Westcott or wait for Eibach for pro?
Discussion in '5th Gen 4Runners (2010-2024)' started by Zal4R, Aug 16, 2021.
  1. Aug 16, 2021 at 9:07 AM
    Zal4R
    Zal4R [OP] New Member
    ‘21 LR TRD Pro
    Eibach TRD Pro Springs RCI Skids
    I have reached a point where I need to lift my 2021 pro a little to meet my off-roading needs. I am trying to decide between westcott designs or waiting for the eibach springs. The prices, at least for past versions are comparable.
    I want to keep as close to the stock fox pro ride as possible, as it is really nice. Both claim they stay pretty close.
    My concerns are would I need to change the ucas if I went with either? Does the westcott lift affect travel, since it is a spacer and collar and achieves lift by compression of the spring in front (iirc). Should I do rear springs and westcott in front? Are either going to cause more wear in my drivetrain/suspension?
    I have been reading, but have not yet been able to track down definitive answers outside of the vendors themselves, which I always take with a grain of salt.
    Roland likes this.
  2. Aug 16, 2021 at 2:06 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Eibach 100%
    No need for UCA upgrade
    Roland, wdsteven and JET4 like this.
  3. Aug 16, 2021 at 2:07 PM
    Bubbles
    Bubbles New Member
    Charleston, SC
    21 TRD Pro Lunar Rock
    Eibach
    Roland and JET4 like this.
  4. Aug 16, 2021 at 3:34 PM
    18 trd off road
    18 trd off road New Member
    Joe
    21 trd pro lunar rock
    Eibach
  5. Aug 16, 2021 at 5:33 PM
    Eibach
    Roland likes this.
  6. Aug 17, 2021 at 6:56 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    Eibach
    Roland likes this.
  7. Aug 17, 2021 at 3:18 PM
    Westcott
    Just kidding. Eibach for sure.
    Roland, 7385 and Jynarik like this.
  8. Aug 17, 2021 at 4:32 PM
    wdsteven
    wdsteven New Member
    I did the Eibach on the 2020 TRD Pro and just works out very good it handle well the install is easy (with the right tools for the front) Also did the Clam Shell Bushing in the front because the Needle bearing may wear faster due to the change of the angle adding some stress in a way the needle bearing do not handle well, very impressed with the results and Yes the Eibach does stay within the range of the Fox Shocks.
    Roland, DRobs and SummitBound like this.
  9. Aug 17, 2021 at 6:36 PM
    ToddD
    ToddD New Member
    ATL
    2021 PRO LR
    Lots of votes for Eibach, but why? Just curious, not being combative nor am I someone who works for Westcott. Why so many people sure in Eibach? I have a 2021 pro and want to raise just a tad so I can fit 285 without cutting, trimming, rubbing, etc. The westcott kit seems like the way to go. I don’t plan on doing any crazy off roading where I go full flex but you never know where a situation would occur. Pros/Cons with either? Westcott is not really classified as a spacer lift but seems like it is for the most part. Will Eibach’s new springs provide enough lift for 285’s while keeping the stock Fox shocks? Sorry for the long winded post, just trying to decide between the 2 once both are available and to see if anyone is in the same dilemma, as the OP
  10. Aug 17, 2021 at 7:08 PM
    YetiMtnBkr
    YetiMtnBkr New Member
    Frederick, MD
    2021 LR Pro
    None
    Well stated because I am in the same boat as you and I don't want to adversely affect the current ride quality (2021 Pro).
  11. Aug 17, 2021 at 11:20 PM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    I did the Eibach springs on my 2020 Pro. Yes 285’s will fit. It rode and handled really well.
    Roland likes this.
  12. Aug 17, 2021 at 11:24 PM
    RusPro17
    Don
    Pa.
    8305C908-7D78-4793-8A75-38C3300CCEB8.jpg Here is a pic before I traded it in on my 21 tundra Pro.
  13. Aug 18, 2021 at 6:12 AM
    Zal4R
    ‘21 LR TRD Pro
    Also tempted to do the springs in the back and wescott up front, since it supposedly keeps suspension geometry.
  14. Aug 18, 2021 at 8:55 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Ask yourself. Does the Westcott kit check all the boxes for my intended use? If it does, then you have your answer. It was my choice, and I'm quite pleased with it.
    EDIT: As it relates to Westcott's lift. There are users with opinions and nonusers with opinions. That's all.
  15. Aug 18, 2021 at 2:49 PM
    The Westcott front lift is $280 for some spacers. I've heard Westcott say they aren't spacers...........I don't understand his logic behind that one..........but they are spacers.
    The Eibach front lift is $200 for lift coils.
    Eibach is a much better value for what you get.
    Bubbles, Roland and 7385 like this.
  16. Aug 18, 2021 at 4:20 PM
    wdsteven
    wdsteven New Member
    It gets better Eibach Front and Rear lift $377 for a well leveled Mild to Moderately hard off road running and great handling on Road.
    7385, Bubbles, DRobs and 2 others like this.
  17. Sep 29, 2021 at 6:22 AM
    Gossamer
    Gossamer lunarrocktrdpro1
    Middle of America
    well considering Eibach doesn't show any spring replacement for the front, it appears Westcott is the only option for 21 trd pro owners...unless you want cornfed spacers, etc.
  18. Sep 29, 2021 at 6:35 AM
    Zal4R
    ‘21 LR TRD Pro
    As of the response I got from them yesterday, Eibach is still waiting on the materials, so they cannot make the front springs for the 2021 pro en masse yet. Was told to check back again in a few weeks.
  19. Sep 29, 2021 at 3:13 PM
    M_RED
    M_RED New Member
    2019 TRD Pro
    Eibach 1.6in LIft springs and 0.25 in spacer in the front Eibach +200lbs load leveler system in the back RSG Angled Sliders
    EIBACH!!
    I did the Eibach's on the front springs, with a 0.4" spacer on top of the shock, and in the rear the Eibach load leveler system with the +200lb springs. Everything still rides fantastic, no issues at all, and my truck sits perfect with a big heavy 5 bike Recon rack on the rear, with 4-5 adults and a back full of mountain bike gear.. couldn't be happier with it...
    MrSmartypants and YetiMtnBkr like this.
  20. Sep 29, 2021 at 4:48 PM
    Charlievee
    Charlievee New Member
    Fyi, keep an eye out on the socialist media sites, seen a new eibach kit for sale this morning. If your going that route.
    2Toys likes this.
  21. Oct 2, 2021 at 1:26 PM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    2021 Magnetic Grey Metallic TRD Pro
    This looks like it may be my route for my 2021 Pro. Especially with me adding a new front bumper and winch. The Eibach should be exactly what I need!!
  22. Oct 2, 2021 at 9:20 PM
    wakebrdr142
    wakebrdr142 New Member
    SC
    21PRO
    Following. The Eibach's look almost perfectly level. Wish there was a little more forward rake.
  23. Oct 3, 2021 at 2:54 AM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    Does anyone know when they will be ready for the 2021 TRD Pro?
  24. Oct 3, 2021 at 6:48 AM
    Zal4R
    ‘21 LR TRD Pro
    I got a reply from Eibach earlier this week that they are still waiting on the metal from their supplier. They are expecting some time in the next few weeks to get the materials and have springs available soon after, but no guarantees there are not more supply delays.
  25. Oct 3, 2021 at 9:54 AM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    I think this is worth waiting for. The springs should have a much better ride than the spacers, right? And they cost difference will be negligible at best.
    7385 likes this.
  26. Oct 3, 2021 at 3:31 PM
    wdsteven
    wdsteven New Member
    The Springs have a great ride better (my opinion) than spacers and have be performing excellent in the different trails I have been on now mind you the trails are not the ones where a spotter walks the entire thing! One thing of Note is Eibach has the rear springs listed on the website for the 21 year 4Runner however not the fronts yet.
  27. Oct 3, 2021 at 3:38 PM
    RusPro17
    Don
    Pa.
    I chose the Eibach springs. I liked how it stiffened up the ride just a little. Took away that plush ride.
  28. Oct 3, 2021 at 3:46 PM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    That “plush ride?” Your TRD Pro had a plush ride? Lol
  29. Oct 3, 2021 at 4:18 PM
    RusPro17
    Don
    Pa.
    More like a soft ride for a 4runner. The springs take away that nose dive. It did look bad looking. But loving my tundra Pro.
  30. Oct 3, 2021 at 6:29 PM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    Just think about it this way Westcott is a spacer but instead of going on the top hat side it goes on the bottom of the spring doing the same thing I would go with the Eibach Spring if i was doing it good luck
    Jrunr likes this.
