Wheel size offset
Discussion in 'Wheels & Tires' started by Gatus1, Jun 18, 2024.
  1. Jun 18, 2024 at 2:57 PM
    Gatus1
    Gatus1 [OP] New Member
    Hi everybody,
    New at the forum and in the 4runner world.
    I recently changed tires to my 2021 4Runner (KO 3's 265/70r17) and I want to change wheels. I have a couple of options I'm liking that I know will work and there will be no rubbing.
    Every shop I went they said go to Wheelpros.com and see what works in your car.
    Here is where the confusion starts.
    There are a couple KMC and Black Rhino's that are 17x8.5 with 00 offset that I'm certain won't rub and that I'm digging.
    Also some Black Rhino's that are 17x9 00 offset that I think will be fine. Also liking.
    I'm loving (looks) some Black Rhino's that are 17x8.5 but -10 offset.
    Wheelspros.com is saying I should be fine. Would I encounter any issues?
    I won't be doing tons of off roading to be honest.
    If I had to choose in terms of look (also mostly driving in the city with some exceptions)
    My favorites are the BR 17x8.5 -10offset.
    I'm liking the others also.
    Should I keep the offset at 0?
    Please help a newbie out!
    Thanks!
  2. Jun 18, 2024 at 3:14 PM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
  3. Jun 18, 2024 at 3:42 PM
    JChiz
    JChiz Old Member
    South Of Tucson, AZ
    Welcome from Arizona. So many options....
  4. Jun 18, 2024 at 4:23 PM
    welcome
  5. Jun 18, 2024 at 9:16 PM
    Bagman
    Bagman Dental Floss Tycoon
    Georgia
    This should help
  6. Jun 19, 2024 at 6:31 AM
    java
    java fauxrunner
    2023 ORP ice cap
    5thToy and Old Tanker like this.
  7. Jun 19, 2024 at 6:47 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    17x8.5 -10 isn't really much more aggressive than the 0 offset option.
    The wheel will only poke out .4" more than the 0 offset.
    This was my setup with a 3" lift, 285/70/17s wrapped around 17x8.5 -12
    I had to remove the front mudflaps. But didn't need a body mount chop. YMMV
    I've changed the setup quite a bit since these photos were taken:
    ^This is a good example of why I changed the setup since then. I wanted a little more tire poke.
    Without a lift a -10 offset should look pretty good and should require very little modification especially with 265/70/17s.
    IMO once you go with a 2.5" or 3" lift tires start looking small. I off road often enough to justify stepping up a size... so I made the jump to 34's, added spidertrax spacers, aggressive BMC, clearance cut the front bumper. The rig is much more capable off road now. If you're interested to read about what that took I'll post a link here.
    https://www.4runners.com/threads/picture-request-38-offset-wheels.38055/#post-586115
  8. Jun 19, 2024 at 11:31 AM
    Gatus1
