What do I need in addition to my supercharger?
Discussion in '3rd Gen 4Runners (1996-2002)' started by ChuckS, Nov 30, 2024.
  1. Nov 30, 2024 at 5:49 AM
    ChuckS
    ChuckS [OP] New Member
    Chuck
    2001 4runner S5
    Old Man Emo springs, methanol injection, lights (fog, driving, ditch), winch, bull bar
    I've got a special case.
    I have a 2001 runner with a bit over 200k miles that I now only use for occasional towing and my annual hunting trip to Wyoming at altitudes from 6,000-10,000 feet that is about 3,000 miles round trip. I tow about 2,000 -3,000 pounds on the trip. It's this annual trip that causes me to write.
    I bought a 2nd gen TRD supercharger 8 years ago for $1,000 and will be having it rebuilt by Superchargers Online. My truck engine/fuel is stock except that I installed cold air intake methanol injection years ago in preparation of a supercharger install and then life got in the way. I'm now ready to do it. Because I go offroad in the middle of nowhere, it is armored like an armadillo and lit up like a Christmas tree.
    I only need some extra power at altitude, especially since I tow my gear pulling a 2,000-3,000 pound trailer in the mountains. I'm not seeking performance anywhere else I will only use the stock pulley and run it conservatively. Maximum longevity and a bit more power above 4,000 feet is what I'm after. That's what forced induction was made for.
    So, with methanol injection, do I need any fuel mods given that I'm only after high altitude assistance and not maximum increases in hp and torque. I'm looking for minimalist, affordable and reliable. I drive my truck like an old woman.
    Last, my 4runner runs like a dream.
  2. Nov 30, 2024 at 5:52 AM
    The only thing you need in addition to your supercharger is gas money. Lots and lots of gas money.
    icebear and ChuckS[OP] like this.
  3. Nov 30, 2024 at 6:17 AM
    ChuckS
    Chuck
    2001 4runner S5
    I've read of supercharged 3rd Gen 4runners that have been converted to run e85 in addition to premium. The high ethanol content is said to prevent any predetination or ping. Downside is that the kit is a grand. Any thoughts?
  4. Nov 30, 2024 at 11:13 AM
    Oakboro, N.C
    I was running methanol injection on my Grand National back in the day but with a big stuff controller and it was very efficient once set up correctly.
  5. Nov 30, 2024 at 11:19 AM
    icebear Recovered Kia Owner
    The cost, availability and further range/efficiency reduction likely won’t make it feasible but that’s my inexperienced opinion. (Will you need that kit to run higher, not-E85 octanes?)
  6. Nov 30, 2024 at 11:51 AM
    E85 gets about -40% worse fuel mileage over 93 pump gas. You have to have bigger fuel pump and about double the injector to flow it, and yes it burns it like no tomorrow. You will get about 2-5mpg at 50% throttle on climbs with E85 and at full throttle you will be lucky to get 1mpg. Your 18.5 gal tank is going to be lucky to get you 150 miles per tank up and down mountains NOT towing, so since you are towing 2000-3000 pounds you are going to be lucky to get 100-120 miles to a tank of fuel. E85 would be the last thing i would run unless its easy to get on your trip or you plan to haul around a 55 gal drum of it and a hand pump to keep your tank topped off.
    Running a 4R and pulling heavy, the supercharger is going to make it a world of difference BUT you will really really want to run premium with octane boost on your climbs. The ECU is good at detecting knock, but not great at preventing it. The engine will be able to lug a high gear and "bog" but still pull big climbs at low RPM, this is the graveyard for boosted engines. The ECU wasnt programmed to know its boosted and doesnt have the tables in the ECU to sense load and downshift like it needs. With the supercharger you will be able to pull tons better and lug the motor down and have enough torque to "muscle" up hills and into headwinds but those low RPM and lugging the motor down while at part throttle like 10-20% throttle will have the engine very lean for efficiency and being lean with boost under loads = detonation. This is an easy recipe to smash the rod bearings out and have a clunking engine when you get home. I am not sure if there is a way to pull timing on your engine, does anyone make timing keys or ECU flashes to work on timing? Maybe see if Overland Taylor does an ECU flash for your machine and the supercharger, i am sure that would be the way to go.
    In the TRD flashes, there were completley different algorithms for load and trans tuning to keep the engine from lugging down and staying in a high gear at slower speeds. Under loads the supercharger will build boost at low throttle % and since the ECU was programmed to see that it has XXX air density, and XX throttle percentage, it assumes it needs to have XX fuel flow to maintain XX AFR. The tune after the supercharger modifies all this and looks more at throttle percentage, crankshaft speed (RPM), gear ratio, to calculate load and then uses an algorithm to upshift and downshift to keep load off the engine to help reduce the likelihood of detonation.
    Old Tanker likes this.
  7. Dec 1, 2024 at 7:59 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Doing all of that, for what you say you need..... Id get a different vehicle. But, best of luck.
    Trekker, ChessGuy and icebear like this.
  8. Dec 22, 2024 at 5:45 AM
    ChuckS
    Chuck
    2001 4runner S5
    I'm looking for advice on a meth controller and advice on how to manage the ecu. Give me your thoughts.
    Also, while we have the plenum off, should I put in new or larger injectors, *just in case* I want to run a 2.2 pulley when headed to the mountains? I intend to run the stock 2.37 pulley otherwise. There is also a 2.3".
    I can drop the tank and put in a larger fuel pump later but larger injectors (at a minimum we'll pull and clean the existing injectors, so we're already there) seems to make sense to do during the SC install.
    I'm interested in value, but not damaging my truck is my first objective. Thanks in advance.
  9. Dec 22, 2024 at 8:03 AM
    I did, here....
    Read what i posted above again, and then read it again, and then if you still dont have the message read it again.
    If you still want to try it out go to Custom Tacos, a place where everyone wanted to supercharge and turbocharge their tacomas. Everyone was turning to meth to keep IATs cool, albeit this was 15+ years ago, maybe you can find an oldie still hanging around on there that remembers how and what evryone was using. There should be tons and tons of reading from the hundreds of threads about it cause it was all the rage back in 2004-2008 with the superchargers on v6 and turbos on the 4cyls.
    RumHamRunner73 and Ironguy like this.
  10. Dec 22, 2024 at 9:24 AM
    Oakboro, N.C
    Correct in all of the above. This is taking into account the hours upon hours of tuning and testing to find a perfect medium. Mine after swapping over full send, was especially limited to track/trailer use.
    Performance was there. The swap point is the hard part to decide on what can be used daily on the street. At some point I had to realize the point I was willing to push to for the end result. Daily driver at that time was a 7.3 F-250 which allowed me to play with the Buick and Duster. Looking back, Monday morning QB style, I realize this isn't a Tacoma but the same influences are there in regards to wants versus rewards and daily reliability.
    Good luck!
  11. Dec 22, 2024 at 2:32 PM
    ChuckS
    Chuck
    2001 4runner S5
    After reading your comment 5 times, I couldn't find anything about a recommended meth controller for the 5vz-fe with a stock 2.37" pulley. Regrettably, I also didnt see any comment about a recommended piggyback for my limited, specific application.
    Merry Christmas.
  12. Dec 22, 2024 at 2:36 PM
    Good luck boss man. Custom tacos.
  13. Dec 22, 2024 at 2:39 PM
    ChuckS
    Chuck
    2001 4runner S5
    I can't put into words how helpful you've been.
    java and roboturner like this.
  14. Dec 22, 2024 at 5:19 PM
    Robb235
    Robb235 New Member
    Rob
    1999 Limited 4wd
    Turbocharged, rear elocker swap, Tundra brake upgrade
    I don’t have water/methanol injection, so I don’t have first hand experience. I’ve heard AEM has a progressive kit for that seems to work well.
    Do you have a wideband gauge? You’ll need one to get your w/m injection dialed in.
  15. Dec 22, 2024 at 6:24 PM
    ChuckS
    Chuck
    2001 4runner S5
    Yes, gotta wideband. Putting in wideband, egt, boost, and run all meaningful 2001 4runner OBDII data through a OBDlink LX to a 9" tablet.
  16. Dec 22, 2024 at 7:52 PM
    Robb235
    Robb235 New Member
    Rob
    1999 Limited 4wd
    That’s good.
    As far as running E85 goes, I’m currently running it with my turbo setup. You need a bigger fuel pump, I’m running a 255lph one. I’m also running 30% larger than stock fuel injectors to compensate for the 30% higher fueling requirement of E85. Even when I was NA before the turbo, I simply replaced my stock 245cc injectors with Supra 315cc ones, filled up with E85, and the ECU is none the wiser. Just for good measure, I replaced my fuel filter after a few hundred miles in case any gunk got cleaned out of the gas tank by the E85. I’m currently tuning closed loop with URD’s Air Fuel Ratio Sensor Calibrator. There’s better ways to tune, including a Haltech stand alone ECU. But Haltech is expensive and mine was more of a budget build since my 4Runner is no longer my daily driver. In your shoes, since you already have a water/methanol system, I would not run E85. There’s not much point to running E85 and w/m injection. The TRD MP62 supercharger is undersized for a 3.4L V6 motor, so it’s not very efficient; meaning that supercharger is really heating up the intake charge. Injecting w/m will help to cool things back down. It would be easier for you to keep a few gallons of water/methanol in the trunk, as it can be a pain to find E85 stations on long road trips. And getting 2/3 the range with E85 can be annoying as well. However $/mile it is cheaper to run e85 than it is 93 premium gas, even with the ~30% heavier fuel consumption of E85.
  17. Dec 22, 2024 at 8:45 PM
    ChuckS
    Chuck
    2001 4runner S5
    Since posting this, I've abandoned e85. It's not easy to get where I'm at, and in WY it will be measurably harder. I carry jerry cans as it is.
    So, if I run the stock 2.37" pulley and run meth, should I upgrade or just replace my stock injectors with 200k miles on them? What meth controller? Should I run a piggyback or leave that to later if I decide to got to a 2.2" pulley and at tgat point drop the tank and put in a higher capacity fuel pump?
  18. Dec 23, 2024 at 3:51 AM
    Robb235
    Robb235 New Member
    Rob
    1999 Limited 4wd
    I would check out the AEM progressive controller.
    https://www.aemelectronics.com/prod...tMXTK8523pvOqz3yejrkU1-pLRzSIkD4aAjMyEALw_wcB
    What sort of budget are you working with? I’d recommend a piggyback to tune with. I’m using URD’s Air Fuel Ratio Sensor Calibrator. You have an ‘01 so that’s an option for you too. I use it to tune fueling for part throttle boost in closed loop.
  19. Dec 23, 2024 at 4:56 AM
    What gear ratio are you running right now? Bigger tires? Or stock....?
    I think regearing would be a better combo for the SC than all the other stuff. Ok, maybe the fuel pump...thing. oh, and even much more important, get a new set of breaks....preferably Bigger rotors...now you need help stopping!
  20. Dec 23, 2024 at 6:03 AM
    Texoma
    Texoma IG: @triplecchopshop
    ChrisTopher
    Lago Vista, TX
    13 T4R
    Just bought dat bish
    Yup, regear that poor ole 8” and 7.5” diff to at least 488 if not 529. You’ll pull no problem. Bigger injectors you’ll need them profiled correctly. Better or newer fuel pump with a new regulator and fuel filter so you have no fuel delivery issues. If you haven’t already, a tad bit colder spark plugs.
  21. Dec 24, 2024 at 3:50 AM
    Kyblack76
    Layton, Utah
    18 TRD O.R
    I will say, if you get it rolling, how you want, .. Please post some pics and vids. Do you man.
    But, sorry, I am zero help with what you want to accomplish, but wish ya luck.
    ChuckS[OP] likes this.
  22. Jan 16, 2025 at 7:52 PM
    ChuckS
    Chuck
    2001 4runner S5
    Any preference for URD over Split Second Air/fuel controller?
  23. Jan 16, 2025 at 8:02 PM
    ChuckS
    Chuck
    2001 4runner S5
    I have to shift into second a lot in the mountains. I'm not sure changing the gear ratio would solve that.
  24. Jan 17, 2025 at 7:33 AM
    Robb235
    Robb235 New Member
    Rob
    1999 Limited 4wd
    They are the same thing.
    ChuckS[QUOTED][OP] likes this.
