What fixed your steering wheel wobble shake?
Discussion in '5th Gen 4Runners (2010-2024)' started by Dr_Egon4r, Aug 1, 2021.
  1. Aug 1, 2021 at 5:18 PM
    Dr_Egon4r
    Dr_Egon4r [OP] New Member
    I guess I’m one of the lucky chosen ones with the steering wobble at highway speeds. I just put on a set of 265 wild peaks with method 701 wheels on my 2020 sr5p. Ive done 2 balances and I need to go back for more. Possibly need to do an alignment (Im going on 18k miles and haven’t done one). I’ve searched and found countless posts on this topic but curious, who’s actually been able to fix this and what worked for you? Not finding a lot of solutions but a lot of the same problems.
  2. Aug 1, 2021 at 6:26 PM
    thatchtt2001
    thatchtt2001 New Member
    TTT
    Northwest Ohio
    2016 Trail
    Eibach Stage 1 Shocks with OEM Springs.
    Are those to wheels hub centric or do they have centric rings at least? I had shake with lug centric XD wheels and I didn't have the rings because they were barely bigger than the hubs. I eventually switched to TRD pro hub centric wheels.... Smoothed everything out.
  3. Aug 1, 2021 at 6:40 PM
    thatchtt2001
    TTT
    Northwest Ohio
    2016 Trail
    I am betting an alignment may be it, the tires are fighting each other a little bit...
  4. Aug 1, 2021 at 6:41 PM
    Dr_Egon4r
    Toy4X4 likes this.
  5. Aug 1, 2021 at 6:43 PM
    Dr_Egon4r
    That’s my next plan of attack. Car only has 18k miles on it and doesn’t pull so I initially thought, nahhh that’s not it. But at this point, I’m willing to try it out since I keep getting told the wheels are balancing out nicely and my rotors seem fine.
  6. Aug 1, 2021 at 6:52 PM
    thatchtt2001
    TTT
    Northwest Ohio
    2016 Trail
    I just got new tires and sometimes I think they need to break in a little to wear so they line up, but I am pretty much making this up lol... Did it do this with your original tires and rims?
  7. Aug 1, 2021 at 6:58 PM
    Dr_Egon4r
    Original stock wheels and crappy stock Dunlops drove and smooth. Never thought I’d say I sorta miss them now. Not sure if I buy the idea of a break in period.
    Trail Runnah likes this.
  8. Aug 1, 2021 at 7:21 PM
    If it didn't wobble with the OEM tires and wheels, it's probably a balance issue. Who's balancing your tires? I had a wobble after a chain balanced my tires. A trip to a trusted off-road shop got them perfect.
    I think the 4runner is sensitive to off balance tires. A friend of mine recently returned a set of Wildpeaks to Discount Tire after multiple failures at balancing them. But, most people who use Wildpeaks are happy with them.
    Toy4X4 likes this.
  9. Aug 1, 2021 at 7:31 PM
    thatchtt2001
    TTT
    Northwest Ohio
    2016 Trail
    it might not be the problem but I just checked out the link you posted for those wheels and they are not hub centric, they are 106.25 which is a little bigger than the 4runners hub at 106.1. This is what I ran into with my wheels and they couldn't balance them after about four tries, they finally put it up on the lift and ran it in four wheel drive and noticed that all four wheels hopped very slightly. Since it was so close to 106.1 I couldn't get any rings since they would be as thin as a couple sheets of paper, so I decided to try to put two layers of metal tape on my hubs to make the wheels fit snug on the hub and I got it almost perfectly smooth doing that... Not saying those wheels won't be able to be smooth, but with my wheels the lugs and cones they pushed into on the wheels were getting chewed up so I decided to get new...
  10. Aug 1, 2021 at 7:39 PM
    thatchtt2001
    TTT
    Northwest Ohio
    2016 Trail
  11. Aug 1, 2021 at 7:54 PM
    adrew0314
    adrew0314 New Member
    Andy
    21 4Runner
    Got mine aligned after a lift and tires and all was well in the universe.
  12. Aug 1, 2021 at 8:55 PM
    Dr_Egon4r
    well damn… my inner Lebowski just said “new sh*t has come to light.” I’ve heard of other running 701’s perfectly fine BUT this is the an element I wasn’t considering. I wonder if the shop I go to will have some TRD pro Semas I can test out if the balance and alignment doesn’t work. Thanks for the tip and link on this!
  13. Aug 1, 2021 at 9:14 PM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    I just turn the music louder and it seems to go away.
