM
    golfpilot
    golfpilot New Member
    David
    Switzerland
    2019 TRD Off Road Premium
    Must be the adjustment for the center bore,
    from the 93 to 106mm size.
    The adapters were probably not originally 106mm.
