Will Tacoma TRD suspension Work on Runner?
Discussion in '5th Gen 4Runners (2010-2024)' started by OmarSing, Dec 10, 2016.
  1. Dec 10, 2016 at 12:45 PM
    OmarSing
    OmarSing [OP] New Member
    Omar
    Central California
    2016 4runner SR5
    TRD Grill, TrdWheels,TRD skid plate, Bilstein (5100) series suspension front 2.5” and rear with 1.5" swayaway coil. BFG 275/70r17, Added front and rear lower valances.. work in progress…
    Will the 2016 Tacoma TRD Sport/OffRoad suspension fit on a 2016 Runner sr5? I see a lot of locals selling this full suspension for pretty cheap in my opinion. Also would it do me any goo to purchase the UCA's for my lift? Any advice would be appreciated ✌️ Happy Holidays
    Amerxon555666 likes this.
  2. Dec 11, 2016 at 5:25 AM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    It most likely will fit, the only thing i would check on is the size of the bushings, thats usually where the differences between the two suspensions is. if all youre doing is swapping tacoma suspension to a 4runner then i wouldnt worry about UCA's, the lift amount won't be large enough to necessitate them, but if youre planning more lift in the future it cant hurt to be prepared
  3. Dec 13, 2016 at 10:46 PM
    OmarSing
    Omar
    Central California
    2016 4runner SR5
    Awesome! Thanks for the notes sir ✌️
  4. Dec 14, 2016 at 9:04 AM
    Relentless
    Relentless Offroad armor Fabricating beast! Vendor
    Eric
    Sparks NV
    05 Limited 4.7 V8, long travel, dual locked
    Lifted on 35s and Relentless Armored, too much to list!
    Front- yes, rear- No.
    scottalot likes this.
  5. Dec 14, 2016 at 11:45 AM
    OmarSing
    Omar
    Central California
    2016 4runner SR5
    Thanks for the response
  6. Dec 15, 2016 at 10:45 AM
    bahndrvr
    bahndrvr New Member
    Trevor
    Melbourne, Fl
    03 SR5 V8 4Runner
    2003 4Runner SR5 v8 - Temp Front: Top hat spacer 2.5" on Tacoma struts/springs Rear: TJM/King heavy extended Tacoma shocks 315 BFG AT KO2's (35's) Thrush Welded muffler and rear watermelon delete with turned exit K&N drop in, and extra filter delete Strengthened/Welded passenger side front diff mount Front diff drop - due to the top hat spacer and massive droop.... Scion headunit CB Other stuff done, 6th 4Runner:)
    Caveat, rear yes if you press out the rear bushings and replace with different lower bushings... Cost is around 8 bucks to do this and around 20 minutes. I will say the rear shocks are too soft for the 4Runner though as I'm currently running them and will replace them soon.
  7. Nov 10, 2018 at 6:25 AM
    cricket1977
    cricket1977 New Member
    2016 4Runner
    Not to drudge up an old thread, but I am under the impression after a couple of scant thread reads and searches that this would be about a 1" lift in front due to length of the Taco coilover, is this actually correct?
  8. Apr 12, 2021 at 7:59 PM
    Amerxon555666
    Amerxon555666 New Member
    Paul
    Red 2021 4runner TRD off-road
    can anyone confirm is this will actually add height to a 5th gen 4runner using Tacoma struts?
