What do you get out of a single tank?
Discussion in '5th Gen 4Runners (2010-2024)' started by Yotaholic, Feb 23, 2024.
  1. Feb 23, 2024 at 3:53 PM
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
    I get between 300 and 365 miles.
    djwantke likes this.
  2. Feb 23, 2024 at 3:57 PM
    I get between 50 & 100 smiles per gallon.
    TrailSpecial22 and BS67 like this.
  3. Feb 23, 2024 at 4:18 PM
    Yotaholic
    Olympia, WA
    I am surprised I did not get the low fuel warning. What is the threshold?
  4. Feb 23, 2024 at 4:19 PM
    Yotaholic
    Olympia, WA
    In dreams
  5. Feb 23, 2024 at 4:25 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    I get about 330, and a lot of smiles with the supercharger :)
    Photon_Chaser and Yotaholic[OP] like this.
  6. Feb 23, 2024 at 4:27 PM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    I get a lighter wallet….
  7. Feb 23, 2024 at 4:27 PM
    TrailSpecial22 and Yotaholic[OP] like this.
  8. Feb 23, 2024 at 4:32 PM
    7Runner
    7Runner New Member
    2018 Silver SR5P
    Around 360 in the winter and around 370 in the summer.
    JS222STL, BS67 and Yotaholic[OP] like this.
  9. Feb 23, 2024 at 4:33 PM
    Oakboro, N.C
    That joker doesn't come on until close to even to the last level line. At least on mine.
  10. Feb 23, 2024 at 4:34 PM
    Yotaholic
    Olympia, WA
    The supercharger is on the menu for me. But after regear and locker :)
    Rob41[QUOTED] likes this.
  11. Feb 23, 2024 at 4:34 PM
    Yotaholic
    Olympia, WA
    Damn lol.
  12. Feb 23, 2024 at 4:35 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    282 miles
    454 kms
    :eek:
    Yotaholic[OP] likes this.
  13. Feb 23, 2024 at 4:36 PM
    Yotaholic
    Olympia, WA
    What is kms?
    RumHamRunner73 likes this.
  14. Feb 23, 2024 at 4:37 PM
    Yotaholic
    Olympia, WA
    The tank is 23 gallons. So a good 3 gallons will be there when the light comes on. Still not enough to get you out of trouble in Montana
    alittleoff, Ripper238 and Toolguy73 like this.
  15. Feb 23, 2024 at 4:50 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    My range shows 320-335 miles when I refuel, but on long trips that don't involve going up mountains hills I've been able to get 360-390 miles by the time the low fuel light shows up.
    I think around 20 miles if I recall so you were almost there.
    Yotaholic[QUOTED][OP] likes this.
  16. Feb 23, 2024 at 4:53 PM
    Haha
    Kilometers, dude
  17. Feb 23, 2024 at 5:08 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Have you ever noticed that kilometers per mile is almost exactly equal to the golden ratio?
  18. Feb 23, 2024 at 5:09 PM
    Not sure, my tank never gets below 3/4?
  19. Feb 23, 2024 at 5:25 PM
    JS222STL
    JS222STL New Member
    2020 SR5 premium
    Same here. 85% hwy driving.
  20. Feb 23, 2024 at 5:35 PM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Why go by miles per tank ? Are people all consistently driving the car until it dies?
    no.
    This approach is baking in all kinds of inconsistencies as each person determines the good enough threshold for “a tank”
    a highly imprecise and low value measurement
  21. Feb 23, 2024 at 5:47 PM
    Wow your one of those eh..
    Just bustin' your balls, I wish I had that discipline to keep filling tank.
  22. Feb 23, 2024 at 5:48 PM
    I'm not familiar with the golden ratio :laughing:
  23. Feb 23, 2024 at 5:51 PM
    Yotaholic
    Olympia, WA
    Dude, Canadian border officer told me on the phone that I can't take my handgun to Alaska. What the hell man! :oops:
  24. Feb 23, 2024 at 5:53 PM
    Yotaholic
    Olympia, WA
    So now how am I going to protect my old ass from the Alaskan moose that take steroids?
  25. Feb 23, 2024 at 5:54 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    If you hadn't said anything, how would they know? Now you attracted their attention! :eek:
  26. Feb 23, 2024 at 5:56 PM
  27. Feb 23, 2024 at 5:57 PM
    Yotaholic
    Olympia, WA
    Not worth the consequences. It's International border, Canada is another country. Come on man lol
  28. Feb 23, 2024 at 6:00 PM
    2Toys
    Gordon
    2019 4Runner TRDORP
    Yeah, except since you spread this on social media, now they are going to send balloons to track you!! LOL! :D
  29. Feb 23, 2024 at 6:00 PM
    No ya you'll go straight to jail any cop spots it lol and sit until your extradited. I bet they'd keep your car even longer
  30. Feb 23, 2024 at 6:02 PM
    2Toys
    Gordon
    2019 4Runner TRDORP
    All kidding aside, @Yotaholic you did the right thing by calling and asking. Not worth the consequences for sure.
    djwantke and Yotaholic[OP] like this.
