What went wrong?
Discussion in '2nd Gen 4Runners (1990-1995)' started by No tine, Oct 21, 2021.
  1. Oct 21, 2021 at 3:56 PM
    No tine
    No tine [OP] New Member
    90 red 4 runner
    Hi all I’m new here and looking for some help.
    I just replaced the clutch and slave cylinder and when I went to bleed the slave the pedal went to the floor and stayed there.
    Any ideas what I may have done wrong? I did replace the throw out and pilot bearing as well. I hate the thought of having to rear this down again.
    Thanks for your thoughts.
  2. Oct 21, 2021 at 4:02 PM
    I can’t help you with your problem, but good to have you on board. Someone should be along soon to help.
  3. Oct 21, 2021 at 4:54 PM
    SYTY
    SYTY New Member
    THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
    pull the pedal back don’t go all the way to the floor when pumping, you may need to do it with your hand a few times until you start getting a pedal. Check for leaks first and make sure the fluid stays full when bleeding
  4. Oct 22, 2021 at 7:35 AM
    No tine
    90 red 4 runner
    It seems as though the spring tension on the fork is pushing the fork away from the slave rather than towards it. I just don’t get what the hell is going on.
    Ill keep at and try to come up in with a plan.
  5. Oct 22, 2021 at 8:12 AM
    No tine
    90 red 4 runner
    Ok so I’m all set. I got desperate and asked a guy on the street to help me out bleed the system and I now have my pedal back.
    thx all
    Tonyota likes this.
