Will cracked manifold automatically throw code
Discussion in '4th Gen 4Runners (2003-2009)' started by esamos, Jul 10, 2024.
  1. Jul 10, 2024 at 8:04 AM
    esamos
    esamos [OP] New Member
    2006 Limited V8 4wd
    If there is a cracked exhaust manifold, will a the check engine light, or another light, automatically come up and throw code or does it have to get worse to a point before that happens? And what is the difference between short and long tube headers from someone like Doug Thorley?
    Thanks
  2. Jul 10, 2024 at 8:09 AM
    It may or may not throw a code depending on the leak size and it also has to see that there is a problem.
    LT usually deletes the cats which will throw a code without a tune or some type of O2 sensor defouler.
