Will adding rear 15mm spacer affect the alignment?
Discussion in '5th Gen 4Runners (2010-2024)' started by JosephD, Apr 5, 2023.
  1. Apr 5, 2023 at 2:59 PM
    JosephD
    JosephD [OP] New Member
    Joseph
    Austin, Texas
    19' Barcelona SR5
    Eibach stage 2, Cali-Raised sliders
    I just installed my Eibach stage 2 lift kit. I've adjusted the front of the truck to be even, and adjusted for the lean. The back still has 1/2" difference due to the gas tank, etc.
    I've ordered the Dobinson rear 15mm spacer to fix the lean. (it won't be in for another week)
    Question: If I get an alignment now will adding the rear 15mm spacer later affect the alignment? Trying to avoid paying unnecessarily on multiple alignments.
    djwantke likes this.
  2. Apr 5, 2023 at 3:12 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Want to know if it will affect rear and front axel alignment, or just the rear - camber, toe, thrust angle?
  3. Apr 5, 2023 at 3:19 PM
    JosephD
    Joseph
    Austin, Texas
    19' Barcelona SR5
    So I guess my question is will it effect both/either? IE. Will I need to get another alignment after the 15mm spacer goes in on the driver side. I'm assuming the answer to the question is yes based on your reply?
  4. Apr 5, 2023 at 3:32 PM
    Me personally would wait for the install to be completed even though the alignment is front only.
    But I have a small question. Wasn't the spring perch not adjusted for the eibach springs? I know some springs has left and right specific springs and I thought Eibach springs come with the spring perch instead of side specific springs?
  5. Apr 5, 2023 at 4:42 PM
    Well alignments aren't just front only there's the angle of your rear axle and wheel toe. Unfortunately I don't have an answer for you lol, but agree you should def wait till the install is done if possible save that $
  6. Apr 5, 2023 at 6:01 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    Lifting the rear only will reduce your caster. It may be a trivial amount if only adding 15mm but like others suggested, I would wait until you have it all completed.
    To prove this out...If you exaggerate the lift, you will see that caster is reduced as the top of the front strut will rotate over the bottom as the rear is raised.
    Again. Wait to install the spacers, then get it aligned.
  7. Apr 9, 2023 at 4:32 PM
    JosephD
    Joseph
    Austin, Texas
    19' Barcelona SR5
    Awesome, I appreciate all of the responses.
  8. Apr 9, 2023 at 6:11 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    But one of those isn't adjustable without aftermarket components, and the other isn't at all.
  9. Apr 9, 2023 at 6:23 PM
    We're talking about an aftermarket setup, and I didn't mean that as two diff things. Thx for parachuting in with no useful information tho
  10. Apr 9, 2023 at 7:02 PM
    08TXRunner
    '20 SR5P
    You didn't mean them as two different things? LOL. So to start with, explain how rear toe is adjustable.
