Which model is best?
Discussion in 'General 4Runner Talk' started by Lori, Jun 23, 2024.
  1. Jun 23, 2024 at 2:19 PM
    Lori
    Lori [OP] New Member
    My daughter is taking my 2013 Limited 4-runner with 20" wheels, 2wd. It has a really wide turning radius. I am in the market for a new one. Do any of the models turn better than others? Does it matter if it is 17 or 20" wheels?
    I know I need to get 4wd on my next 4 runner. I don't drive on any rough terrain but I do want to take it on the beach. Our sand is very soft and can be deep in areas. All models come in 4wd. I don't know anything about the technical aspects. Is there anything on the TRD or Ltd that would be better for the beach vs the SR5?
    Any advice would be appreciated.
  2. Jun 23, 2024 at 2:32 PM
    According to Toyota's website: chrome-extension://oemmndcbldboiebfnladdacbdfmadadm/https://www.toyota.com/content/dam/toyota/brochures/pdf/2024/4runner_ebrochure.pdf
    The turning circle for ALL models is 37.4
    All 4Runners do not come in 4wd, but MOST will. I'd guess about 80-ish % are 4wd. Then you have the Sport & Limited models that are heavily 2wd, or the rare one off SR5 or SR5P that's a 2wd. I've heard that the 4wd/AWD system on the Limited is great for snow/sand/ice.
  3. Jun 23, 2024 at 2:46 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    As stated above, the turning radius is what it is - wheel size won't change that. A smaller wheel (17" vs 20") would give you a bigger footprint in the sand if you air down, which would be an advantage.
    If you are unfamiliar with part time 4wd then I would stick with a limited or other model that has full time 4wd. However, I believe all of those come with the larger 20" wheels.
    I don't think the TRD (MTS and locker) would give you much benefit over the ATRAC system on the beach (which will be on the SR5 and maybe the limited trims?) - SR5 is going to be part time 4wd though.
    If it were me, I'd try to find a limited model or similar that comes in full time 4wd and then swap to 17" wheels (if it comes with 20's). If you are going to drive on the beach (or live near beach) then I'd also have it regularly sprayed with an undercoating to prevent rust.
    Caveat - my opinions are not always right
    icebear and RumHamRunner73 like this.
