White Square on Front of Mirror?
Discussion in '5th Gen 4Runners (2010-2024)' started by Captain Spalding, Feb 27, 2023.
  1. Feb 27, 2023 at 6:08 PM
    Captain Spalding [OP] . . .
    Greetings all,
    I’m looking at mounting a dash cam. It will hang between the rear view mirror and the windshield. I notice there is a white square on the front of the mirror (the side that faces the glass). What is it? And what happens if the dash cam obstructs it?
    Thanks in advance.
  2. Feb 27, 2023 at 6:13 PM
    Glenn Goodlett
    Glenn Goodlett New Member
    Glenn
    2020 TRD Pro
    Paid for
    I think it is a light sensor.
  3. Feb 27, 2023 at 6:19 PM
    Light sensor. The mirror may not dim correctly if it’s blocked.
    wdsteven likes this.
  4. Feb 27, 2023 at 6:22 PM
    scanny
    scanny New Member
    Ontario, Canada
    I wouldn't put dashcam behind mirror since it will be hard to operate it and might interfere if you need to change mirror position. And that thing of course probably some sort of sensor. I put dashcam slightly under the mirror on passenger side right under dots on windshield.
    Mass4runner likes this.
  5. Feb 27, 2023 at 8:26 PM
    Glenn Goodlett
    Glenn
    2020 TRD Pro
    Paid for
    It has something to do with dimming the rear view mirror. I covered mine as well as pointed a flashlight at it at night and it did weird things to the dimming on the rear view mirror.
    I think if you put something in front of the sensor, it may not be so bad as long as you don't completely block light from entering the sensor.
    Captain Spalding[OP] likes this.
  6. Feb 28, 2023 at 2:49 AM
    wdsteven
    wdsteven New Member
    The rearview mirror contains two sensors - one forward facing and one rearward facing - that work together to identify and eliminate dazzling light. The forward facing sensor detects ambient light, while the rearward facing sensor detects the light from vehicle headlights behind.
  7. Feb 28, 2023 at 4:35 AM
    scanny
    scanny New Member
    Ontario, Canada
    Yes, I got Safety Sense stuff all around the mirror, so at first I was sort of wondering of where to put camera. My old SR5 didn't have anything around mirror and putting dashcam was easy - i was almost at the center or windshield. With Safety Sense cameras I had to put dashcam a little more to the passenger side then I intended, but after all it worked out well.
  8. Feb 28, 2023 at 8:49 AM
    4oreigner
    4oreigner New Member
    2019 4Runner Limited
    Tell me more. I thought the one facing forward was the ambient sensor to turn the headlights on automagically when dusk hits. And the rear facing one makes almost no sense since the rear door and window sits higher than most any vehicle approaching from behind and the dark tint on the rear glass will block most offensive light reaching the rear-view mirror.
  9. Feb 28, 2023 at 9:25 AM
    See if Blendmount has a solution for your camera.
  10. Feb 28, 2023 at 9:33 AM
    4oreigner
    Very cool, tons of dash cams out there, none of them will block the light sensor on the mirror enough to affect efficiency.
  11. Feb 28, 2023 at 11:51 AM
    No I think that’s the little button shaped nub on the center of the dash.
  12. Feb 28, 2023 at 11:55 AM
    It might be better to put the dash cam to the right of the safety sense stuff anyway. I did a “dry fit” behind the mirror and Scanny is right. It’s tight back there. Tough to get to the controls.
  13. Feb 28, 2023 at 12:23 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    I mounted my Garmin mini dash cam high up on the driver side of the windshield behind the mirror for a higher viewing angle and so I wouldn’t be distracted by its red power LED. Then I noticed that the auto-dimming mirror function was always dim even in the daytime.
    It’s because I obscured that forward facing photocell, so the mirror behaves as if it’s always in night mode and keeps the mirror dimmed.
    I wound up removing the mount and re-positioning it so the photocell could see the light, and all is well now.
  14. Feb 28, 2023 at 1:42 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Depends on the camera, but its got to be a light sensor. Though even with my Blackvue semi obstructing it it works perfect since there is also a sensor for cars behind (which is more important).
    My Blackvue is literally less than 1/4" above the sensor. Plus i have tons of other stuff around my mirror so not to obstruct any visibility. Definitely ideal having it in from of the RVM making it a bit stealthy and out of view.
  15. Feb 28, 2023 at 3:20 PM
    wdsteven
    wdsteven New Member
    From the Factory the Toyota rear window is not tinted so dark that it interferes with the rear facing sensor that detects bright headlights coming in from behind.
    Then If your car has automatic headlights, it also has a headlight control sensor. Essentially, this is what’s responsible for turning your headlights on and off based on ambient light levels. The sensor is located on the dash near the windshield in front of the driver’s position. It monitors the amount of light outside through the windshield. When it detects dropping light levels, it turns the headlights on.
  16. Feb 28, 2023 at 4:43 PM
  17. Feb 28, 2023 at 4:44 PM
    Glenn Goodlett
    Glenn
    2020 TRD Pro
    Paid for
    During the day, put you finger over the front sensor on the mirror. The mirror dims down. It must be on auto.
    I couldn't tell the rear sensor did anything during the day by blocking it or shining a flashlight into it. Will try again after dark.
  18. Feb 28, 2023 at 4:54 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
  19. Feb 28, 2023 at 5:16 PM
    scanny
    scanny New Member
    Ontario, Canada
    Checked manual for my 2022 TRD Off-road - looks like it an Anti-glare function sensor.
    Responding to the level of brightness of the headlights of vehicles
    behind, the reflected light is automatically reduced.
  20. Feb 28, 2023 at 6:54 PM
    UncleShorty
    UncleShorty New Member
    I use painter's tape to dim LEDs. The number of layers you put on controls the brightness. And it comes off easy if need be.
  21. Mar 1, 2023 at 6:51 AM
    MartianArmada
    MartianArmada New Member
    Alex
    Harford County, MD
    2021 Venture
    Wildpeaks
    I've been noticing my rear mirror hasn't been dimming properly at night lately. I bet its because I have my Garmin dashcam back there! I guess I'll attempt to move it an inch to the left or right and see if that improves anything.
  22. Mar 1, 2023 at 7:31 AM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    Sorry to sidetrack the thread - would love to see a pic of your Garmin cam. I am also thinking of using a Garmin for a rear dash cam. I already have the Mini 2 up front. Thanks!
  23. Mar 1, 2023 at 7:39 AM
    Emmantik
    Emmantik New Member
    I put the auto dimmer on a switch because it is always on and the little green light bugged me - especially when I don't need it on. I added a pushbutton switch to control it so now it is always off and turns on only when I need it (someone behind me with highbeams on or headlights not angled properly). I had to trim some plastic to make it fit but really happy with the finish. It's located where an SOS button would be on other models.
  24. Mar 1, 2023 at 8:01 AM
    MartianArmada
    Alex
    Harford County, MD
    2021 Venture
    Wildpeaks
    Oh sorry, I meant "back there" as behind the mirror facing forward. I did have the same idea though, to get a second Garmin as a rear camera. If I ever mount one, I'll do my darndest to remember this thread send a photo.
  25. Mar 1, 2023 at 2:19 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    The auto-dimming mirror on your 2015 doesn’t already have a power button? My 2018 does.
  26. Mar 1, 2023 at 2:21 PM
    Emmantik
    Emmantik New Member
    It does, but it is always on. I would rather have it always off and turn on when needed. I know it's kinda silly but I'm all about the little details.
  27. Mar 1, 2023 at 4:11 PM
    I installed the Garmin Mini 2 Dash Cam and the Dongar adapter yesterday. It’s a little involved, but this install video is excellent:
    I would add a couple of notes:
    1. I chose to locate the USB port on the passenger side of the mirror pillar, between the pillar and the Safety Sense camera housing. It’s more hidden that way. It was a 15 minute job requiring only pry tools and a screwdriver.
    2. When it’s time to place the camera, it’s best to have already downloaded the app onto your phone and have it set up and running, so you can see what the camera sees, on your phone, before you peel the film off the mount and stick it to your windshield. I first placed the camera close to the mirror pillar, but the when I looked at the image on the phone an obnoxiously large portion of the camera image was obscured by a blacked-out portion of the glass. I had to pry the mount off the glass and use the included second mount to relocate the camera.
    3. I chose to locate the camera behind the mirror so it wouldn’t encroach into my field of view, and to avoid seeing the red LED that ElectroBoy mentioned above. I knew this might affect the dimming function of the mirror. I took the 4Runner for a test drive last night to test the dimming function, but there wasn’t much traffic so more testing may be necessary.
    4. When installing the Dongar adapter I put a blanket over the windshield because the glare from outside made it hard to see. I noticed that when the mirror dims, it does so gradually.
    As I’ve placed it, the camera sits too close to the mirror to operate the button on the back without moving the mirror. But the camera accepts voice commands and works pretty well.
    The camera is invisible except for the pad of the adhesive mount at the upper left corner of the mirror.
  28. Mar 1, 2023 at 7:33 PM
    Here’s a still image from the camera. I was able to take the picture with a voice command.
    Thacrow likes this.
