White smoke.. With a twist
Discussion in '2nd Gen 4Runners (1990-1995)' started by mvincent, Mar 19, 2023.
  1. Mar 19, 2023 at 4:55 PM
    mvincent
    mvincent [OP] New Member
    Alright so my 3.0 is shooting white smoke out of the exhaust.
    It’s not overheating, coolant looks decent. But it only happens when it’s warm? Cold start no problem it won’t start blowing white until it’s warm. Any hot guesses?
  2. Mar 19, 2023 at 5:12 PM
    Daddykool
    Head gasket.
    negusm and watermelonman122 like this.
  3. Mar 19, 2023 at 5:12 PM
    mvincent
    Wouldn’t she smoke when she starts then? It takes about 20 minutes to get smoke.
  4. Mar 19, 2023 at 5:16 PM
    Daddykool
    Things expand when they heat up, which could open whatever gap there is. Is the oil cloudy after running?
  5. Mar 19, 2023 at 5:17 PM
    mvincent
    Oil looks fine, no bubbling in the coolant resi.
    I did just do my valve cover gaskets and had to disconnect a coolant line if that changes anything.
  6. Mar 19, 2023 at 5:21 PM
    Daddykool
    Maybe check the spark plugs for fouling or moisture. Might identify which cylinder(s) affected.
    watermelonman122 likes this.
  7. Mar 21, 2023 at 1:57 PM
    Kyle11863
    Kyle11863 King of the BS
    Big Bear California
    1990 Toyota 4Runner SR5 V6 5 Speed Manual
    Doug Thorley long tube headers and lots of mud
    Could just be a small blow which is why its not overheating yet, given enough time the blow could get worse and start overheating
    The other possibility is a bad intake manifold gasket but that’s not a common cause or failure for white smoke on these engines
  8. Mar 24, 2023 at 11:08 AM
    Get a tester kit. $40 and you'll know for sure.
  9. Mar 24, 2023 at 11:45 AM
    Oakboro, N.C
    Second this if you want to start checking possible issues off the list. Compression test, leak down test, Combustion leak test.
  10. Mar 24, 2023 at 11:47 AM
    importman
    importman The mountains are calling and I must go...
    Danny
    Carolinas
    05 Silver SR5 V6 4X4
    Blacked out, Ironman 3" Nitro Gas Suspension lift, JBA High Caster upper control arms, Differential drop and sway bar relocate, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX100 with Apple Carplay, USB Jack, Backup Camera, Black TRD Pro Wheels with General Grabber ATX 265/70/17, Rear differential vent extension, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Weathertech floor mats, Homemade rear storage compartment with built in pull out table.
    Maybe. On my 4th gen the test was inconclusive. The leak was so minor the only way I found it was pressurizing the cooling system and looking in the cylinder with a borescope. About every 45-60 seconds a single drop of coolant would trickle down the cylinder wall. But normally I'd fully agree with your advice to the OP.
