What's with the fog light shroud?
Discussion in '5th Gen 4Runners (2010-2024)' started by Burnt Taco, Nov 29, 2021.
  1. Nov 29, 2021 at 2:29 PM
    Burnt Taco
    Burnt Taco [OP] "Like that's just your opinion, man".
    Tucson, AZ
    '22 ORP, Wife's 2020 SR5
    Just finished installing DD SS3 Pro fog lights on my '22 ORP. Took the passenger side shroud off and did a half a$$ job trying to get it back in. Said f- it as it doesn't seem to provide a significant function. If it did then why isn't there one on the driver's side as well??? Seems I heard that someone else ditched it as well.
  2. Nov 29, 2021 at 2:34 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Probably to keep the lights from blinding oncoming traffic.
  3. Nov 29, 2021 at 2:41 PM
    Burnt Taco
    Tucson, AZ
    The shroud was up inside and behind the wheel well covering on the passenger side fog light. No shroud on the driver's side.
  4. Nov 29, 2021 at 2:46 PM
    I know I read something on that back when I put in the DD SS3 fog lights last year, but for the life of me I can't remember what was said. Mine wasn't too difficult to get back in, so I left it in place...some, as you said, ditched it, and most likely never had any issues with it.
  5. Nov 29, 2021 at 3:48 PM
    Gstick
    Gstick New Member
    19' TRD OFF ROAD
    Some claim that the cover over the right side fog light is to protect from spillage if you overfill the washer reservoir. I have no factual data on this tho'.
    Firefly21 likes this.
  6. Nov 29, 2021 at 4:06 PM
    SYTY
    SYTY New Member
    THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
    There are vents cut out on the pass side inner Fender well, I think it might be to cover the fog from posable splashing through the wheel well from tire.
    Bear76 likes this.
  7. Nov 29, 2021 at 4:30 PM
    Burnt Taco
    Tucson, AZ
    Ok, ok. I'll re- install it.
    peter2772000 likes this.
  8. Nov 29, 2021 at 5:10 PM
    SYTY
    SYTY New Member
    It is a pain in the A$$ to put back on, I was going to leave it off then i saw the vents in the wheel well and just put it back
  9. Nov 29, 2021 at 5:55 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    @SYTY got it. It’s a splash shield. And it’s a pain to reinstall. I kind of mangled the tabs removing it so I got it back together the best I could and dabbed some glue around the tab area to hold it in place.
  10. Nov 29, 2021 at 7:42 PM
    Burnt Taco
    Tucson, AZ
    Duh. So that's what they meant when they said "use a flat blade screwdriver on each side to release the shroud fasteners".
    Lesson learned.
    Sheesh.
    peter2772000 and Stumpjumper21 like this.
  11. Dec 1, 2021 at 2:55 AM
    Burnt Taco
    Tucson, AZ
    Shroud reinstalled. Lovin the DD SS3 amber (yellow) fogs.
