What is Load Rating E on Tires?
Discussion in '6th Gen 4Runners (2025+)' started by garoto, Mar 28, 2024.
  1. Mar 28, 2024 at 7:42 PM
    garoto
    garoto [OP] New Member
    Any advantages to E rated tires? Looking at Wildpeek A/T 4W. Or is SL the way to go? Not going oversized as I’m avoiding rubbing.
    thanks!
  2. Mar 28, 2024 at 8:06 PM
    Load range E are LT tires. Load range C is a 6ply rating, D is 8 ply, E is 10 ply. Although, there aren't necessarily that many actual plies.
    Load range E is good if you need maximum puncture resistance. SL is ideal for the best ride quality and fuel economy, and is fine for mild to moderate off-roading. Load range C is a popular middle ground.
    Sometimes there variations in tread compound and siping between the SL and LT versions of tires. I'd stick to the SL version for mild off-roading and mostly street use.
    Yotaholic, JChiz, brownersd and 6 others like this.
  3. Mar 28, 2024 at 8:10 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    :101010:
  4. Mar 28, 2024 at 8:39 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    It's a real tradeoff. You'll definitely notice the extra weight, but the durability gives peace of mind in those situations where failure would be most inconvenient. The weight is there all the time, though, and only you can say whether the durability offsets it.
    Yotaholic, JChiz, brownersd and 2 others like this.
  5. Mar 29, 2024 at 5:26 AM
    garoto
    I will stick to standard load. The SL ones are already 6lbs heavier per corner than the Terra grappler. The E load is 13lbs heavier per corner (7lbs more than SL).
    E rated tires seem to be very duty specific. I’d do it in my non daily wrangler or bronco if I owned one. But my 4Runner is also my daily so the SL wildpeaks seem like a good compromise.
  6. Apr 2, 2024 at 5:36 AM
    NoDak
    NoDak New Member
    JR
    North Dakota
    from what i remember, "E" rating tires are also used for towing heavy loads. usually you mate them to 8 lug rims since most 6 lugs are only rated up to 2500 lbs vs like 3500 for 8 lugs.
    since we never tow 99.5% of the time, we just use standard load (p-rated) duratracs on our 23 tundra platinum since its the wifes daily driver.
    Yotaholic and JChiz like this.
  7. Apr 2, 2024 at 5:50 AM
    Good point!
    I forgot to mention this in my other reply. The 4Runner's GVWR and towing capacity don't really necessitate anything beyond an SL, but LT tires might be beneficial for those who are running around heavily loaded most of the time.
  8. Apr 2, 2024 at 5:55 AM
    garoto
    Glad I went with standard.
  9. Apr 2, 2024 at 6:01 AM
    I really think it's the way to go if you don't require maximum puncture resistance, or carry a lot of constant extra weight. I'm actually planning on going SL for my next set of "winter" (all terrain, 3PMSF) tires.
  10. Apr 2, 2024 at 11:27 AM
    JMcFly
    JMcFly New Member
    Some sizes only come in E / LT flavor though. I went with 235/85/15s on my Tacoma and they were only an LT size. Worth it though, saved me from almost getting punctures out and about in woods.
    djwantke and Thatbassguy like this.
  11. Apr 2, 2024 at 12:18 PM
    This is one of the disadvantages of 275/70/17's. Very limited options for tires and most are E or C.
    djwantke and brownersd like this.
  12. Apr 8, 2024 at 9:27 AM
    3JOH22A Toyota Gigolo
    Load range E tires are heavier because the tread is deeper. Tread being solid rubber (as opposed to nylon and kevlar in the carcass) is heavy. So you do get more miles out of E tires before the tread is worn down.
  13. Apr 8, 2024 at 9:36 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    If i had a dedicated off roader i may go to E load. But most i would go is a C load with my moderate off roading. My C load Duratracs have been great and durable for my off roading, going on 4 years now, definitely the longest lasting tire i have ever had.
  14. Apr 8, 2024 at 12:56 PM
    Nice guys, thanks for this info
    (And all the dudes above too)
    I'm switching from load E to load C next tire. Load C is plenty and I can shed a few pounds.
    But...
    Load E's are badass man, I have never got a flat or even a leak - and I have identified 2-3 nails plus a full on lag bolt in my tires, the lag bolt head ended up breaking off, haven't lost a single psi though.
    Look at the side wall thread depth on these puppies:
  15. Apr 9, 2024 at 10:30 AM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    funny enough for the LT275/70R17, load E toyo AT3 (51 lbs) is still lighter than load C Falken AT4W (58.1 lbs) in that same size.
    EDIT: even LT285/70R17 Toyo lighter than LT275/70R17 Falken!
    Doglover2003 and SlvrSlug like this.
  16. Apr 9, 2024 at 7:29 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Load E if you want to minimize the chance of getting flat while offroading
    semprenissart likes this.
  17. Apr 9, 2024 at 7:32 PM
    Yotaholic
    Olympia, WA
    Just for peace of mind, similar to carrying two spares.
