Wheel / Tire question...
Discussion in '5th Gen 4Runners (2010-2024)' started by chan2018, Jun 15, 2023.
  1. Jun 15, 2023 at 11:13 AM
    chan2018
    chan2018 [OP] New Member
    2018 Barcelona Red 4Runner
    Good Afternoon all -
    I am currently running a 285/70/17 falken a/t wildpeaks on trd wheels with pro comp nitro 2 inch rear/ 3 inch front level kit 65210K
    I am looking to change out my wheels for the RAY10 SCS wheels in dark bronze. Sorry if this has been asked or answer....
    Will the RAY10 SCS wheels
    17 X 9 6 X 139.7 3.50" -38mm offset - fit my current tire? Could I simply change out the wheels or due to offset will I have to trim/modify anything?
    Picture is my current wheel setup.
  2. Jun 15, 2023 at 12:18 PM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    The tires will fit the wheels. But if they don't rub now, they will once you push them out over an inch and a half...scrub radius...
    chan2018[OP] and 08TXRunner like this.
  3. Jun 15, 2023 at 1:09 PM
    chan2018
    I’m not planning on adding spacers or anything. I’m just wondering if I swap out the wheels as the setup is now will they still rub? Sorry if that’s what you were saying and I misunderstood
  4. Jun 15, 2023 at 1:12 PM
    mainerunr
    Maine
    '23 TRD ORP
    Going from a +4 offset to a -38 offset is going to push the wheel out 42mm (about 1-5/8"), that means a larger scrub radius.
    hopefully someone with similar wheels can chime in since I still have stock size tires on oem wheels (TRD Off Road which have a +15 offset). I would expect a lot of rubbing (but I could be wrong).
  5. Jun 15, 2023 at 3:42 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    08TXRunner and chan2018[OP] like this.
  6. Jun 15, 2023 at 3:57 PM
    chan2018
    Thank you so much! And the video is great. Makes it easy for people like me to understand :))) appreciate all the feedback guys
    CalcityRenegade likes this.
  7. Jun 15, 2023 at 4:09 PM
    Mtbpsych
    Mtbpsych New Member
    Yes you will rub. What will rub, you’ll have to install and find out after alignment. I have 295’s, just a tad wider. I had a to remove my rocker panels, trim the front bumper, and get a BMC. I still rub a little when the tire is stuffed into the wheel well.
    chan2018[OP] likes this.
  8. Jun 15, 2023 at 5:05 PM
    chan2018
    Damn. Guess I need to find a decent shop around me lol… thanks guys!
