Wheel question
Discussion in '5th Gen 4Runners (2010-2024)' started by afret, Nov 6, 2021.
  1. Nov 6, 2021 at 9:22 PM
    afret
    afret [OP] 2022 ORP, KDSS, Toyo AT3
    North Idaho
    I have a 2022 Limited on "order" and don't care for the 20" wheel. I'm going to go to a 17" wheel and kinda like the ones on the SR5. I see a lot of SR5 takeoffs for cheap. Any fitment problems with a Limited and the SR5 wheels using the stock SR5 265/70-17 tire size?
  2. Nov 6, 2021 at 9:55 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    Should be fine
    Thatbassguy and Toy4X4 like this.
  3. Nov 7, 2021 at 4:54 AM
    Like @Daytonaviolet said, should be fine. I like the SR5 wheels as well.
    If you shop around, you might even find a set with TPMS sensors.
    4R21 likes this.
  4. Nov 7, 2021 at 6:38 AM
    afret
    North Idaho
    Thanks for the great info! Do you know if the lug nuts are different between the Limited and SR5 wheel?
    Do any of you switch between winter and summer tires by having 2 sets of tires/wheels? What do you do about getting the car to relearn the TPMS sensors so the warning light doesn't come on?
  5. Nov 7, 2021 at 6:48 AM
    I have 2 sets of wheels and tires. I just ignore the tire pressure light. :D
    There is a way to make it learn. I'm sure someone around here knows.
    suaveflooder likes this.
  6. Nov 7, 2021 at 7:28 AM
    afret
    North Idaho
    That will work. Just get a piece of back tape over the light. :)
