Will replacing shocks on a 2016 SR5 Premium with Bilstein 5100's improve "nose dive" when breaking?
Discussion in '5th Gen 4Runners (2010-2024)' started by LKN4Runner, Aug 10, 2020.
  1. Aug 10, 2020 at 3:39 PM
    LKN4Runner
    LKN4Runner [OP] New Member
    Lake Norman, NC
    2016 Magnetic Grey Metallic XP 4X4 with 20" Gunner rims and 275/55 R20 Nitto Grappler G2 Tires.
    I have a 2016 4Runner SR5 Premium 4X4 (XP Package) and would like to know if anyone has replaced stock shock with Bilstein 5100's (or any other aftermarket shock) to minimize the "nose dive" effect when breaking?
  2. Aug 10, 2020 at 3:43 PM
    Mtbpsych
    Mtbpsych New Member
    Yes it will, slightly with stock coils I assume and remedy it if swapped with aftermarket coils.
    djwantke and Thatbassguy like this.
  3. Aug 10, 2020 at 3:50 PM
    LKN4Runner
    Lake Norman, NC
    Thanks John.
    Sounds like I need to replace the factory coils (in addition to the shocks) to minimize or resolve this "nose dive" effect when braking. Unless there is some reason that Toyota designed the 4Runner to react this way, I want to correct it.
    Thanks again for your input!
    Mtbpsych and Thatbassguy like this.
  4. Aug 10, 2020 at 5:05 PM
    I think they use soft springs to make the ride more comfortable. I like the ride better with aftermarket shocks and springs.
    A&P and Antman like this.
  5. Aug 10, 2020 at 8:07 PM
    I just replaced my shocks and kept the stock coils. It significantly reduced my nose dive. The stock shocks are valved pretty soft. Bilsteins are much firmer.
    Our stock coils are something close to 600lb coils up front. Most replacement coils are 600lb coils as well. If you replace your stock 600lb coil with an aftermarket 600lb coil, you haven't done anything to improve the nose dive. You can buy stiffer coils, but the purpose of that is to accommodate a constant load (like a bumper and winch). If you add stiffer coils to your truck with no weight, you could risk being unhappy with the way it rides.
    You might want to consider trying it out with the 5100's and your stock coils first to see if you're happy with the reduction in nose dive the shocks provide with the stiffer valving. If you're unhappy with that result, get some stiffer coils.
    djwantke, A&P, SlvrSlug and 1 other person like this.
  6. Aug 11, 2020 at 4:02 PM
    runner4it
    runner4it New Member
    Alex
    2020 4Runner ORP
    Did you raise your height with the bilstein struts? If so that increased your effective spring rate by adding preload to the spring. The idea that new shocks will prevent brake dive is a bit of a misnomer. Only spring rate can do that. The valving only damps (controls) the rate of expansion and contraction of the coil in a smooth manner. The new shocks may have slowed the dive so it feels better but without springs it will still dive just as far.
    Oldtoyotaguy likes this.
  7. Aug 11, 2020 at 4:12 PM
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    That's an interesting observation, but I'm not sure how it squares with the effect of XREAS. That system uses the shocks to reduce brake dive and body roll by sending additional hydraulic fluid to firm the shocks that are compressing the most with the shifting weight of the vehicle. I can guarantee it makes a big difference. This is why I've been wondering if the effects of XREAS could be duplicated -- or at least approached -- with shocks that have piggyback hydraulic reservoirs.
  8. Aug 11, 2020 at 4:21 PM
    runner4it
    Alex
    2020 4Runner ORP
    I'm not familiar with the xreas system at all so I can't speak to how it works other that dramatically slowing the valving for split seconds to disperse the load back to the rear. I was talking only in terms of a traditional valve and spring suspension. It's something we deal with a lot racing motorcycle because everything is hyper sensitive to weight of rider, motorcycle and personal braking characteristics.
    A&P likes this.
  9. Aug 11, 2020 at 4:34 PM
    runner4it
    Alex
    2020 4Runner ORP
    So maybe just to clarify my statement. Assuming brake pressure, brake distance and time are all the same a new shock will better control the rate at which front dives make for a more "planted" feel but the physical compression distance of the spring will likely be the same if the spring is unchanged.
    Where things like xreas and advanced digital suspension usually works is by slowing the rate of compression enough that the load is removed before complete compression under normal circumstances. Variable valving is awesome tech and it no doubt helps so im not trying to take that away from it nor am I an expert in it.
    I run remote res rear shock on my triumph and that helps because you can get a lot more fluid in the system for the length of the shock body. It help dissipate heat really well. Variable valved shocks (not sure if that's a thing on most lower end units) allow you to control high and low speed compression. Low speed is things like body roll while high speed helps in heavy braking and especially sharp bumps.
    A&P and Oldtoyotaguy like this.
  10. Aug 11, 2020 at 4:47 PM
    Singleminded
    OEM LED foglights
    That makes sense. Thanks for the info.
  11. Aug 11, 2020 at 7:26 PM
    I did raise the height, but doing so does not preload the springs.
    The springs are not compressed anymore than they were before by raising the lower spring perch. I raised the height of the spring perch, which in turn raises the vehicle......and the truck still weighs the same as it did before. Therefore, spring rate does not change.
    The only difference is the valving of the shocks, which can make a big difference in the way a vehicle handles. Think of the way progressive valving handles vs digressive valving....or adding compression adjusters to shocks.
    A&P and Thatbassguy like this.
  12. Aug 12, 2020 at 3:27 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    My Eibach Pro Truck Lift (4 springs 4 shocks) eliminated the body roll and significantly reduces nose dive on braking. It handles curves 100% better. Ride is firm but not punishing on bumpy roads.
    Spring rate for front Eibach Coils = 662lbs Spring rate for rear Eibach Coils = 206lbs +/- 2% Only time I notice nose dive on braking is in emergency braking situations. Otherwise nosedive is eliminated.
  13. Aug 12, 2020 at 4:01 AM
    will van
    will van New Member
    Will
    2019 Toyota 4Runner TRD ORP and 1977 FJ40 Land Crusier
    Great thread. I would also like to reduce nose dive and am looking for a former ride. I do not want any lift. Suggestions for stock suspension height setup?
    Tank010 likes this.
  14. Aug 12, 2020 at 5:04 AM
    runner4it
    Alex
    2020 4Runner ORP
    The bilstein struts are the same length as the factory strut to maintain proper suspension travel. If you move the collar upward on the body the length of the strut does not change therefore you must compress the spring more to reach that perch.
    Mtbpsych likes this.
  15. Aug 12, 2020 at 5:23 AM
    If raising the spring also raises the truck, then you are not compressing it. All you're doing is raising the at rest position.
    BlueSpruce and nimby like this.
  16. Aug 12, 2020 at 5:27 AM
    I would think a digressive valved shock would be the best for this. Bilstein are digressive valved. I believe Icon is as well. My truck is much less floaty with Bilsteins, in spite of having added hundreds of pounds of armor, etc.
    It seems that most reputable aftermarket shocks will accomplish this. I think the stock shocks are very soft valved.
    nimby and A&P like this.
  17. Aug 12, 2020 at 5:30 AM
    karmatp
    karmatp New Member
    Trevor
    2016 SR5 4x4
    I put 5100’s on my 16 right after I purchased it. I raised the front 1”, so the setting was .85 of the shocks. I can say it has drastically reduced the nose dive, it is perfect now while braking.
    nimby, A&P and Thatbassguy like this.
  18. Aug 12, 2020 at 6:00 AM
    V4runner
    V4runner New Member
    Vikash
    2019 Sr5 Premium
    Daystar Leveling Kit
    I have a day star leveling kit I am looking for some upgraded springs and shocks without adding any additional lift. I would like to upgrade the ride quality of stock what is a good option?
  19. Aug 12, 2020 at 6:01 AM
    runner4it
    Alex
    2020 4Runner ORP
    You aren't elongating the strut when you raise the lower post. The strut is internally fixed for maximum length which is the same regardless of the position you install the lower. You raise the truck by reducing static sag of the suspension by preloading the spring.
  20. Aug 12, 2020 at 7:17 AM
    Your truck doesn't sit at maximum droop. Height is determined by the spring position, therefore the spring rate is the same at any height
    nimby likes this.
  21. Aug 12, 2020 at 7:26 AM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Dasaíta HU, Bilstein 5100s, AT Tires, Coveted grill lights
    I put Bilstiens all around on my '15 SR5, fronts at .85, stock springs. Much better in handling and ride. Significantly reduced nose dive.
    nimby and Thatbassguy like this.
  22. Aug 12, 2020 at 8:02 AM
    runner4it
    Alex
    2020 4Runner ORP
    Honestly I think we are just talking around each other lol. I agree that bilstein 5100 struts are a great option to improve ride quality and adding lift (or not if selected)! Had them on my old Ram and loved them. Only didn't do them on the t4r because I didn't want to deal with doing the spring transfer which is sketchy with the crap rental coil spring compressors.
  23. Aug 12, 2020 at 8:39 AM
    I believe that raising the perch would affect the spring rate at the top of up travel, but not at resting height. The initial impact should stay the same, because you're just riding higher(or lower, depending how you look at it) in the shock's range of motion.
    I have a (cheap) spring compressor, and I have avoided using it ever since I had enough money to not HAVE to.:D
    What shocks did you do on the 4runner? Or, running stock? I have 6112's and the shop I ordered them from assembled them for me free of charge. Thank God!
  24. Aug 12, 2020 at 9:56 AM
    runner4it
    Alex
    2020 4Runner ORP
    I decided to bite the bullet and get an Ironman 4x4 stage 2 kit to try. It was a bit of build creep from my original plan but I'm happy with the stance on the truck right now and comfortable knowing the UCAs are done. Need to sort out wheels and tires now.
  25. Jan 20, 2024 at 9:02 AM
    Rupp1
    Rupp1 New Member
    NC
    2017 SR5 Premium RWD Starlight Black
    I installed 5100’s all around on my 2017 SR5 Premium RWD, and no better with the dive. Set to .85”. Will likely try some different springs. The ride is fantastic, so we’ll see what happens.
    My 15 Tacoma Off Road is always level even when you hammer the brakes to the floor. That’s what I’d like to accomplish with the 4R.
  26. Jan 20, 2024 at 9:39 AM
    One would think a RWD would have less brake dive due to less weight in the front...
    Rupp1[QUOTED] likes this.
  27. Jan 20, 2024 at 10:51 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    This right here^
    @LKN4Runner I run 5100's on all four corners, and upgraded springs (OME in front, ICON rear coils).
    nimby[QUOTED] likes this.
  28. Jan 21, 2024 at 6:17 AM
    Shanky
    Shanky New Member
    I find towing reduces Nose Dive dramatically……
  29. Jan 21, 2024 at 8:39 AM
    CO RUNNER
    CO RUNNER New Member
    I put 5100s all around on my 2017 and 2019 with stock springs and a .85 lift in the front only. A much better drive IMO.
