What has made my 5th gen gear shifter super squeaky?
Discussion in '5th Gen 4Runners (2010-2024)' started by djwantke, May 16, 2023.
  1. May 16, 2023 at 1:19 PM
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    My 5th gen gear shifter squeaks and squeals bad in both directions. Maybe started a year ago, bought new 2016. It's pretty annoying. Even more annoying my wife says it's my fault.
    Spray lube had no effect.
    Thanks for any guidance
  2. May 16, 2023 at 2:16 PM
    perhaps you’ve got some debris in there. Maybe take it apart and blow it out with some compressed air.
    Texrun50 likes this.
  3. May 16, 2023 at 2:34 PM
    Or spilled soda?
    Nothing will ruin an interior quicker than soda.
  4. May 16, 2023 at 7:08 PM
    There's certainly been little spills, probably coffee as well. Doesn't help it's the wife n babies weekday daily.
    YouTube knows all!
    Slopemaster likes this.
  5. May 16, 2023 at 7:21 PM
    EC15
    EC15 ...
    Neutral safety switch is starting to go.
    It starts that way, then the gear indicator malfunction and dash lights will be next.
    Get underneath and start soaking it with penetrating fluid for the inevitable swap.
    Its on the passenger side of the transmission.
    https://youtu.be/R9FUgjwq1_o
  6. May 16, 2023 at 7:37 PM
  7. May 17, 2023 at 6:52 AM
    With the needle bearing soon to follow...:eek:
  8. May 17, 2023 at 11:44 AM
  9. May 17, 2023 at 11:45 AM
    @EC15 thank-you very much; penetrating fluid as in a lubricant?
  10. May 17, 2023 at 12:24 PM
    MartianArmada
    MartianArmada New Member
    Alex
    Harford County, MD
    2021 Venture
    Wildpeaks
    Penetrants are basically a lubricant that creep very well.
    If you don't have any, order a can of Kroil and spray a bit on every bolt you remove. I sprayed a bit on a ~120k mile turbo manifold on my Mazda a few times over the course of a couple days and was able to remove the turbo and manifold without snapping any studs - and was able to reuse all hardware.
  11. May 17, 2023 at 12:29 PM
    Sorry, lousy joke. What @EC15 posted seemed completely unrelated to what you were asking about, so I threw something else also in to the mix...please ignore.
  12. May 17, 2023 at 12:58 PM
    EC15
    EC15 ...
    Refer to what @MartianArmada said.
    Penetrating fluid like Kroil or PB Blaster can help.
    The NSS gets rusted to the shaft and can be a bitch to take out.
    Unrelated?
  13. May 17, 2023 at 1:51 PM
    I have the b'laster penetrating catalyst, it would be perfect no?
  14. May 17, 2023 at 1:58 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    If the squeak is coming directly from the shifter/console area I doubt it's a Neutral Safety Switch causing the noise, if the squeak seems to be coming from deep under the shifter/floor and more on the passenger's side then maybe it could the the switch.
    That being said it certainly wouldn't hurt to spray a little lube on the switch.
    djwantke[OP] likes this.
  15. May 17, 2023 at 2:55 PM
    EC15
    EC15 ...
    That's it.
    Keep in mind, it is not intended to make your shifter feel better. It's mainly to aid with removing the old NSS.
  16. May 17, 2023 at 3:06 PM
    EC15
    EC15 ...
    The squeaks do sound like it's coming from the shifter/console and the shifter feels gummed up but that's to Toyotas credit for making the linkages so smooth where a switch on the passenger side of the transmission feels like it's right there.
    Same symptoms OP described happen on my last 5th gen
    NOS4A2-1 and AuSeeker[QUOTED] like this.
  17. May 17, 2023 at 4:18 PM
    As a young man when I was introduced to the concept of penetrating oil I ignored the part about applying it several times over the course of a couple of days, but that part is really important. Patience is key. Something I lacked as a young man. ;-)
  18. May 17, 2023 at 8:17 PM
    MartianArmada
    Alex
    Harford County, MD
    2021 Venture
    Wildpeaks
    Nowadays I usually hit any bolt/nut on a car I'm about to remove to just avoid any risks of breakage or struggle.
  19. May 17, 2023 at 9:32 PM
    @Captain Spalding @MartianArmada wise advice, love that. It's like you could predict I definitely did not re-apply multiple times over multiple days, before deeming lube not working
  20. May 17, 2023 at 9:37 PM
    @EC15 thank you!
    Do ya'll know if I can post short smart phone videos on here? To hear the sound
  21. May 18, 2023 at 8:26 AM
    MartianArmada
    Alex
    Harford County, MD
    2021 Venture
    Wildpeaks
    It might be easiest to upload to YouTube as an unlisted video and share the link here.
    djwantke[QUOTED][OP] likes this.
  22. May 18, 2023 at 6:26 PM
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    My gear shift has recently started squeaking when shifting in and out of park . It kind of sounds like a mouse, and it definitely sounds like it’s coming from the console area. Did your sound start like this also?
    A few months back I was getting a hard shift and I sprayed some lubricant on the linkage on the drivers side and on the neutral safety switch (passenger side) and that solved the problem, smooth as butter. But I don’t think this squeaking sound is coming from underneath the vehicle.
  23. May 18, 2023 at 7:23 PM
    Mine sounds like a mouse just like that, yes.
    I mean my sound didn't 'start like this', it just is this; a squeaky shifter. So you're saying you solved the hard shift but your squeak is new?
  24. May 18, 2023 at 8:32 PM
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    Exactly, I solved the hard shifting several months ago and all was good. The squeaking started a few weeks ago. I think I’ll get under the truck and give everything a good spray again and see if that has any effect on the squeaking. If not I’ll have to open the console and check it out. I mean it really does sound like it’s coming from the console, but maybe not.
  25. May 18, 2023 at 8:47 PM
    Ah I hear ya, thank-you. I must take apart the console and investigate, perhaps tnite. It's bloody hot out haha
  26. May 18, 2023 at 8:50 PM
    I'll have to YouTube what exactly I'm looking for :cheers:
  27. May 20, 2023 at 5:56 PM
  28. May 20, 2023 at 6:16 PM
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
  29. May 21, 2023 at 6:55 AM
    EC15
    EC15 ...
    Sounds like what happened to mine.
    Looks like the shifter is not as smooth either right?
  30. May 21, 2023 at 8:34 AM
    Shifter seems the same, I haven't noticed it necessarily less smooth. Just squeaks, and the noise sounds close by. But like ya'll have said, could be deceiving, and could be irrelevant where it sounds like it's coming from and I indeed do have bigger problem... Or it's a 7 year old Runner with a console I've never cleaned or lubed :D
