Wheel Shake 4R PRO
Discussion in '5th Gen 4Runners (2010-2024)' started by 4HI4LO, Oct 16, 2020.
  1. Oct 16, 2020 at 6:31 PM
    4HI4LO
    4HI4LO [OP] New Member
    T4R ORP W/KD
    I test drove both 4Rs and have a question about the wheel shake I’ve experienced with the Pro after reaching 60 MPH - is that normal?
  2. Oct 16, 2020 at 6:33 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    A lot of them seem to have balance issues from the factory. I had to have them road force balance mine and it fixed it.
    I’m on new tires now and still fine
    nimby and 4HI4LO[OP] like this.
  3. Oct 16, 2020 at 7:13 PM
    Dark Knight
    Dark Knight Get off my lawn
    It also depends on how long it has been sitting. If mine sits a while I feel a shimmy for about 5-10 miles then all is smooth again.
  4. Oct 16, 2020 at 7:23 PM
    Mine did it when it was stock (SR5, not Pro).
    When I got new tires it completely went away.
    As mentioned above, it's usually a tire balancing issue. Our trucks are pretty sensitive when it comes to that.
    If a truck is sitting on the lot for a while, the tires could develop flat spots which will also give you the shakes.
    4HI4LO[OP] likes this.
  5. Oct 16, 2020 at 7:40 PM
    4HI4LO
    T4R ORP W/KD
    Great to hear guys! I’m still at the dealer - let’s see how this shit show ends :rockband:
    nimby likes this.
  6. Oct 16, 2020 at 7:52 PM
    Alfa1
    Alfa1 New Member
    Dominic
    2020 Nightshade
    :popcorn:
  7. Oct 16, 2020 at 7:53 PM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Well if you’ve got an opt out notice in front of you your deal is most likely coming to the close
    4HI4LO[QUOTED][OP] likes this.
  8. Oct 16, 2020 at 8:32 PM
    jvinhj240
    jvinhj240 New Member
    Ben
    for sure balance issues. I have same problem with 60mph, first day 50mile no problem then second day i start have vibration. However I put new wheel on my now vibration totally gone.
    TRDPro916 and 4HI4LO[OP] like this.
  9. Oct 17, 2020 at 4:47 AM
    ThePnsh3r
    ThePnsh3r New Member
    2020 TRDOP
    I would absolutely not pick it up with that issue though. It is beyond unacceptable to have that on any new car, never mind something that costs $40k. Get a promissory note for free road force balance and tire replacement if not resolved by balancing.
    Could be a flat spot for sitting too long, or could be bad balance , or even a defective tire that won’t balance right. Either way, should not be your hustle when buying a new car.
    Good luck
    4HI4LO[OP] and jvinhj240 like this.
  10. Oct 17, 2020 at 5:00 AM
    jvinhj240
    Ben
    ^^I buy many Toyota in the past. Sienna is mostly the problems , so what was weird is their alignment software never up to date. for example I buy 2016 got problem. the system don't cover that year, then 2019 again same problem , their system don't cover 2019. Even I go to Bridgestone tire last month, their software still not able to do alignment in my car. I ended up took to me friend who own High end body shop they updated theirs.
    Now this is my first time balance issues. I don't bother go back to dealer, cuz I was already wanted to replace TRD pro wheel.
  11. Oct 17, 2020 at 7:00 AM
    ForRun
    ForRun 4Runner
    2020 orp
    I read this issue many times before buying. When I test drove my 19 and 20. Each time I drove them up to 60 on a smooth road. salesman said it was the road... the 2nd runner on same road, same speed was smooth as silk so I bought it.
    On my 20 I made sure dealer had multiple runners fitted the way I wanted them. He had 6 gray ones. Again it took 2 and found a non shaker
  12. Oct 17, 2020 at 7:06 AM
    4HI4LO
    T4R ORP W/KD
    Went with the non-shaker - new to all this just didn’t want to deal with any issues out of the gate
    nimby and ForRun like this.
