What brand of grease you using
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Aug 4, 2023.
  1. Aug 4, 2023 at 11:27 AM
    morfdq [OP] New Member
    What brand of grease are you using on your drive shaft? I know it needs to be NLGI No 2 rated but didn’t know if you were using one you researched or is known for being the best
  2. Aug 4, 2023 at 11:30 AM
    I know some folks like "Green Grease." I just use whatever Wallyworld carries.
  3. Aug 4, 2023 at 11:50 AM
    hvac guy
    hvac guy New Member
    Lucas Red n' tacky
  4. Aug 4, 2023 at 11:54 AM
    Oakboro, N.C
    Lucas green X-tra is what i think is what I last loaded in the grease gun
  5. Aug 4, 2023 at 11:56 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Valvoline Moly-Fortified Gray Full Synthetic
    hossler1788 likes this.
  6. Aug 4, 2023 at 12:03 PM
    Normally Amsoil red but Lucas red now. Any off the shelf NLGI-2 grease will work fine.
    POWERPLANTHOMER likes this.
  7. Aug 4, 2023 at 12:06 PM
    Austin26
    Austin26 New Member
    Austin
    5th gen ORP
    Valvoline synthetic nlgi 2.
  8. Aug 4, 2023 at 12:22 PM
    2021venture
    Todd
    2021 Venture
    Do you guys think drive shafts are being greased if the owner is not doing it themselves? From my experience dealer or other oil change places don't do it. Every 5k and never any problems.
  9. Aug 4, 2023 at 2:56 PM
    3JOH22A Toyota Gigolo
    Castrol Pyroplex from the local big box store. It has good water washout performance.
    The store previously carried Lucas Xtra (green), so I used that in the Tacoma. While a good grease, it's polyurea, incompatible and not intermixable with the more common lithium greases on the market.
  10. Aug 4, 2023 at 2:57 PM
    TRD Ted
    TRD Ted New Member
    These trucks still have zerk fittings?
  11. Aug 4, 2023 at 2:58 PM
    At my local dealers, it's a separate chargeable service costing about $50.
  12. Aug 4, 2023 at 3:05 PM
    hvac guy
    hvac guy New Member
    Yes they do
  13. Aug 4, 2023 at 3:10 PM
    TRD Ted
    TRD Ted New Member
    Interesting, owning one gets more fascinating every day compared to the Tacoma….
    3JOH22A likes this.
  14. Aug 4, 2023 at 3:16 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Lucas x-tra
  15. Aug 4, 2023 at 3:19 PM
    TeslasBigCarbonFootprint
    Southern California
    '23 TRD ORP Super Ice Cap White
    Lucas Red & Tacky.
    If they did it right, $50 is worth the cleanup time and soap alone :D:D:D
  16. Aug 4, 2023 at 8:18 PM
    OdyRunner
    OdyRunner New Member
    I use two different greases, both from Amsoil, that are installed in two different grease guns equipped with lockNlube grease gun coupler, which I highly recommend. I use there synthetic polymeric off-road grease, NLGI #2 grease with 5% moly on the slip yokes and synthetic multi-purpose grease, NLGI #2 on the spyders.
  17. Aug 4, 2023 at 10:17 PM
    I'm curious how many people are using lithium based grease, as spec'd in the manual. Some of the ones mentioned above don't seem to be.
  18. Aug 4, 2023 at 11:27 PM
    Didn’t Tacomas have greasable driveshafts up until very recently. I thought I remembered hearing some surprise that the zerks disappeared one year to the next.
    I’d be curious to know if those driveshafts are different in some way, or if it’s the same driveshaft, but just un-greasable. I would imagine a greasable shaft would be better able to endure corrosion in the spiders when used on salty roads.
  19. Aug 4, 2023 at 11:29 PM
  20. Aug 5, 2023 at 1:47 AM
    blackcloud08
    blackcloud08 They're Watching Us....
    I use Triax or Amsoil for the u-joints and Valvoline FS Moly for the slip joint and ball joints (SPC).
  21. Aug 5, 2023 at 4:46 AM
    Foothills
    Foothills New Member
  22. Aug 5, 2023 at 5:11 AM
    Jere39
    Jere39 Rattlesnake Trail - Sproul SF
    Sky Island, PA
    2022 4Runner SR5 MGM
    AirTec Lube-Shuttle® G200EP Grease I keep it loaded in my Lube-Shuttle at all times and use it on truck, tractor, chipper, ATV, Trac-Vac:
  23. Aug 5, 2023 at 6:18 AM
    TRD Ted
    TRD Ted New Member
    my 2020 did not have any. It spent spent 3 winters in Massachusetts.
  24. Aug 5, 2023 at 6:20 AM
    Austin26
    Austin26 New Member
    Austin
    5th gen ORP
    While we're taking about this, may I suggest using plastic caps to keep the fittings clean. So far I haven't had any come off on the road, either.
    LockNLube Grease Fitting Caps (50 Count) (Yellow) https://a.co/d/5SAtWCN
  25. Aug 5, 2023 at 11:20 AM
    100% agree with you. If you’re not doing it, it’s not getting done
    Toy4X4 and POWERPLANTHOMER like this.
  26. Aug 5, 2023 at 11:25 AM
    That’s laughable. Now you got a 19 year old doing it and I guarantee they aren’t cleaning the fittings first. Nope just push all that dirt and grit in there.
  27. Aug 5, 2023 at 11:26 AM
    That’s what I’m going to start using
  28. Aug 5, 2023 at 11:27 AM
    I’m going to start using that
  29. Aug 5, 2023 at 12:02 PM
    DesertSurfer
    DesertSurfer New Member
    Lucas Red & Tacky from Walmart
  30. Aug 5, 2023 at 12:55 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    You probably won't have any come off either.
    These caps are a worthwhile addition. As @morfdq mentioned above - the grease fitting should be cleaned before hooking up the grease gun. All it takes is a grain of sand or two and it will clog the grease fitting.
    We use the plastic caps on the jets that I maintain. They stay attached to the grease fittings on the landing gear which is subject to speeds in the air over 200 mph.
