Wheel clearance
Discussion in '5th Gen 4Runners (2010-2024)' started by SCyota, Oct 21, 2020.
  1. Oct 21, 2020 at 5:37 PM
    SCyota
    SCyota [OP] New Member
    Question for you guys...will 285/70/17s clear the UCAs and the cab mounts with just a stock suspension if I get wheels with a 0 or slightly negative offset?
  2. Oct 21, 2020 at 5:42 PM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Depends on tires. Some run smaller, like BFG, and would probably work without an issue at 0mm offset or a 7.5 or 8.5" wheel. 9" wheels...also probably...
    -12mm offset yes, but you'll have more rubbing on that offset to trim for.
    As far as will you clear UCAs on stock suspension, probably. Will you clear Cab mounts, probably not even close. I got my 265/70/r17 to rub with a 2.5" lift on -12mm offset wheels (8.5"), I imagine you'll rub pretty hard. At a minimum, mudflaps and front valance trimming will happpen.
  3. Oct 21, 2020 at 6:56 PM
    Mtbpsych
    Mtbpsych New Member
    You should clear UCA’s but will more than likely rub on the cab mount/pinch weld area.
    You’ll need to do quite a bit of work to get them to fit properly at stock height.
  4. Oct 21, 2020 at 8:34 PM
    SCyota
    Thanks for the info guys.
