Which bump stops? (so many options)
Discussion in '5th Gen 4Runners (2010-2024)' started by SLIVER, Jan 31, 2024.
  1. Jan 31, 2024 at 6:39 AM
    SLIVER
    SLIVER [OP] New Member
    Hey guys, I am done with the suspension components on my T4R and now need to upgrade the bump stops so they are functional with the lift. I am wondering what brand you recommend?
    I have a 3" lift with 285/75/17's and Fox 2.5's. The stock bumps are way short in the back. I have also seen people use spacers and keep their stocks?
    What do you guys suggest?
    Timberen, Sumo, Durobumps, Superbumps, Wheeler....So many to choose from.
    Thank you for any advice you can give.
    ))--SLIVER-->
    kolter45 and djwantke like this.
  2. Feb 1, 2024 at 9:35 AM
    SLIVER
    I see all of these options have stumped you guys as well........
  3. Feb 1, 2024 at 9:51 AM
    If you lift and then use extended bump stops, what are you gaining?
  4. Feb 1, 2024 at 9:55 AM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Additional ground clearance and better approach and departure angles.
  5. Feb 1, 2024 at 9:58 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    I have 2.5" lift with Elkas and went with Durobumps.
    djwantke and Toy4X4 like this.
  6. Feb 1, 2024 at 9:58 AM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    Any of them will be better than nothing but I like the Sumo due to their progressive nature.
    djwantke likes this.
  7. Feb 1, 2024 at 10:03 AM
    2021venture
    Todd
    2021 Venture
  8. Feb 1, 2024 at 12:02 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    i went wheelers for my taco & have had no problems for over 4 years
    wheelersoffroad.com/shop-by-category/superbumps.html
  9. Feb 1, 2024 at 12:47 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    You'll need them if you upsized your tires. 35 inch tires will rub pretty badly w/out massive body cutting, or use a bump stop and plan on extending your break lines (assuming your lift is balanced).
    djwantke and Slopemaster[QUOTED] like this.
  10. Feb 1, 2024 at 1:09 PM
    kolter45
    Denver
    Also if you go 3" or more get extended brake lines
  11. Feb 1, 2024 at 1:46 PM
    3JOH22A Toyota Gigolo
    For the front, I'm running Energy Susp 8.9104G urethane bumpstops - these are a good value and feel cushy.
    For the rear, I'm running Wheelers WOR-306952 Super Bumps. They are a bit longer than stock. Wheelers sells puck spacers for them if you need more length.
  12. Feb 1, 2024 at 1:49 PM
    2021venture
    Todd
    2021 Venture
    It hurts every time I see rust pics from you guys living up in rust belt.
    Bluesky 07, Schlappesepple and nova like this.
  13. Feb 2, 2024 at 11:56 AM
    SLIVER
    Thank you guys for the info! I am running a 3” lift. 34” tires and have extended brake lines. these are the last piece of the suspension puzzle for me.
    I appreciate your comments and recommendations.
    ))—SLIVER—>
    Harringbr99 and djwantke like this.
  14. Feb 2, 2024 at 7:42 PM
    Do your Fox 2.5 shocks have the same travel range as stock? If they have the same lengths fully compressed and fully extended as stock shocks, then why do you need taller bump stops? Wouldn’t that restrict your up-travel unnecessarily? 33s should fit in the rear wheel well with no problem.
    edit: I just realized they’re closer to 34”. Do they rub in the rear?
  15. Feb 2, 2024 at 8:08 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I've been eyeing the same ones you got, thanks for this, I gotta get this done. So far I've ignored brake lines after my 3/2 suspension upgrade/lift springs :anonymous:
    What length you think your Energy's are, and same question bout the Wheelers? (I'll check ur links as well)
    Thanks
  16. Feb 3, 2024 at 8:18 AM
    djwantke[QUOTED] likes this.
  17. Feb 3, 2024 at 8:23 AM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Silver ‘07 Sport V6 4WD @ 265K miles
    “Deep” Satoshi grille | X-REAS delete / TRD Offroad front springs & Bilstein 4600 shocks + FJC rear springs | Weathertech front & rear mats | Tinted front windows | Floor Armor cargo mat | TPMS bypass | LED interior, tag, & reverse lights | BlueSea Systems console USB power ports | Gentex 453 autodim mirror w/Homelink & compass | Kenwood DDX373BT HU + Audiovox backup camera | Fumoto F-103S | Bazooka tube subwoofer | Kenwood speakers & KAC-M1804 amp | Philips H9/9011 headlight bulbs | Rexing V1 Gen3 dash cam | Map light mod | Breather mod | Off-road Nav Setup | Power Stop Z36 brakes | OBD Fusion diagnostics
    I have Wheelers. Product 9, lead time 2, customer service 2.
  18. Feb 3, 2024 at 9:09 AM
    mcat707
    mcat707 MURDERED TRD
    NOR*CAL - Solano County
    2015 TRDPro - Attitude Black Metallic 218
    I got a pair of the extended OEM rear bump stops from the GX470. They mount right on my 2015 T4R. If you’re feeling frugal, you can get a cheap aftermarket set for around $40.
    3JOH22A likes this.
  19. Feb 3, 2024 at 9:15 AM
    mcat707
    yeah, so glad we don’t have that problem here in Northern California.
    We just have to deal with the higher cost of living and other stupid California bullshit.
  20. Feb 3, 2024 at 9:56 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Somebody posted a little-known, small shop with their own bump stops at a great price, and I can't find the dang thread now.
    Edit* Found it, never used em, but here's another option.
    https://www.perryparts.com/4runner-5th-gen
    hossler1788 and djwantke like this.
  21. Feb 3, 2024 at 10:16 AM
    aesthetics
    aesthetics New Member
    I had the energy suspension in front and extensions in the rear.
    Now running full perryparts the rear definitely made a difference the fronts have a much more progressive damping vs the energy but both are very good.
    I still keep my old bumps in the truck at all times, we'll see how the 3d print holds up.
  22. Feb 3, 2024 at 10:35 AM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Similar elkas but sumo springs.
  23. Feb 3, 2024 at 11:48 AM
    Of course they are up in price eh, f me for waiting lol
    I can have the Prime Minister and President to thank, fo real.
    Thanks very much for linking this for me
  24. Feb 3, 2024 at 6:38 PM
    53caddy
    53caddy New Member
  25. Feb 8, 2024 at 10:18 AM
    4R Florida
    4R Florida New Member
    Northeast Florida
    2024 4R Off Road
    Newbie here so be patient if I ask a silly question. :)
    I'm getting ready to buy a 2024 4Runner TRD Offroad with 4WD and I want to pick the front up about 1" with spacers to level it a little. Do I need to do anything to the bump stops? Down near the bottom of the article, this link suggests adding washers as spacers?
    https://trail4runner.com/2020/12/02/how-to-fix-driver-side-lean-on-5th-gen-4runner/
    "One thing you may also want to consider is adjusting your bump stops. The general rule of thumb seems to be that the factory bump stops will still work with 1/4” thick top spacers. Anything more than that and you run the risk of over compressing the coilover shock under a hard compression.
    To solve this, you can unscrew the bump stop and add a few washers on top to space it down some so that it makes contact sooner than the factory position ..."
  26. Feb 8, 2024 at 10:28 AM
    CRasch505
    CRasch505 New Member
    Chris
    5th Gen 4Runner ORP
    Fifteen52 Analog HD's, Nitto Terragrapplers, 1" spacer lift front, ceramic on all glass.
    It's all over the place and, from what I understand, it depends on what you use the truck for. Apparently light offroading won't be an issue on factory stops. Moderate lifts around 2'2.5" may also not need them. On the other had, I've had folks tell me that any change needs new stops. I could also just be a simpleton. Haha
  27. Feb 8, 2024 at 10:31 AM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    I don't intend to do anything offroad, although I do sometimes get into some sticky situations when camping and adventuring in the mountains of North Carolina. I actually bent a wheel on my FJ Cruiser on a very bad forest "road" when I fell into a hole that I didn't think was as deep as it was. Oops. So if something like that hole comes along again, I want to be ready for it.
  28. Feb 8, 2024 at 11:02 AM
    CRasch505
    Chris
    5th Gen 4Runner ORP
    It may be worth it if the concern is that large. If you're just worried about the fronts, Energy Suspension seems to be super popular and super affordable.
  29. Feb 8, 2024 at 11:35 AM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    Yes, front only. I just want to shim it up about 1" in the front (1/2" spacers) to level it a little. The Energy Suspension linked in this thread says "rear" when I go to the link. I have no idea if they are correct for what I want to do. I didn't even know what a bump stop was until last night. :confused:
  30. Feb 8, 2024 at 11:38 AM
    CRasch505
    Chris
    5th Gen 4Runner ORP
    They're "rear" but the 4Runner rear is 2 bolts rather than 1 so it doesn't work in the back on our applications. However, lot's of folks use them in the front. I'm going out today to articulate the suspension in some nearby hills and see what contacts where or if I even need the stops. We will see.
    4R Florida[QUOTED] likes this.
