What is the noise??
Discussion in '5th Gen 4Runners (2010-2024)' started by boa2, Nov 25, 2020.
  1. Nov 25, 2020 at 3:43 PM
    boa2
    boa2 [OP] New Member
    Our 2020 4Runner Off-Road Premium with KDSS has had this noise since new. It occurs when the car jostles side to side on rough road.
    Two dealers acknowledged with me on a test drive that they hear the noise. They have seen two videos of the noise, which I can generate simply by shaking the vehicle side to side.
    It is not the shocks/struts, and generally occurs when it's 50 degrees or warmer.
    We have gone to 2 different dealers a total of 5 times, and they always call back a day later and say they cannot duplicate the noise.
    Any ideas? Thank you in advance.
  2. Nov 25, 2020 at 3:48 PM
    Max4Runnah
    Max4Runnah New Member
    2014 Nauty Blue SR5 4x4
    Stock and in the works
    Thatbassguy and boa2[OP] like this.
  3. Nov 25, 2020 at 5:20 PM
    Agent_Outside
    Built 2011 T4R Limited
    It definitely sounds like a bushing. Have someone else shake the vehicle and lay under it and feel differing bushings with your hand. You’ll be able to feel the sound resonating. Use regular water in a spray bottle and spray down suspected bushings. Water will act as a lubricant but dry without contamination.
    Max4Runnah, Thatbassguy and boa2[OP] like this.
  4. Nov 25, 2020 at 5:22 PM
    Agent_Outside
    Radiators are semi sealed to force air to go through them instead of through gaps around them.
  5. Nov 25, 2020 at 5:23 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Sounds like my bed during sexy time
  6. Nov 25, 2020 at 8:37 PM
    boa2
  7. Nov 25, 2020 at 8:38 PM
    boa2
    Will do. Great idea, thank you.
  8. Nov 25, 2020 at 8:39 PM
    boa2
    Send it.
    Thatbassguy and A&P like this.
  9. Nov 25, 2020 at 10:17 PM
    4runningMan
    4runningMan New Member
    New Mexico
    Somebody was gonna say it. Surprised it took 5 posts! You guys are gettin slow.
  10. Nov 26, 2020 at 7:27 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX4(Runner)60
    That video was way longer though
  11. Nov 26, 2020 at 7:57 AM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    That’s what she said...
