Weird noise when off roading
Discussion in '5th Gen 4Runners (2010-2024)' started by remoguy55, Nov 26, 2021.
  1. Nov 26, 2021 at 7:13 PM
    remoguy55
    remoguy55 [OP] New Member
    2020 SR5 Premium 4WD
    Anyone else have a strange noise when going over medium to large ruts or rocks or just bumps on a dirt road? Hard to describe the sound...it's like a squeak but sounds more like a goose honk . I don't hear it on the freeway since there's no flex at all. I feel it's either shocks, springs, or sway bar?
    I have stock SR5 suspension. I hope I'm not the only one so I can diagnose the issue.
  2. Nov 26, 2021 at 7:43 PM
    Mtbpsych
    Mtbpsych New Member
    Off roading creates all sorts of noises. My springs are pretty noisy whenever there’s flexing of the axles involved.
  3. Nov 26, 2021 at 9:12 PM
    Before you hit the panic button, try cleaning the two rubber stoppers for the hood and clean and lubricant the hood latch.
    When these items get a little trail dust they make sounds that mimic a suspension issue.
    I trouble shot these noises by standing on a side step and rocking the truck back and forth. Then I popped the hood latch and the noise went away.
    After I’ve had a day of dusty trails, my 4Runner makes all kinds of weird sounds until I wash it in these areas.
  4. Nov 27, 2021 at 12:08 AM
    I stupidly sprayed wool wax on the lower spring seat on the rear axle. I got a little squeak /groan/pop sound when accelerating or stopping. It went away when i sprayed the spring seat down with brake clean.
    But i recently loaded it up with people and luggage and my other side started with the spring noises lol. If brake clean doesnt fix it, im probably going to take the springs out and clean it up
    remoguy55[OP] likes this.
  5. Nov 27, 2021 at 8:15 AM
    remoguy55
    Thanks all, I'll try cleaning the hood stoppers.
  6. Nov 27, 2021 at 5:50 PM
    T4RNR
    T4RNR New Member
    Anthony
    17 4Runner, 03 Tacoma
    If hood stoppers doesn't work, in my experience, common squeaks on our Toyotas come from the swaybar bushings, end links, and control arm bushings. I've had luck with poly bushings but still require grease over time especially if you wheel often.
  7. Nov 28, 2021 at 11:06 PM
    remoguy55
    Thanks for the advice!
    T4RNR[QUOTED] likes this.
  8. Nov 30, 2021 at 11:08 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    I spray silicone on the rubber bushings ... I do it in November every year . I also spray the boots and my 2016 runner has the boots looking like new ..no noises .. many rubber parts are on the front in the suspension control arms ...
    Crank_Mancastle and ElectroBoy like this.
  9. Nov 30, 2021 at 8:12 PM
    I’ve never really had luck with silicon sprays. I usually use WD40, which I realize isn’t the primary purpose of it.
    On the hood latch and rubber hood stops, I’ve been trying “Boelube” which is a dry lube that Boeing Aircraft developed years ago.
    Comes in a tube and it’s kinda like a soap/wax in a solid form. Very effective.
