What PSI are you guys running?
Discussion in 'Wheels & Tires' started by Stoney Ranger, Apr 21, 2021.
  1. Apr 21, 2021 at 1:14 PM
    Stoney Ranger
    Stoney Ranger [OP] New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
    Gettin' Falken Wildpeaks 275/70R 17's installed (whenever they show up at the store). 4R has a 1" front spacer, rear is stock. 2018 SR5. No body armor and no heavy mods are planned.
    I have seen the "chalk test" vids, but was curious what you guys are running on the hi-way for PSI in your 275's?
    mrmike7189 likes this.
  2. Apr 21, 2021 at 1:19 PM
    doublewide
    doublewide ShittCo
    TRD OR PREM
    General Grabber AT/X 275/70R/17 E load rating. On the road, 38. On trails, anywhere from 20 to 14, just depends on where I'm at and what I'm doing.
    POWERPLANTHOMER likes this.
  3. Apr 21, 2021 at 1:19 PM
    285 45psi.
    What load are those tires.
    ruiz4251 and Thatbassguy like this.
  4. Apr 21, 2021 at 2:27 PM
    SR5 Stock weight
    BFG KO2 265/70R17 Load C + SR5 Wheels - 34 -35 psi
    TRD ORP (almost stock) - Full skids (Front A-Arm to Rear Diff skid) + sliders
    BFG KO2 275/70R17 Load E + TRD ORP Wheels - 32 psi (since they are firm, to get slightly better ride) - Changed to KO2 285 Load C
    BFG KO2 285/70R17 Load C + TRD ORP Wheels - 34psi
    Limited Stock weight
    Falken Wildpeaks P285/70R17 (Standard Load) + TRD ORP Wheels - 32Psi
  5. Apr 22, 2021 at 2:41 AM
    Cooper AT3 275-70-17 LT's 38PSI on highway 24PSI on trail
  6. Apr 22, 2021 at 4:54 AM
    Stoney Ranger
    Driftless Area
    '18 SR5 Nauti Blue
    This info is very helpful. I have '96 Silverado (you wouldn't believe it's a Wis truck, very little rust )with Goodyear Wrangler Silent Armor, 10 ply sidewall, and I run 50-52 psi in those. Hence my question on what you guys run.
  7. Apr 22, 2021 at 7:56 AM
    brownersd
    Sean
    Humble, Texas
    Also, Toyo Country AT III, E Grade, running at 38PSI for day to day driving. Haven't taken them off roading yet...
    Cheers,
    Sean
    mrmike7189 and Thatbassguy like this.
  8. Apr 22, 2021 at 10:29 AM
    According to the tire pressure genie, an LT 275/70/17 should be run at 41 PSI on our trucks. I would start there and adjust as needed.
    FWIW, I ran LT/C 265's at 35 and was happy with the results, so it's worth experimenting. I definitely wouldn't go below 32 on the road, though. FWIW, I'm on LT/E 295/70/17's and run 35 PSI on the road, and probably going to vary from ~12-25 off-road.
    brownersd, Toy4X4 and ruiz4251 like this.
  9. Apr 22, 2021 at 11:19 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    38-40
  10. Apr 22, 2021 at 11:32 AM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    45fnt 42/43bck on 285 duratrac E
    4R load and weight/mods plus as mentioned above tire squishyness will help determine psi
    Play around with it (psi) see.what different psi feels like and take it from there
    Tip: notes help
    This tire psi too squishy
    This tire psi too firm
    This tire psi is juuussstt right
    Goldilocks method LMAO
    catus and Toy4X4 like this.
  11. Apr 22, 2021 at 12:59 PM
    Fortuner
    Fortuner New Member
    CA
    2021 4Runner TRD Off Road Premium w/KDSS
    BFG KO2 275/70R17 Load E - 36 PSI Cold. This was the sweet spot after a couple weeks of "testing." Originally the tire shop had them set to 50PSI, which made it feel like I was driving on tiny rocks all day.
    Now if I can only get rid of this steering wheel shimmy above 55mph...
  12. Apr 22, 2021 at 1:14 PM
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    52 psi on my stock Duelers (LOL ok not really, but that WAS the psi when I took delivery. I actually drove like 800 miles at that pressure until I finally checked to see if the dealer had set them up properly -- doh!)
    ATM they're about 37 cold, but only cause I'd set them to about 33 when it was like 20 somethin degrees outside. Door jam sticker thingy says they should be 32. I haven't noticed any problems at 37 (though I do have more steering correction than I'd like at highway speeds, which I've attributed to the thing being a big block of a truck etc etc, but prob also low-ish caster). Anyway I think I'll try them out at 32 and see if anything changes.
    Note I'm not hauling anything especially heavy etc. Just normal on-road use...
  13. Apr 22, 2021 at 4:00 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    I run 285 KO2s at 38. They’re E rated LT tires.
  14. Apr 22, 2021 at 5:48 PM
    Stoney Ranger
    Driftless Area
    '18 SR5 Nauti Blue
    brainh18, brownersd and Toy4X4 like this.
  15. Apr 22, 2021 at 6:51 PM
    GoSlow
    GoSlow New Member
    2021 TRD ORP Nautical Blue
    40psi
    Toy4X4 likes this.
  16. Apr 23, 2021 at 11:14 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Don't bother. Or, maybe I'm just dumb. I tried the chalk test on my 4Runner and it was a big waste of time. No matter what pressure I chose, the chalk wear was always the same.
    You also just plain don't need to do it. The tire manufacturers and engineers have already figure this out for us. There's something called "Inflation Tables" that list the recommended/required pressure based upon tire size, type, and vehicle weight. For ALL LT tires, that number is ~39 PSI for the 4Runner.
    Whoever started the myth that we need a "chalk test" for basic LT tires should be slapped. However, I could see that test coming into use if you're putting 40" mud tires on a vehicle.. that for some reason you plan to drive on the street.. lol.
  17. Dec 11, 2022 at 3:43 PM
    RSD
    RSD New Member
    2017 TRD PRO
    Nitto Terra Grappler G2 LT265/70 17 E Rated on stock TRD-Pro: 43psi. Nitto provides a tire pressure chart for vehicle and Nitto tire sizes https://www.nittotires.ca/search-results?vid=148651 I find the G2s (43psi) provide much better handling on pavement than the former P-rated Terra Grapplers (32psi) that came on the new truck. The TRD-Pro suspension is tuned for running desert tracks, dirt roads and is somewhat soft. The soft suspension contributes to greater lean on curves. The stiffer sidewalls on the E-ratred G2 result in much less lean. This is very apparent on twisty mountain roads and steep, sharp downhill curves on fast interstates. The ride is a bit firmer on highways and quite a bit firmer/rougher off road. I would recommend against running these G2 E tires below 38psi on highways; five hours or so at 75mph is bound to weaken sidewalls and risk overheating and blowout, if not on one trip, then on subsequent ones. So far, I've run the G2s at 28-32psi off road; it helps a bit with rough ride and traction. I'll probably go a bit lower in future depending on road conditions. I chose to run the E tires out of concern over a flat tire in remote areas I often travel alone; I've often encountered sections of road/trail with sharp rocks. Gas mileage about same as P tires.
  18. Dec 11, 2022 at 4:02 PM
    HotelMedicis
    HotelMedicis No Commercial Interests
    38 psi. Stock tires. 2023 SR5
  19. Dec 11, 2022 at 4:33 PM
    mrmike7189
    mrmike7189 New Member
    mike
    2020 silver SR5 4x4
    I have tried 32psi up to 39psi and I think the P size Standard load tires somewhere within lies the sweet spot.
    Toy4X4 likes this.
  20. Dec 12, 2022 at 1:48 AM
    Cooper AT3 LT's 275-70-17 @ 38psi. in the summer, 36psi. in the winter. They have 20K miles on them, 3/4 of the tread left... or there abouts.
  21. Dec 12, 2022 at 7:09 AM
    Commited
    Commited New Member
    Oscar
    So Cal
    2019 Silver Metallic TRD ORP
    Tinted fronts, blacked out overlays.
    285/70/17 KO2’s 35-36 PSI
  22. Dec 23, 2022 at 9:31 AM
    Gstick
    Gstick New Member
    19' TRD OFF ROAD
    BFG KO2's LT265/70/17 Load Range C (6ply) on OEM TRD OR wheels 39 lb cold.
    Goodyear Duratracs 255/75/17 Standard Load on OEM SR5 wheels 36 lb cold.
    Elvis4R likes this.
  23. Dec 23, 2022 at 9:53 AM
    This is my Runner with Falken 285/70/17 MT’s with about 30,000 miles on them, i run 44 psi. in thefront and34 psi. in the rear. Unless i load it down, then i adjust the air.
  24. Dec 23, 2022 at 10:18 AM
    ToyotaRDie
    ToyotaRDie New Member
    I follow what it says on the door panel, even with bigger tires. I know people do differently but I feel the psi on the door is there for a reason based on vehicle weight, size and point of gravity, for safety.
    Toy4X4 and Trail Runnah like this.
  25. Dec 23, 2022 at 10:24 AM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    The placard on the door post is for the proper pressures based on the wheels and tires the truck was first sold with. For anyone that makes any changes to the wheel size, tire size and type - the placard is no longer the standard. But it is your truck, and you and your families' lives - do what you think is best. However, I would suggest doing some research just in case you might be wrong.
    Toy4X4, Piney and Thatbassguy like this.
  26. Dec 23, 2022 at 1:01 PM
    Like @2Toys said, the door placard is for tires of the stock size and load range. Any tires that match OEM specs can be run at this pressure.
    If you change size and/or load range, there's a handy calculator linked in post #8 that will tell you the appropriate new pressure. Some folks like to use a chalk test, or just experiment to see what works, but the calculator is the safest bet.
    2Toys and Toy4X4 like this.
  27. Dec 23, 2022 at 4:46 PM
    Gstick
    Gstick New Member
    19' TRD OFF ROAD
    Well I hate to be the bearer of bad news but, LT tires need more air pressure than "P metric" or SL tires, even if they are the exact same size as OEM.
    Stoney Ranger[OP] and Toy4X4 like this.
  28. Dec 23, 2022 at 5:43 PM
    Any idea what is the reason LT285s have higher psi recommendation vs P285 have very low psi?
    (which I'm not comfortable running)
  29. Dec 23, 2022 at 5:47 PM
    Singleminded
    OEM LED foglights
    52. That's what my dealer delivered mine at, so it must be right. :laugh:
  30. Dec 23, 2022 at 5:47 PM
    Fortuner
    Fortuner New Member
    CA
    The PSI recommendations are mainly for Load Carrying Capacity. For an LT tire to have the same Load carrying capacity as a P metric, the pressure requirements are greater.
    brainh18, Falken QA, Toy4X4 and 2 others like this.
