What is this dark spot/oil?
Discussion in '5th Gen 4Runners (2010-2024)' started by Dutchjoy, Aug 15, 2024.
  1. Aug 15, 2024 at 6:44 PM
    Dutchjoy
    Dutchjoy [OP] New Member
    Any one else have dark oil spots?
  2. Aug 15, 2024 at 7:02 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    When you think about all the stuff that your truck runs over on the road... I wouldn't get excited about that as long as there are no oil drips on the ground under the engine when you park it, and the oil level doesn't change much on the dipstick.
  3. Aug 15, 2024 at 7:16 PM
    Dutchjoy
    Under 5k miles too.
  4. Aug 15, 2024 at 7:26 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Have you had a look underneath and in front of where that spot is? Can you see anything above it in the engine compartment?
    Saker likes this.
  5. Aug 15, 2024 at 8:11 PM
    HuskyMike
    HuskyMike New Member
    Did you install the suspension upgrade yourself?
  6. Aug 15, 2024 at 8:21 PM
    Dutchjoy
    Shop did but spot was there before. I'll check it out tomorrow and take more pic
  7. Aug 15, 2024 at 9:49 PM
    Jasonst4r
    Jasonst4r New Member
    Jason
    2021 offroad barcelona red
    275 70 17 at3w
    that is definitely not from running something over on the road, there is no cast off, which there would be from a spinning tire.
    Saker likes this.
  8. Aug 16, 2024 at 7:55 AM
    3JOH22A Toyota Gigolo
    Have you touched/smelled it to confirm it's oil?
    Things in the vicinity in the engine compartment
    - Sulfuric acid spilling out of the battery
    - Front diff oil puking out of the breather
    - Spilled engine oil from filling
    - Broken oil filler neck (only for dual battery setups)
  9. Aug 16, 2024 at 7:58 AM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    I’ve had a few oil changes where as much oil was left all over my engine compartment as there was in the engine. You should investigate but I’m betting a shitty oil change job and blowback all over. Look around to confirm because a single photo doesn’t tell the whole story. Good luck
  10. Aug 17, 2024 at 1:25 AM
    MooreKen
    MooreKen 2023 TRD PRO “Solar Octane”
    Just checking back in with OP; Were you able to find out the root cause?
  11. Aug 17, 2024 at 8:26 AM
    No oil spots here. That looks like a lot of something was spilled inside the engine bay. Have you had the oil changed on it? I’d pop the hood and take a look around. Make sure the oil fill cap is on and tight.
    Saker likes this.
