What lift for 33-35” tires?
Discussion in '4th Gen 4Runners (2003-2009)' started by DATURK, Dec 18, 2022.
  1. Feb 22, 2023 at 5:37 AM
    Ahspurlock
    Ahspurlock New Member
    Summerville SC
    08 T4R limited
    @Libagui got measurements so roughly
    Front is at 24"
    Rear is at 24-1/4
    Measured from center of hub to bottom of uncut fender
    Libagui likes this.
  2. Feb 22, 2023 at 4:04 PM
    Libagui
    Libagui New Member
    Librado
    2006 Silver 4runner limited.
    Awesome, thank you!
    Ahspurlock[QUOTED] likes this.
  3. Sep 5, 2023 at 10:07 AM
    xmt037
    xmt037 New Member
    2021 ORP
    ARB Skid Plates, FrontRunner SlimLine2 rack, 31" KO2s
    What wheels do you have for the Wildpeaks?
  4. Sep 5, 2023 at 10:21 AM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    If you look at his posts prior to that one, he is running OEM 5th gen 4Runner wheels. They are many options but generally, the OEM wheels will fit the Wildpeaks in the 285/70 size.
  5. Sep 5, 2023 at 1:26 PM
    TrailSpecial22 New Member
    PA
    they arw the stock rims that came with my 2022 trail special edition.
  6. Sep 14, 2023 at 9:27 AM
    Bmxer06pa
    Bmxer06pa New Member
    21DE0D1E-0208-4B6F-8643-452D8BCF25ED.jpg 03F910E1-4DFD-46D5-90A0-23DBCBF8C63B.jpg I have the stage 3 Icon suspension kit and run 35's. I had to get the SpiderCo wheel spacers and cut my front body mount. I need to adjust my steering stops because it just kisses the frame at full lock. I also need to trim my fenders as the rub offroad. They are fine on the street though.
    I did regear when I got lockers, but I drove it for almost a year before that. It wasn't terrible, it's not like these trucks are fast stock anyways.
  7. Sep 14, 2023 at 2:35 PM
    Ctreg
    Ctreg New Member
    Ahspurlock, SlvrSlug and djwantke like this.
  8. Sep 14, 2023 at 2:42 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    one may be able to turn full lock, but can you flex and stuff!
    ↓ this is virtually what's needed for big daddy 35's ↓
    SlvrSlug likes this.
  9. Sep 19, 2023 at 6:51 AM
    Eubeenhadd
    Eubeenhadd Bit of a derp
    Indianapolis
    2005 T4R 4.7 AWD
    Spartan Locker, OME 885/895w/stiff Nitrochargers, 265/70R17 Encounter AT
    How thick are those spacers?
  10. Sep 19, 2023 at 7:41 AM
    Bmxer06pa
    i’m pretty sure I bought these
    djwantke and Eubeenhadd[QUOTED] like this.
  11. Oct 19, 2023 at 4:15 AM
    Ahspurlock
    Summerville SC
    08 T4R limited
    New wheel setup on the runner for overland off-road 35x12.50-17 IMG_20231017_074717_032.jpg IMG_20231017_130137_248.jpg IMG_20231017_130137_219.jpg
    xtremewlr and SlvrSlug like this.
  12. Oct 19, 2023 at 9:54 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    EMU BP51, 285/75/R17 KO2s, zero rub. Invest in a quality lift kit, you will save money in the long run.
    Ahspurlock and SlvrSlug like this.
  13. Nov 5, 2023 at 3:50 AM
    Ahspurlock
    Summerville SC
    08 T4R limited
    We'll getting ready to change up the tire size . So I'm currently running 35s and will run 35s for daily driving but the off-road/overland rims will be 37s :D
    xtremewlr and gkomo like this.
  14. Nov 11, 2023 at 9:15 AM
    Ahspurlock
    Summerville SC
    08 T4R limited
    Got 1 of the 37s mounted up lol 3 more to go
  15. Nov 11, 2023 at 11:58 AM
    :drool:
    Those Mickeys are sexy as hell! I'm considering some for my next set of "summer" tires.
    Are those Baja MTZ's in the background your previous set?
  16. Nov 11, 2023 at 12:05 PM
    Ahspurlock
    Summerville SC
    08 T4R limited
    Yea they were .35x1250-17s
  17. Nov 14, 2023 at 11:59 PM
    Yotaholic
    Olympia, WA
    I am running 33.8 inch 285/75/R17s with EMU BP51 lift. Zero rubbing at full flex after minimal chopping.
    SlvrSlug, Ahspurlock and Han4Run like this.
  18. Nov 21, 2023 at 2:18 AM
    Ahspurlock
    Summerville SC
    08 T4R limited
