Why add wheel spacers?
Discussion in '5th Gen 4Runners (2010-2024)' started by Sparkkky, Feb 15, 2019.
  1. Feb 15, 2019 at 7:31 AM
    Sparkkky
    Sparkkky [OP] New Member
    2018 4 Runner TRD Off-road
    Eiback Pro lift, ARB Summit bumper, Smitty Bilt wench, Summit flood LED
    Is because of wider tires or what?
  2. Feb 15, 2019 at 7:38 AM
    It gives your ride a wider stance, and looks really cool.
  3. Feb 15, 2019 at 8:31 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Could be to fit larger tires without rubbing frame at full lock but I think most do it for the looks.
    troprobped17 likes this.
  4. Feb 15, 2019 at 9:14 AM
    rkntoy
    rkntoy New Member
    Not rubbing so much on the frame is why I did it in front. I think most do it for looks.
  5. Apr 12, 2019 at 5:32 PM
    57buick
    57buick New Member
    David
    2018 4runner Off Road premium
    33" Duratracs, TRD Wheels, Addicted Off-Road front Bumper
    just buy the right wheels with the right offset and you dont need the spacers. just another part to fail and they do fail because they dont get torqued correctly etc.
    These are Black Rhino wheels with a -10 offset with 285/70/17 duratrac tires
  6. Apr 12, 2019 at 7:42 PM
    Agent_Outside
    Built 2011 T4R Limited
    It's trendy to poke your tires out and spray mud and rocks at the paint down the side your vehicle
  7. Apr 12, 2019 at 7:48 PM
    57buick
    57buick New Member
    David
    Yep, and make the rig more stable offroad and onroad, but thats the trade off your right
    troprobped17 and Backslider like this.
  8. Apr 12, 2019 at 8:05 PM
    Agent_Outside
    Let's be honest, the vast majority of people adding spacers are doing it for looks. The guys looking for off road stability are typically running wheels in the offset they want.
  9. Apr 12, 2019 at 8:16 PM
    Ajmogen
    Ajmogen Staying Stock
    Aaron
    Wisconsin
    Liscence Plate Surround
    Upper control arm clearance is the only functional reason. I ran them on my tacoma untill I could buy wheels with proper backspace.
  10. Apr 13, 2019 at 5:31 AM
    karmatp
    karmatp New Member
    Trevor
    2016 SR5 4x4
    I think spacers look silly. I want my tires under the fender flares to prevent rocks from being thrown down the side of my vehicle.
  11. Apr 13, 2019 at 6:06 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    Everyone’s different. I like the wheels to be flush when they are tucked in it reminds me of a bodybuilder that always skips leg day. Haha it’s your truck though mod it the way you want as long as your happy with it that’s what counts.
    Backslider and SlvrSlug like this.
  12. Apr 13, 2019 at 6:30 AM
    Dammit, today is leg day.:muscleflexing:
    HoBoDanny[QUOTED] likes this.
  13. Dec 3, 2021 at 2:10 PM
    4Runner007
    4Runner007 New Member
    2021 4 runner Limited
    2” level front
    Trying to revive an old thread here. Had anyone come across a 1/4 wheel spacer for 4 runners? I’ve tried 1 inch and 1/2 inch but it’s just a tad too much for my liking. 1/4 is what I’m going for to improve the look and give me a little more of a gap from my upper control arms. 1/4 inch will do the trick, but for the life of me I can’t find one that size with a 106mm center bore to fit a Toyota. Anyone know where I might be able to pick 4 up?
  14. Dec 3, 2021 at 4:02 PM
    Friends don’t let friends use wheel spacers.
    wfxt, negusm, Big B and 2 others like this.
  15. Dec 3, 2021 at 6:00 PM
    I don't think they make quarter inch because there's no way to bolt them to your hubs. They would literally just be like a washer that slips over your lugs and spaces your wheel away. Most quality spacers bolt to your hubs with their own set of lug nuts, and then your wheels bolt to studs on the spacers.
  16. Dec 3, 2021 at 6:21 PM
    FourRunnerFor4
    FourRunnerFor4 New Member
    ‘22 TRDOR, KDSS, Lunar Rock
    Can someone give me some insight on tire/wheel fitment? I traded my Tacoma for a 22 TRD off-road. I took the practically new 265/70/17 falken wildpeaks off my Tacoma before trading and I would like to put them on a set of pro wheels for the 4 runner. Will these tires fit on 17x7 pro wheels? Also, what offset should I shoot for to avoid rubbing? I prefer to not do any lift/leveling or any spacers, and I don’t really care about where tires end up in relation to the fenders, flush or less is fine. Sorry, I’m new to a 4 runner and have read many different things when it comes wheels and tires. Any help would be greatly appreciated. Thanks.
  17. Dec 3, 2021 at 6:37 PM
    4Runner007
    2” level front
    They make a lot of 1/4 inch spacers, but I can’t find ones that for the 4 runner hub of 106mm. Even all of the 1/2 inch spacers are slide on and use the stock lug bolts. I tried 1/2 inch spacer (slide on) and they went on fine, just too wide for me. Once you get to 1 inch spacers they become bolt on due to not enough threads on the stock bolts. Everything I’ve read says if you have at least an inch of thread beyond the spacer your fine without bolt ons.
  18. Dec 3, 2021 at 6:49 PM
    Buzzkill! That’s what wider mudflaps are for :p
  19. Dec 4, 2021 at 4:41 AM
    Matt83
    Matt83 New Member
    Northeast
    So their scratch free lifted trucks with big tires look even better in the super market parking lot.
  20. Dec 4, 2021 at 6:06 AM
    I'll share why I have them.
    I like the stock offroad wheels but the +15 offset on the SR5 and Offroad's are a bit too sunken in, IMO. I felt I could add a little more stability by increasing my track width with wheel spacers.
    I'm also not a big fan of all the aftermarket wheels. When I purchased the truck (2018) almost every god damn wheel was black and had fake beadlocks. I was over that trend. it was near impossible to find wheels that fit without that shit. There are a few companies without them now, thank goodness.
    McSpazatron and SlvrSlug like this.
  21. Dec 4, 2021 at 6:35 AM
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    SCS wheels have a couple without the faux bead locks. I like their offsets too. As far as spacers, I had to run them on my 4th gen TC set up with the LCAs.
    I took steps to help keep them from being hazardous (longer studs, extended lug nuts, and proper torque specs). Don't blame anyone for NOT wanting to use them. If installed improperly, they can be disastrous.
  22. Dec 5, 2021 at 4:48 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    They will fit. That was the 1st set of tires I had on my 4Runner.
  23. Dec 5, 2021 at 6:31 AM
    jmart4173
    jmart4173 New Member
    Joe
    So true :)
  24. Dec 5, 2021 at 6:55 AM
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    I have a couple of friends with 2WD rigs that keep trying to get me to put spacers on. It looks cool, they say. But I off-road. And I’ve never been on a tight obstacle (or any for that matter) and thought, “if only my wheels stuck out into the rocks more.”
  25. Dec 5, 2021 at 7:58 AM
    4Runner007
    2” level front
    My thought on wheel spacers is that they are purely for cosmetic purposes. I mean, unless your going bigger than 2-3 inches. I can’t imagine that if you put on 2 inch spacers giving you 4 extra inches total of stance would do anything. I’ve done the Rubicon trail which is pretty Gnarly in my 05 4 runner SR5 with no spacers and I don’t think it would have helped me at all. My 2 cents.
    YetiMtnBkr and Dinosaur Overland like this.
  26. Dec 5, 2021 at 8:04 AM
    Gamma Ray
    2020 SR5 Barcelona Red
    You'd add wheel spacers because your perfume or cologne of choice is Bud Light.
    whippersnapper02 likes this.
  27. Dec 5, 2021 at 10:09 AM
    Not for the Runner but I used 1/4" spacers from Bora to clear my shock reserviors on my Tacoma.
  28. Dec 5, 2021 at 10:16 AM
    4Runner007
    2” level front
    I just found 1/4 Bora spacers and they do have them for the 4 runner! Thanks! Can you tell me if the Bora 1/4 inch spacers are simply slide on or do you have to bolt them on and then bolt on your tires to the spacer studs?
  29. Dec 5, 2021 at 10:35 AM
    They are hubcentric and bolt onto the OEM studs with their short nuts. Use loctite on those. Then you mount your wheel/tire on them with the OEM lugnuts. I used antisieze on the back of the spacer to keep it from sticking to the rotor.
    LandCruiser and Thatbassguy like this.
  30. Dec 5, 2021 at 10:40 AM
    Those are the stock size for our 4Runners. They should certainly fit, especially since you're using OEM wheels.
