What GL rating should the transfer case gear oil have?
Discussion in '3rd Gen 4Runners (1996-2002)' started by Trekker, Sep 4, 2021.
  1. Sep 4, 2021 at 11:52 AM
    Trekker
    Trekker [OP] Regular Member
    1997 3rz 5spd
    I have a VF2A transfer case. I know to use 75W-90 gear oil, but what GL rating should I use?
    The Chilton says I can use GL4 or GL5 in the transfer case. Usually one GL rating is better than the other in a certain application, like the GL4 is better in a transmission because it has fewer additives that can react with bronze synchromesh.
  2. Sep 6, 2021 at 3:49 PM
    Trekker
    1997 3rz 5spd
  3. Sep 6, 2021 at 6:29 PM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    After doing some research a few years ago, I ended up getting ALL kinds of conflicting information.
    1. Just use the Toyota stuff, it's crazy expensive but you only need a quart. That is about $80 if I remember.
    2. Use this instead, I did: https://www.amazon.com/gp/product/B00QPCL7ZE?ie=UTF8 -- and that was about 30k miles ago? I am a big believer in change often so instead of buying really expensive stuff I just change the front/rear diff every 25k miles, and the transfer case about the same. No science here, so lots of people will blast me, but I use SuperTech walmart brand gear oil in the diffs and the Ravenol stuff for the transfer case.
    (For transmission fluid, just pony up for the Toyota stuff).
  4. Sep 7, 2021 at 12:58 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    If it's GL-4 in the transmission, then it's GL-5 in the differentials. I know it's one in the first, say transmission, and the other in the diffs. My problem is my brain is turning to mush lately, for whatever reason (whole different subject...), and I can never remember which is which. If you say GL4 in the transmission, I believe you. That means GL-5 in the diffs.
    I know I went over this in a thread or three over on YotaTech. I'll see if I can find one of them. I know people who remember this stuff have corrected me a few times. Give me a little time...
    Pat☺
  5. Sep 7, 2021 at 4:55 PM
    Tuco S.
    Tuco S. New Member
