Wheel Question
Discussion in '5th Gen 4Runners (2010-2024)' started by Edjoe4Runner, Nov 4, 2024 at 8:39 AM.
  1. Nov 4, 2024 at 8:39 AM
    Edjoe4Runner
    Edjoe4Runner [OP] New Member
    Today
    New to the forum. We just got a 2016 4Runner trail. It has the stock wheels (17 x 7.5). We want to swap out the wheels to an OEM wheel (Black). APPEARS there is 2 to pick from BUT I can't find any true answers.
    Wheel 1
    This wheel is a direct fit: PTR20-35110-BK I very confident they fit no questioned ask.
    Wheel2
    On the otherhand this wheel PTR56-89210-F2 we really like ... BUT it says 2022 - 2024 only. Everything I can see it has the same exact specs. So why does Toyota say not to use on a 2016 model? The offset for both wheel will be the same 4mm
    THANKS !!!
  2. Nov 4, 2024 at 8:47 AM
    cuse93
    cuse93 Ice Station Zebra
    both will fit fine. one is a slightly older style and uses a different center cap.
  3. Nov 4, 2024 at 10:51 AM
    Ironguy New Member
    Welcome to the forum!
  4. Nov 4, 2024 at 10:53 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Based on your post, Toyota does not say not to use on a 2016 model.
  5. Nov 4, 2024 at 11:04 AM
    Manhattan
    Manhattan New Member
    Keep in mind, the wheels you're looking at are 7" wide - not 7.5". That will only matter if you go wider than stock - some shops may not mount wider tires on the 7.0" wheels. But lots (!) of guys have gone to 285/70/17 on the 7" wheels.
  6. Nov 4, 2024 at 11:09 AM
    Edjoe4Runner
    Today
    Using the stock tire size 265/70/17
    Manhattan likes this.
  7. Nov 4, 2024 at 11:54 AM
