Which interior fuses are constant power?
Discussion in '5th Gen 4Runners (2010-2024)' started by YotaMojo, Oct 17, 2023.
  1. Oct 17, 2023 at 10:20 AM
    YotaMojo
    YotaMojo [OP] New Member
    2023 4Runner TRD Off Road Premuim
    Anyone know which interior fuses are constant power? I’ve got a dash cam with parking monitoring and I want to hook it up but it requires a constant power fuse and I’d prefer not going through the firewall to the engine compartment fuse box.
  2. Oct 17, 2023 at 11:18 AM
    Use the 30A (P/Seat F/L) option. That has constant power:
    Also, hard wiring the dashcam for parking mode will cause the device to get REALLY hot. A lot of reviews have users saying that it causes the device to over heat, fail suddenly or shorten the over-all life of the device.
    Did you already buy the dashcam? If not, look into FitCamx. It's plug n play, no reason to hard wire it to a fuse.
    MeefZah, Rocko9999, Bob and 1 other person like this.
  3. Oct 17, 2023 at 1:48 PM
    HuskyMike
    HuskyMike New Member
    I just did this. The empty slot between Fog RR and AMI is constant power.
    Borracho Loco likes this.
  4. Oct 17, 2023 at 1:57 PM
    joshdub
    joshdub New Member
    2020 TRD ORP
    If you're going to be doing electrical work you should buy a multimeter.
    08TXRunner likes this.
  5. Oct 17, 2023 at 2:31 PM
    YotaMojo
    I have a multimeter and the dash cam has a wire tap set specifically for tapping in to the fuse box.
    HuskyMike likes this.
  6. Oct 17, 2023 at 2:31 PM
    YotaMojo
    Thanks Mike!
  7. Oct 17, 2023 at 3:59 PM
    HuskyMike
    No worries.
    To confirm this slot is correct, set your multimeter to DC Volts. With the vehicle off, touch the black probe to a ground point and the red probe to the wire on one side of the open slot (you'll see bare wire in there). Should read around 12v.
    For accessory power, I used the ACC fuse spot (lower right of image above), two fuses will go in your tap. The original from the slot and one for the camera (mine had the fuse for the camera already in wire tap).
    Magichands likes this.
  8. Oct 17, 2023 at 4:01 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    So if you have a multimeter then why do you need info on what fuse to tap?
    Rocko9999 likes this.
  9. Oct 17, 2023 at 4:05 PM
    HuskyMike
    Which camera does the OP have?
  10. Oct 17, 2023 at 4:12 PM
    That's a question that you should ask him, not me.
  11. Oct 17, 2023 at 4:13 PM
    HuskyMike
    You said his camera would overheat in parking mode.... I wondered how you knew that since I hadn't seen him post which camera he had.
  12. Oct 17, 2023 at 4:14 PM
    I was speaking in general terms. I have seen reviews for many styles of cameras that mention overheating when left in parking mode.
  13. Oct 17, 2023 at 4:15 PM
    HuskyMike
    Got it. As I just purchased and installed one with parking mode (A139 Pro), you piqued my curiosity.
  14. Oct 17, 2023 at 5:18 PM
    08TXRunner
    '20 SR5P
    He doesn't. He's in every thread and just bought a 4Runner three weeks ago.
  15. Oct 17, 2023 at 5:21 PM
    So, I can't offer advice or be a part of this community until I've passed a certain time on this site threshold?
  16. Oct 21, 2023 at 12:07 PM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Does plug in console?
  17. Oct 21, 2023 at 12:41 PM
    Oakboro, N.C
    I went out and checked and I have a Nextbase 522GW with a motion control sensor that will power on if motion is detected. Have had this installed over a year with zero issues on the 4Runner. It Is hard wired for what it is worth. In this day and time, In my opinion, A dash cam is pretty much a necessity with the way society has evolved....
    https://nextbase.com/dash-cams/522gw-dash-cam
    czekchik78 likes this.
  18. Nov 6, 2023 at 8:18 PM
    czekchik78
    czekchik78 New Member
  19. Nov 6, 2023 at 8:18 PM
    czekchik78
    which interior fuse box spot did you use? i just purchased the same next base 522 with hard wire kit
  20. Nov 8, 2023 at 4:31 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Can you post any pics where you installed?
  21. Nov 8, 2023 at 4:39 PM
    Oakboro, N.C
    Kinda dark out in the garage, But here is one from the front and inside.Also has a quick release to remove with out unplugging any wires as the connector is in the quick disconnect.
